This is a large sync for indigo including over 50 new packages and over 300 updated packages.
Thank you to everyone who has contributed to these releases through Pull request, individual contributions, opening issues etc! The full details of all the updated packages as well as the list of maintainers who made releases is below.
Updates to indigo
Added Packages [52]:
- ros-indigo-cost-map: 0.3.1-0
- ros-indigo-cost-map-core: 0.3.1-0
- ros-indigo-cost-map-cv: 0.3.1-0
- ros-indigo-cost-map-demos: 0.3.1-0
- ros-indigo-cost-map-ros: 0.3.1-0
- ros-indigo-cost-map-visualisations: 0.3.1-0
- ros-indigo-darknet: 2016.11.27-2
- ros-indigo-folaga-msgs: 0.0.3-0
- ros-indigo-four-wheel-steering-controller: 0.2.2-0
- ros-indigo-four-wheel-steering-msgs: 0.2.2-0
- ros-indigo-gazebo-mimic: 0.0.4-0
- ros-indigo-geometry2: 0.5.15-0
- ros-indigo-idolink-node: 0.1.2-0
- ros-indigo-light-scan-sim: 0.1.0-0
- ros-indigo-marvelmind-nav: 1.0.6-0
- ros-indigo-move-base-to-manip: 1.0.6-0
- ros-indigo-moveit-full: 0.7.7-0
- ros-indigo-moveit-full-pr2: 0.7.7-0
- ros-indigo-moveit-runtime: 0.7.7-0
- ros-indigo-plotjuggler: 0.11.0-0
- ros-indigo-pyros-common: 0.4.0-2
- ros-indigo-rail-object-detector: 1.0.4-0
- ros-indigo-range-msgs: 1.1.2-0
- ros-indigo-remote-manipulation-markers: 1.0.1-0
- ros-indigo-robotino-description: 0.0.24-0
- ros-indigo-roch-base: 1.0.12-0
- ros-indigo-roch-bringup: 1.0.9-0
- ros-indigo-roch-capabilities: 1.0.12-0
- ros-indigo-roch-control: 1.0.12-0
- ros-indigo-roch-description: 1.0.12-0
- ros-indigo-roch-ftdi: 1.0.12-0
- ros-indigo-roch-gazebo: 1.0.10-0
- ros-indigo-roch-msgs: 1.0.12-0
- ros-indigo-roch-navigation: 1.0.9-0
- ros-indigo-roch-robot: 1.0.12-0
- ros-indigo-roch-safety-controller: 1.0.12-0
- ros-indigo-roch-sensorpc: 1.0.12-0
- ros-indigo-roch-simulator: 1.0.10-0
- ros-indigo-roch-teleop: 1.0.9-0
- ros-indigo-roch-viz: 1.0.8-0
- ros-indigo-softhand-description: 0.0.24-0
- ros-indigo-squirrel-3d-localizer-msgs: 0.0.24-0
- ros-indigo-squirrel-dynamic-filter-msgs: 0.0.24-0
- ros-indigo-squirrel-vad-msgs: 0.0.24-0
- ros-indigo-squirrel-view-controller-msgs: 0.0.24-0
- ros-indigo-urdf-vehicle-kinematic: 0.2.2-0
- ros-indigo-yumi-control: 0.0.4-0
- ros-indigo-yumi-description: 0.0.4-0
- ros-indigo-yumi-hw: 0.0.4-0
- ros-indigo-yumi-launch: 0.0.4-0
- ros-indigo-yumi-moveit-config: 0.0.4-0
- ros-indigo-yumi-support: 0.0.4-0
Updated Packages [338]:
- ros-indigo-ackermann-controller: 0.1.2-0 -> 0.2.2-0
- ros-indigo-ar-track-alvar: 0.5.4-0 -> 0.5.6-0
- ros-indigo-arm-navigation-msgs: 0.0.3-0 -> 0.0.5-1
- ros-indigo-assimp-devel: 2.0.17-0 -> 2.0.19-0
