I have a Turtlebot2 / Kobuki base but no charger for it. I’ve searched online and can’t seem to find any for sale anywhere. If anyone has a link to where I might purchase one, I’d appreciate it.
Thanks.
Thanks.
Hi Matt,
I looked at the spec sheet and you need an Input: 100-240V AC, 50/60Hz, 1.5A max; Output: 19V DC, 3.16A power supply.
Here’s an example on Amazon: https://www.amazon.com/0335A1960-CPA09-004A-QX410-S02US-NP-QX410-S02US-NP-RV515-A02US/dp/B073BM7Z53
As for the barrel connector, I measured mine at 5mm. The one linked above is 5.5mm, which I assume would also probably work with a little tough love.
S
Thanks @smac, I’ll give that one a try.
My charger broke and I am looking to replace it ASAP.
From the datasheet, I was only able to find the voltage/frequency/current specifications of the charger: Anatomy — kobuki 2.0 documentation
From what I can tell the end is a male barrel connector with positive polarity and measures 5mm in diameter. Is this correct?
