I’ve recently been testing ROS2 galactic and tried using the new per-logger log levels here. I am using it with namespaces and couldn’t get it to work. Is there a way to use it with namespaces?
The command I am using is:
ros2 run robot_control vehicle --ros-args -r __ns:=/drone_0 --log-level vehicle:=DEBUG
I’ve also tried the following after using ros2 node list
to get the node names:
ros2 run robot_control vehicle --ros-args -r __ns:=/drone_0 --log-level /drone_0/vehicle:=DEBUG