- ros-indigo-backports-ssl-match-hostname: 3.5.0-2 -> 3.5.0-3
- ros-indigo-bayesian-belief-networks: 2.0.17-0 -> 2.0.19-0
- ros-indigo-camera-calibration-parsers: 1.11.11-0 -> 1.11.12-0
- ros-indigo-camera-info-manager: 1.11.11-0 -> 1.11.12-0
- ros-indigo-carl-moveit: 0.0.17-0 -> 0.0.18-0
- ros-indigo-catkin-pip: 0.1.16-0 -> 0.1.17-0
- ros-indigo-checkerboard-detector: 1.0.1-0 -> 1.1.0-0
- ros-indigo-collada-parser: 1.11.11-0 -> 1.11.12-0
- ros-indigo-collada-robots: 0.0.3-0 -> 0.0.5-1
- ros-indigo-collada-urdf: 1.11.11-0 -> 1.11.12-0
- ros-indigo-collada-urdf-jsk-patch: 2.0.17-0 -> 2.0.19-0
- ros-indigo-contact-states-observer: 0.1.10-0 -> 0.1.11-0
- ros-indigo-cost-map-msgs: 0.3.0-0 -> 0.3.1-0
- ros-indigo-cv-bridge: 1.11.14-0 -> 1.11.15-0
- ros-indigo-default-cfg-fkie: 0.6.2-0 -> 0.7.2-0
- ros-indigo-downward: 2.0.17-0 -> 2.0.19-0
- ros-indigo-dynamic-tf-publisher: 2.1.2-4 -> 2.2.2-1
- ros-indigo-dynamixel-controllers: 0.4.0-0 -> 0.4.1-0
- ros-indigo-dynamixel-driver: 0.4.0-0 -> 0.4.1-0
- ros-indigo-dynamixel-motor: 0.4.0-0 -> 0.4.1-0
- ros-indigo-dynamixel-msgs: 0.4.0-0 -> 0.4.1-0
- ros-indigo-dynamixel-tutorials: 0.4.0-0 -> 0.4.1-0
- ros-indigo-ecl-build: 0.61.4-0 -> 0.61.6-0
- ros-indigo-ecl-command-line: 0.61.15-0 -> 0.61.17-0
- ros-indigo-ecl-concepts: 0.61.15-0 -> 0.61.17-0
- ros-indigo-ecl-containers: 0.61.15-0 -> 0.61.17-0
- ros-indigo-ecl-converters: 0.61.15-0 -> 0.61.17-0
- ros-indigo-ecl-core: 0.61.15-0 -> 0.61.17-0
- ros-indigo-ecl-core-apps: 0.61.15-0 -> 0.61.17-0
- ros-indigo-ecl-devices: 0.61.15-0 -> 0.61.17-0
- ros-indigo-ecl-eigen: 0.61.15-0 -> 0.61.17-0
- ros-indigo-ecl-exceptions: 0.61.15-0 -> 0.61.17-0
- ros-indigo-ecl-filesystem: 0.61.15-0 -> 0.61.17-0
- ros-indigo-ecl-formatters: 0.61.15-0 -> 0.61.17-0
- ros-indigo-ecl-geometry: 0.61.15-0 -> 0.61.17-0
- ros-indigo-ecl-ipc: 0.61.15-0 -> 0.61.17-0
- ros-indigo-ecl-license: 0.61.4-0 -> 0.61.6-0
- ros-indigo-ecl-linear-algebra: 0.61.15-0 -> 0.61.17-0
- ros-indigo-ecl-math: 0.61.15-0 -> 0.61.17-0
- ros-indigo-ecl-mpl: 0.61.15-0 -> 0.61.17-0
- ros-indigo-ecl-sigslots: 0.61.15-0 -> 0.61.17-0
- ros-indigo-ecl-statistics: 0.61.15-0 -> 0.61.17-0
- ros-indigo-ecl-streams: 0.61.15-0 -> 0.61.17-0
- ros-indigo-ecl-threads: 0.61.15-0 -> 0.61.17-0
- ros-indigo-ecl-time: 0.61.15-0 -> 0.61.17-0
- ros-indigo-ecl-tools: 0.61.4-0 -> 0.61.6-0
- ros-indigo-ecl-type-traits: 0.61.15-0 -> 0.61.17-0
- ros-indigo-ecl-utilities: 0.61.15-0 -> 0.61.17-0
- ros-indigo-eus-nlopt: 0.1.10-0 -> 0.1.11-0
- ros-indigo-eusgazebo: 0.1.11-0 -> 0.1.12-0
- ros-indigo-ff: 2.0.17-0 -> 2.0.19-0
- ros-indigo-ffha: 2.0.17-0 -> 2.0.19-0
- ros-indigo-geometry-experimental: 0.5.13-0 -> 0.5.15-0
- ros-indigo-grid-map: 1.4.1-0 -> 1.4.2-0
- ros-indigo-grid-map-core: 1.4.1-0 -> 1.4.2-0
- ros-indigo-grid-map-cv: 1.4.1-0 -> 1.4.2-0
- ros-indigo-grid-map-demos: 1.4.1-0 -> 1.4.2-0
- ros-indigo-grid-map-filters: 1.4.1-0 -> 1.4.2-0
- ros-indigo-grid-map-loader: 1.4.1-0 -> 1.4.2-0
- ros-indigo-grid-map-msgs: 1.4.1-0 -> 1.4.2-0
- ros-indigo-grid-map-pcl: 1.4.1-0 -> 1.4.2-0
- ros-indigo-grid-map-ros: 1.4.1-0 -> 1.4.2-0
- ros-indigo-grid-map-rviz-plugin: 1.4.1-0 -> 1.4.2-0
- ros-indigo-grid-map-visualization: 1.4.1-0 -> 1.4.2-0
- ros-indigo-hironx-calibration: 1.1.18-0 -> 1.1.20-0
- ros-indigo-hironx-moveit-config: 1.1.18-0 -> 1.1.20-0
- ros-indigo-hironx-ros-bridge: 1.1.18-0 -> 1.1.20-0
- ros-indigo-hrpsys-gazebo-general: 0.1.11-0 -> 0.1.12-0
- ros-indigo-hrpsys-gazebo-msgs: 0.1.11-0 -> 0.1.12-0
- ros-indigo-ihmc-msgs: 0.8.0-6 -> 0.9.1-4
- ros-indigo-ihmc-ros-common: 0.8.0-6 -> 0.9.1-4
- ros-indigo-ihmc-ros-core: 0.8.0-6 -> 0.9.1-4
- ros-indigo-ihmc-ros-java-adapter: 0.8.0-6 -> 0.9.1-4
- ros-indigo-image-common: 1.11.11-0 -> 1.11.12-0
- ros-indigo-image-geometry: 1.11.14-0 -> 1.11.15-0
- ros-indigo-image-transport: 1.11.11-0 -> 1.11.12-0
- ros-indigo-image-view2: 2.1.2-4 -> 2.2.2-1
- ros-indigo-imagesift: 1.0.1-0 -> 1.1.0-0
- ros-indigo-imu-pipeline: 0.2.1-0 -> 0.2.2-0
- ros-indigo-imu-processors: 0.2.1-0 -> 0.2.2-0
- ros-indigo-imu-transformer: 0.2.1-0 -> 0.2.2-0
- ros-indigo-joint-state-publisher: 1.11.11-0 -> 1.11.12-0
- ros-indigo-joy: 1.10.1-0 -> 1.11.0-1
- ros-indigo-joy-mouse: 0.1.10-0 -> 0.1.11-0
- ros-indigo-joystick-drivers: 1.10.1-0 -> 1.11.0-1
- ros-indigo-jsk-3rdparty: 2.0.17-0 -> 2.0.19-0
- ros-indigo-jsk-calibration: 0.1.10-0 -> 0.1.11-0
- ros-indigo-jsk-common: 2.1.2-4 -> 2.2.2-1
- ros-indigo-jsk-data: 2.1.2-4 -> 2.2.2-1
- ros-indigo-jsk-footstep-controller: 0.1.10-0 -> 0.1.11-0
- ros-indigo-jsk-footstep-planner: 0.1.10-0 -> 0.1.11-0
- ros-indigo-jsk-ik-server: 0.1.10-0 -> 0.1.11-0
- ros-indigo-jsk-interactive: 2.0.1-0 -> 2.1.0-0
- ros-indigo-jsk-interactive-marker: 2.0.1-0 -> 2.1.0-0
- ros-indigo-jsk-interactive-test: 2.0.1-0 -> 2.1.0-0
- ros-indigo-jsk-network-tools: 2.1.2-4 -> 2.2.2-1
- ros-indigo-jsk-pcl-ros: 1.0.1-0 -> 1.1.0-0
- ros-indigo-jsk-pcl-ros-utils: 1.0.1-0 -> 1.1.0-0
- ros-indigo-jsk-perception: 1.0.1-0 -> 1.1.0-0
- ros-indigo-jsk-planning: 0.1.7-0 -> 0.1.8-0
- ros-indigo-jsk-pr2eus: 0.3.5-0 -> 0.3.9-0
- ros-indigo-jsk-recognition: 1.0.1-0 -> 1.1.0-0
- ros-indigo-jsk-recognition-msgs: 1.0.1-0 -> 1.1.0-0
- ros-indigo-jsk-recognition-utils: 1.0.1-0 -> 1.1.0-0
- ros-indigo-jsk-rqt-plugins: 2.0.1-0 -> 2.1.0-0
- ros-indigo-jsk-rviz-plugins: 2.0.1-0 -> 2.1.0-0
- ros-indigo-jsk-teleop-joy: 0.1.10-0 -> 0.1.11-0
- ros-indigo-jsk-tilt-laser: 2.1.2-4 -> 2.2.2-1
- ros-indigo-jsk-tools: 2.1.2-4 -> 2.2.2-1
- ros-indigo-jsk-topic-tools: 2.1.2-4 -> 2.2.2-1
- ros-indigo-jsk-visualization: 2.0.1-0 -> 2.1.0-0
- ros-indigo-julius: 2.0.17-0 -> 2.0.19-0
- ros-indigo-katana: 1.0.5-0 -> 1.0.7-0
- ros-indigo-katana-arm-gazebo: 1.0.5-0 -> 1.0.7-0
- ros-indigo-katana-description: 1.0.5-0 -> 1.0.7-0
- ros-indigo-katana-driver: 1.0.5-0 -> 1.0.7-0
- ros-indigo-katana-gazebo-plugins: 1.0.5-0 -> 1.0.7-0
- ros-indigo-katana-moveit-ikfast-plugin: 1.0.5-0 -> 1.0.7-0
- ros-indigo-katana-msgs: 1.0.5-0 -> 1.0.7-0
- ros-indigo-katana-teleop: 1.0.5-0 -> 1.0.7-0
- ros-indigo-katana-tutorials: 1.0.5-0 -> 1.0.7-0
- ros-indigo-kdl-parser: 1.11.11-0 -> 1.11.12-0
- ros-indigo-kdl-parser-py: 1.11.11-0 -> 1.11.12-0
- ros-indigo-kni: 1.0.5-0 -> 1.0.7-0
- ros-indigo-laser-filters-jsk-patch: 2.0.17-0 -> 2.0.19-0
- ros-indigo-leap-motion: 0.0.10-0 -> 0.0.11-0
- ros-indigo-libcmt: 2.0.17-0 -> 2.0.19-0
- ros-indigo-libmavconn: 0.17.4-0 -> 0.17.5-0
- ros-indigo-librealsense: 1.12.0-0 -> 1.12.1-0
- ros-indigo-libsiftfast: 2.0.17-0 -> 2.0.19-0
- ros-indigo-lpg-planner: 2.0.17-0 -> 2.0.19-0
- ros-indigo-marti-can-msgs: 0.0.6-0 -> 0.0.7-0
- ros-indigo-marti-common-msgs: 0.0.6-0 -> 0.0.7-0
- ros-indigo-marti-nav-msgs: 0.0.6-0 -> 0.0.7-0
- ros-indigo-marti-perception-msgs: 0.0.6-0 -> 0.0.7-0
- ros-indigo-marti-sensor-msgs: 0.0.6-0 -> 0.0.7-0
- ros-indigo-marti-visualization-msgs: 0.0.6-0 -> 0.0.7-0
- ros-indigo-master-discovery-fkie: 0.6.2-0 -> 0.7.2-0
- ros-indigo-master-sync-fkie: 0.6.2-0 -> 0.7.2-0
- ros-indigo-mavros: 0.17.4-0 -> 0.17.5-0
- ros-indigo-mavros-extras: 0.17.4-0 -> 0.17.5-0
- ros-indigo-mavros-msgs: 0.17.4-0 -> 0.17.5-0
- ros-indigo-mini-maxwell: 2.0.17-0 -> 2.0.19-0
- ros-indigo-moveit: 0.7.6-0 -> 0.7.7-0
- ros-indigo-moveit-commander: 0.7.6-0 -> 0.7.7-0
- ros-indigo-moveit-controller-manager-example: 0.7.6-0 -> 0.7.7-0
- ros-indigo-moveit-core: 0.7.6-0 -> 0.7.7-0
- ros-indigo-moveit-fake-controller-manager: 0.7.6-0 -> 0.7.7-0
- ros-indigo-moveit-kinematics: 0.7.6-0 -> 0.7.7-0
- ros-indigo-moveit-planners: 0.7.6-0 -> 0.7.7-0
- ros-indigo-moveit-planners-ompl: 0.7.6-0 -> 0.7.7-0
- ros-indigo-moveit-plugins: 0.7.6-0 -> 0.7.7-0
- ros-indigo-moveit-ros: 0.7.6-0 -> 0.7.7-0
- ros-indigo-moveit-ros-benchmarks: 0.7.6-0 -> 0.7.7-0
- ros-indigo-moveit-ros-benchmarks-gui: 0.7.6-0 -> 0.7.7-0
- ros-indigo-moveit-ros-control-interface: 0.7.6-0 -> 0.7.7-0
- ros-indigo-moveit-ros-manipulation: 0.7.6-0 -> 0.7.7-0
- ros-indigo-moveit-ros-move-group: 0.7.6-0 -> 0.7.7-0
- ros-indigo-moveit-ros-perception: 0.7.6-0 -> 0.7.7-0
- ros-indigo-moveit-ros-planning: 0.7.6-0 -> 0.7.7-0
- ros-indigo-moveit-ros-planning-interface: 0.7.6-0 -> 0.7.7-0
- ros-indigo-moveit-ros-robot-interaction: 0.7.6-0 -> 0.7.7-0
- ros-indigo-moveit-ros-visualization: 0.7.6-0 -> 0.7.7-0
- ros-indigo-moveit-ros-warehouse: 0.7.6-0 -> 0.7.7-0
- ros-indigo-moveit-setup-assistant: 0.7.6-0 -> 0.7.7-0
- ros-indigo-moveit-simple-controller-manager: 0.7.6-0 -> 0.7.7-0
- ros-indigo-multi-map-server: 2.1.2-4 -> 2.2.2-1
- ros-indigo-multimaster-fkie: 0.6.2-0 -> 0.7.2-0
- ros-indigo-multimaster-msgs-fkie: 0.6.2-0 -> 0.7.2-0
- ros-indigo-multisense: 3.4.7-0 -> 4.0.0-0
- ros-indigo-multisense-bringup: 3.4.7-0 -> 4.0.0-0
- ros-indigo-multisense-cal-check: 3.4.7-0 -> 4.0.0-0
- ros-indigo-multisense-description: 3.4.7-0 -> 4.0.0-0
- ros-indigo-multisense-lib: 3.4.7-0 -> 4.0.0-0
- ros-indigo-multisense-ros: 3.4.7-0 -> 4.0.0-0
- ros-indigo-nao-control: 0.0.5-0 -> 0.0.6-0
- ros-indigo-nao-dcm-bringup: 0.0.3-0 -> 0.0.4-0
- ros-indigo-nao-gazebo-plugin: 0.0.5-0 -> 0.0.6-0
- ros-indigo-nao-moveit-config: 0.0.10-0 -> 0.0.11-0
- ros-indigo-nerian-sp1: 1.3.3-0 -> 1.6.0-0
- ros-indigo-nextage-description: 0.7.11-0 -> 0.7.14-0
- ros-indigo-nextage-gazebo: 0.7.11-0 -> 0.7.14-0
- ros-indigo-nextage-ik-plugin: 0.7.11-0 -> 0.7.14-0
- ros-indigo-nextage-moveit-config: 0.7.11-0 -> 0.7.14-0
- ros-indigo-nextage-ros-bridge: 0.7.11-0 -> 0.7.14-0
- ros-indigo-nlopt: 2.0.17-0 -> 2.0.19-0
- ros-indigo-node-manager-fkie: 0.6.2-0 -> 0.7.2-0
- ros-indigo-object-recognition-core: 0.6.5-0 -> 0.6.7-0
- ros-indigo-openhrp3: 3.1.8-0 -> 3.1.9-0
- ros-indigo-openrave: 0.0.3-0 -> 0.0.5-1
- ros-indigo-openrave-planning: 0.0.3-0 -> 0.0.5-1
- ros-indigo-opt-camera: 2.0.17-0 -> 2.0.19-0
- ros-indigo-parrot-arsdk: 3.10.1-0 -> 3.11.0-0
- ros-indigo-pddl-msgs: 0.1.7-0 -> 0.1.8-0
- ros-indigo-pddl-planner: 0.1.7-0 -> 0.1.8-0
- ros-indigo-pddl-planner-viewer: 0.1.7-0 -> 0.1.8-0
- ros-indigo-pepper-bringup: 0.1.7-0 -> 0.1.10-1
- ros-indigo-pepper-description: 0.1.7-0 -> 0.1.10-1
- ros-indigo-pepper-moveit-config: 0.0.6-0 -> 0.0.8-0
- ros-indigo-pepper-robot: 0.1.7-0 -> 0.1.10-1
- ros-indigo-pepper-sensors-py: 0.1.7-0 -> 0.1.10-1
- ros-indigo-pgm-learner: 2.0.17-0 -> 2.0.19-0
- ros-indigo-phidgets-api: 0.2.2-0 -> 0.2.3-1
- ros-indigo-phidgets-drivers: 0.2.2-0 -> 0.2.3-1
- ros-indigo-phidgets-imu: 0.2.2-0 -> 0.2.3-1
- ros-indigo-phidgets-ir: 0.2.2-0 -> 0.2.3-1
- ros-indigo-polled-camera: 1.11.11-0 -> 1.11.12-0
- ros-indigo-pr2eus: 0.3.5-0 -> 0.3.9-0
- ros-indigo-pr2eus-moveit: 0.3.5-0 -> 0.3.9-0
- ros-indigo-pr2eus-tutorials: 0.3.5-0 -> 0.3.9-0
- ros-indigo-ps3joy: 1.10.1-0 -> 1.11.0-1
- ros-indigo-pyros: 0.3.0-2 -> 0.3.1-0
- ros-indigo-qt-dotgraph: 0.2.31-0 -> 0.2.32-0
- ros-indigo-qt-gui: 0.2.31-0 -> 0.2.32-0
- ros-indigo-qt-gui-app: 0.2.31-0 -> 0.2.32-0
- ros-indigo-qt-gui-core: 0.2.31-0 -> 0.2.32-0
- ros-indigo-qt-gui-cpp: 0.2.31-0 -> 0.2.32-0
- ros-indigo-qt-gui-py-common: 0.2.31-0 -> 0.2.32-0
- ros-indigo-rail-manipulation-msgs: 0.0.8-0 -> 0.0.9-0
- ros-indigo-realsense-camera: 1.7.0-0 -> 1.7.1-0
- ros-indigo-resized-image-transport: 1.0.1-0 -> 1.1.0-0
- ros-indigo-robot-model: 1.11.11-0 -> 1.11.12-0
- ros-indigo-robot-self-filter: 0.1.29-0 -> 0.1.30-1
- ros-indigo-robotino-msgs: 0.0.18-0 -> 0.0.24-0
- ros-indigo-romeo-bringup: 0.1.3-1 -> 0.1.5-0
- ros-indigo-romeo-description: 0.1.3-1 -> 0.1.5-0
- ros-indigo-romeo-robot: 0.1.3-1 -> 0.1.5-0
- ros-indigo-romeo-sensors-py: 0.1.3-1 -> 0.1.5-0
- ros-indigo-ros-type-introspection: 0.3.3-2 -> 0.4.3-0
- ros-indigo-rospatlite: 2.0.17-0 -> 2.0.19-0
- ros-indigo-rospeex: 2.15.0-0 -> 2.15.4-0
- ros-indigo-rospeex-audiomonitor: 2.15.0-0 -> 2.15.4-0
- ros-indigo-rospeex-core: 2.15.0-0 -> 2.15.4-0
- ros-indigo-rospeex-if: 2.15.0-0 -> 2.15.4-0
- ros-indigo-rospeex-launch: 2.15.0-0 -> 2.15.4-0
- ros-indigo-rospeex-msgs: 2.15.0-0 -> 2.15.4-0
- ros-indigo-rospeex-samples: 2.15.0-0 -> 2.15.4-0
- ros-indigo-rospeex-webaudiomonitor: 2.15.0-0 -> 2.15.4-0
- ros-indigo-rosping: 2.0.17-0 -> 2.0.19-0
- ros-indigo-rostwitter: 2.0.17-0 -> 2.0.19-0
- ros-indigo-rqt-action: 0.4.3-0 -> 0.4.5-0
- ros-indigo-rqt-bag: 0.4.3-0 -> 0.4.5-0
- ros-indigo-rqt-bag-plugins: 0.4.3-0 -> 0.4.5-0
- ros-indigo-rqt-common-plugins: 0.4.3-0 -> 0.4.5-0
- ros-indigo-rqt-console: 0.4.3-0 -> 0.4.5-0
- ros-indigo-rqt-dep: 0.4.3-0 -> 0.4.5-0
- ros-indigo-rqt-graph: 0.4.3-0 -> 0.4.5-0
- ros-indigo-rqt-image-view: 0.4.3-0 -> 0.4.5-0
- ros-indigo-rqt-launch: 0.4.3-0 -> 0.4.5-0
- ros-indigo-rqt-logger-level: 0.4.3-0 -> 0.4.5-0
- ros-indigo-rqt-moveit: 0.5.5-0 -> 0.5.6-0
- ros-indigo-rqt-msg: 0.4.3-0 -> 0.4.5-0
- ros-indigo-rqt-nav-view: 0.5.5-0 -> 0.5.6-0
- ros-indigo-rqt-plot: 0.4.3-0 -> 0.4.5-0
- ros-indigo-rqt-pose-view: 0.5.5-0 -> 0.5.6-0
- ros-indigo-rqt-publisher: 0.4.3-0 -> 0.4.5-0
- ros-indigo-rqt-py-common: 0.4.3-0 -> 0.4.5-0
- ros-indigo-rqt-py-console: 0.4.3-0 -> 0.4.5-0
- ros-indigo-rqt-reconfigure: 0.4.3-0 -> 0.4.5-0
- ros-indigo-rqt-robot-dashboard: 0.5.5-0 -> 0.5.6-0
- ros-indigo-rqt-robot-monitor: 0.5.5-0 -> 0.5.6-0
- ros-indigo-rqt-robot-plugins: 0.5.5-0 -> 0.5.6-0
- ros-indigo-rqt-robot-steering: 0.5.5-0 -> 0.5.6-0
- ros-indigo-rqt-runtime-monitor: 0.5.5-0 -> 0.5.6-0
- ros-indigo-rqt-rviz: 0.5.5-0 -> 0.5.6-0
- ros-indigo-rqt-service-caller: 0.4.3-0 -> 0.4.5-0
- ros-indigo-rqt-shell: 0.4.3-0 -> 0.4.5-0
- ros-indigo-rqt-srv: 0.4.3-0 -> 0.4.5-0
- ros-indigo-rqt-tf-tree: 0.5.5-0 -> 0.5.6-0
- ros-indigo-rqt-top: 0.4.3-0 -> 0.4.5-0
- ros-indigo-rqt-topic: 0.4.3-0 -> 0.4.5-0
- ros-indigo-rqt-web: 0.4.3-0 -> 0.4.5-0
- ros-indigo-rtmros-hironx: 1.1.18-0 -> 1.1.20-0
- ros-indigo-rtmros-nextage: 0.7.11-0 -> 0.7.14-0
- ros-indigo-sick-tim: 0.0.9-0 -> 0.0.10-0
- ros-indigo-slic: 2.0.17-0 -> 2.0.19-0
- ros-indigo-spacenav-node: 1.10.1-0 -> 1.11.0-1
- ros-indigo-squirrel-3d-mapping-msgs: 0.0.18-0 -> 0.0.24-0
- ros-indigo-squirrel-common: 0.0.18-0 -> 0.0.24-0
- ros-indigo-squirrel-hri-msgs: 0.0.18-0 -> 0.0.24-0
- ros-indigo-squirrel-kclhand-msgs: 0.0.18-0 -> 0.0.24-0
- ros-indigo-squirrel-localizer-msgs: 0.0.18-0 -> 0.0.24-0
- ros-indigo-squirrel-manipulation-msgs: 0.0.18-0 -> 0.0.24-0
- ros-indigo-squirrel-mhand-msgs: 0.0.18-0 -> 0.0.24-0
- ros-indigo-squirrel-navigation-msgs: 0.0.18-0 -> 0.0.24-0
- ros-indigo-squirrel-object-perception-msgs: 0.0.18-0 -> 0.0.24-0
- ros-indigo-squirrel-person-tracker-msgs: 0.0.18-0 -> 0.0.24-0
- ros-indigo-squirrel-planning-knowledge-msgs: 0.0.18-0 -> 0.0.24-0
- ros-indigo-squirrel-prediction-msgs: 0.0.18-0 -> 0.0.24-0
- ros-indigo-squirrel-rgbd-mapping-msgs: 0.0.18-0 -> 0.0.24-0
- ros-indigo-squirrel-sketch-interface-msgs: 0.0.18-0 -> 0.0.24-0
- ros-indigo-squirrel-speech-msgs: 0.0.18-0 -> 0.0.24-0
- ros-indigo-squirrel-waypoint-msgs: 0.0.18-0 -> 0.0.24-0
- ros-indigo-srdfdom: 0.3.3-0 -> 0.3.5-0
- ros-indigo-staro-moveit-config: 0.1.11-0 -> 0.1.12-0
- ros-indigo-stdr-gui: 0.3.1-0 -> 0.3.2-0
- ros-indigo-stdr-launchers: 0.3.1-0 -> 0.3.2-0
- ros-indigo-stdr-msgs: 0.3.1-0 -> 0.3.2-0
- ros-indigo-stdr-parser: 0.3.1-0 -> 0.3.2-0
- ros-indigo-stdr-resources: 0.3.1-0 -> 0.3.2-0
- ros-indigo-stdr-robot: 0.3.1-0 -> 0.3.2-0
- ros-indigo-stdr-samples: 0.3.1-0 -> 0.3.2-0
- ros-indigo-stdr-server: 0.3.1-0 -> 0.3.2-0
- ros-indigo-stdr-simulator: 0.3.1-0 -> 0.3.2-0
- ros-indigo-task-compiler: 0.1.7-0 -> 0.1.8-0
- ros-indigo-test-mavros: 0.17.4-0 -> 0.17.5-0
- ros-indigo-tf2: 0.5.13-0 -> 0.5.15-0
- ros-indigo-tf2-bullet: 0.5.13-0 -> 0.5.15-0
- ros-indigo-tf2-eigen: 0.5.13-0 -> 0.5.15-0
- ros-indigo-tf2-geometry-msgs: 0.5.13-0 -> 0.5.15-0
- ros-indigo-tf2-kdl: 0.5.13-0 -> 0.5.15-0
- ros-indigo-tf2-msgs: 0.5.13-0 -> 0.5.15-0
- ros-indigo-tf2-py: 0.5.13-0 -> 0.5.15-0
- ros-indigo-tf2-ros: 0.5.13-0 -> 0.5.15-0
- ros-indigo-tf2-sensor-msgs: 0.5.13-0 -> 0.5.15-0
- ros-indigo-tf2-tools: 0.5.13-0 -> 0.5.15-0
- ros-indigo-tornado: 4.2.1-1 -> 4.2.1-2
- ros-indigo-turtlebot-exploration-3d: 0.0.7-0 -> 0.0.9-0
- ros-indigo-um7: 0.0.3-0 -> 0.0.4-0
- ros-indigo-urdf: 1.11.11-0 -> 1.11.12-0
- ros-indigo-urdf-parser-plugin: 1.11.11-0 -> 1.11.12-0
- ros-indigo-urdfdom-py: 0.3.1-1 -> 0.3.3-1
- ros-indigo-virtual-force-publisher: 2.1.2-4 -> 2.2.2-1
- ros-indigo-vision-opencv: 1.11.14-0 -> 1.11.15-0
- ros-indigo-vision-visp: 0.9.1-0 -> 0.10.0-0
- ros-indigo-visp: 3.0.0-4 -> 3.0.1-1
- ros-indigo-visp-auto-tracker: 0.9.1-0 -> 0.10.0-0
- ros-indigo-visp-bridge: 0.9.1-0 -> 0.10.0-0
- ros-indigo-visp-camera-calibration: 0.9.1-0 -> 0.10.0-0
- ros-indigo-visp-hand2eye-calibration: 0.9.1-0 -> 0.10.0-0
- ros-indigo-visp-tracker: 0.9.1-0 -> 0.10.0-0
- ros-indigo-voice-text: 2.0.17-0 -> 2.0.19-0
- ros-indigo-web-video-server: 0.0.5-0 -> 0.0.6-0
- ros-indigo-wiimote: 1.10.1-0 -> 1.11.0-1
Removed Packages [4]:
- ros-indigo-jsk-control
- ros-indigo-pano-core
- ros-indigo-pano-py
- ros-indigo-pano-ros
- Aaron Blasdel
- AlexV
- Alexander Tiderko
- Andy Zelenak
- Antons Rebguns
- Austin Hendrix
- Ayush Dewan
- Bona
- Carl
- Carnegie Robotics
- Chris Lalancette
- Chris Zalidis
- Dan Lazewatsky
- Daniel Miller
- Daniel Stonier
- Dave Coleman
- David Kent
- David V. Lu!!
- Davide Faconti
- Devon Ash
- Dirk Thomas
- Dorian Scholz
- Doug Stephen
- Edith Langer
- Edmond DuPont
- Elliot Johnson
- Evangelos Emmanouil
- Fabien Spindler
- Federico Boniardi
- Felipe R. Fabresse (University of Seville)
- Florian Lier
- Florian Voigtländer
- Henning Deeken
- Hitoshi Kamada
- IK Fast Plugin Creater
- Ioan Sucan
- Isaac I. Y. Saito
- Isaac Saito
- Jack O’Quin
- Jackie Kay
- Jaebok Kim
- Jonathan Bohren
- Joseph Duchesne
- Juergen Hess
- Kei Okada
- Koji Terada
- Komei Sugiura
- Konstantin Schauwecker
- Maintained by Carnegie Robotics LLC
- Mani Monajjemi
- Marc Alban
- Markus Bajones
- Martin Guenther
- Martin Günther
- Mathias Lüdtke
- Michael Ferguson
- Michael Zillich
- MoveIt Setup Assistant
- Nadia Hammoudeh Garcia
- Natalia Lyubova
- Noda Shintaro
- Paul Bovbel
- Peter Regier
- Philipp Zech
- Procopio Stein
- Péter Fankhauser
- Rajvi Jingar
- Robert Krug
- Russell Toris
- Ryohei Ueda
- Sachin Chitta
- Scott K Logan
- Scott Niekum
- Senka Krivic
- Sergey Dorodnicov
- Siddhartha Banerjee
- Simon Hangl
- Surya Ambrose
- TORK
- Takuya Nakaoka
- Todor Stoyanov
- Tully Foote
- Vincent Rabaud
- Vincent Rousseau
- Vladimir Ermakov
- Yohei Kakiuchi
- YoheiKakiuchi
- Youhei Kakiuchi
- Yuki Furuta
- Yusuke Furuta
- Yuto Inagaki
- furuta
- k-okada
- michael
- nozawa
- smoker77
- youssef
