We’re happy to announce 32 new packages and 58 updated packages for Indigo Igloo. Full details are below.
Thank you to everyone who has helped make these packages available. Your efforts are greatly appreciated.
Package Updates for indigo
Added Packages [32]:
- ros-indigo-behaviortree-cpp: 2.4.1-0
- ros-indigo-costmap-queue: 0.2.2-0
- ros-indigo-dataspeed-ulc: 0.0.3-0
- ros-indigo-dataspeed-ulc-can: 0.0.3-0
- ros-indigo-dataspeed-ulc-msgs: 0.0.3-0
- ros-indigo-dlux-global-planner: 0.2.2-0
- ros-indigo-dlux-plugins: 0.2.2-0
- ros-indigo-dwb-critics: 0.2.2-0
- ros-indigo-dwb-local-planner: 0.2.2-0
- ros-indigo-dwb-msgs: 0.2.2-0
- ros-indigo-dwb-plugins: 0.2.2-0
- ros-indigo-flexbe-behavior-engine: 1.1.0-0
- ros-indigo-flexbe-core: 1.1.0-0
- ros-indigo-flexbe-input: 1.1.0-0
- ros-indigo-flexbe-mirror: 1.1.0-0
- ros-indigo-flexbe-msgs: 1.1.0-0
- ros-indigo-flexbe-onboard: 1.1.0-0
- ros-indigo-flexbe-states: 1.1.0-0
- ros-indigo-flexbe-testing: 1.1.0-0
- ros-indigo-flexbe-widget: 1.1.0-0
- ros-indigo-global-planner-tests: 0.2.2-0
- ros-indigo-locomotor: 0.2.2-0
- ros-indigo-locomotor-msgs: 0.2.2-0
- ros-indigo-locomove-base: 0.2.2-0
- ros-indigo-nav-2d-msgs: 0.2.2-0
- ros-indigo-nav-2d-utils: 0.2.2-0
- ros-indigo-nav-core-adapter: 0.2.2-0
- ros-indigo-nav-core2: 0.2.2-0
- ros-indigo-nav-grid: 0.2.2-0
- ros-indigo-nav-grid-iterators: 0.2.2-0
- ros-indigo-nav-grid-pub-sub: 0.2.2-0
- ros-indigo-robot-navigation: 0.2.2-0
Updated Packages [58]:
- ros-indigo-astuff-sensor-msgs: 2.3.0-0 -> 2.3.1-0
- ros-indigo-automotive-autonomy-msgs: 2.0.2-0 -> 2.0.3-0
- ros-indigo-automotive-navigation-msgs: 2.0.2-0 -> 2.0.3-0
- ros-indigo-automotive-platform-msgs: 2.0.2-0 -> 2.0.3-0
- ros-indigo-dbw-fca: 0.0.2-0 -> 1.0.0-0
- ros-indigo-dbw-fca-can: 0.0.2-0 -> 1.0.0-0
- ros-indigo-dbw-fca-description: 0.0.2-0 -> 1.0.0-0
- ros-indigo-dbw-fca-joystick-demo: 0.0.2-0 -> 1.0.0-0
- ros-indigo-dbw-fca-msgs: 0.0.2-0 -> 1.0.0-0
- ros-indigo-dbw-mkz: 1.0.17-0 -> 1.1.0-0
- ros-indigo-dbw-mkz-can: 1.0.17-0 -> 1.1.0-0
- ros-indigo-dbw-mkz-description: 1.0.17-0 -> 1.1.0-0
- ros-indigo-dbw-mkz-joystick-demo: 1.0.17-0 -> 1.1.0-0
- ros-indigo-dbw-mkz-msgs: 1.0.17-0 -> 1.1.0-0
- ros-indigo-dbw-mkz-twist-controller: 1.0.17-0 -> 1.1.0-0
- ros-indigo-default-cfg-fkie: 0.8.2-0 -> 0.8.4-0
- ros-indigo-delphi-esr-msgs: 2.3.0-0 -> 2.3.1-0
- ros-indigo-delphi-mrr-msgs: 2.3.0-0 -> 2.3.1-0
- ros-indigo-delphi-srr-msgs: 2.3.0-0 -> 2.3.1-0
- ros-indigo-derived-object-msgs: 2.3.0-0 -> 2.3.1-0
- ros-indigo-ibeo-core: 2.0.1-0 -> 2.0.2-0
- ros-indigo-ibeo-lux: 2.0.0-0 -> 2.0.1-0
- ros-indigo-ibeo-msgs: 2.3.0-0 -> 2.3.1-0
- ros-indigo-kartech-linear-actuator-msgs: 2.3.0-0 -> 2.3.1-0
- ros-indigo-marti-data-structures: 2.6.0-0 -> 2.7.0-0
- ros-indigo-master-discovery-fkie: 0.8.2-0 -> 0.8.4-0
- ros-indigo-master-sync-fkie: 0.8.2-0 -> 0.8.4-0
- ros-indigo-mobileye-560-660-msgs: 2.3.0-0 -> 2.3.1-0
- ros-indigo-multimaster-fkie: 0.8.2-0 -> 0.8.4-0
- ros-indigo-multimaster-msgs-fkie: 0.8.2-0 -> 0.8.4-0
- ros-indigo-neobotix-usboard-msgs: 2.3.0-0 -> 2.3.1-0
- ros-indigo-node-manager-fkie: 0.8.2-0 -> 0.8.4-0
- ros-indigo-openni2-camera: 0.4.1-0 -> 0.4.2-0
- ros-indigo-openni2-launch: 0.4.1-0 -> 0.4.2-0
- ros-indigo-pacmod-msgs: 2.3.0-0 -> 2.3.1-0
- ros-indigo-pacmod3: 1.2.0-0 -> 1.2.1-0
- ros-indigo-radar-msgs: 2.3.0-0 -> 2.3.1-0
- ros-indigo-swri-console-util: 2.6.0-0 -> 2.7.0-0
- ros-indigo-swri-dbw-interface: 2.6.0-0 -> 2.7.0-0
- ros-indigo-swri-geometry-util: 2.6.0-0 -> 2.7.0-0
- ros-indigo-swri-image-util: 2.6.0-0 -> 2.7.0-0
- ros-indigo-swri-math-util: 2.6.0-0 -> 2.7.0-0
- ros-indigo-swri-nodelet: 2.6.0-0 -> 2.7.0-0
- ros-indigo-swri-opencv-util: 2.6.0-0 -> 2.7.0-0
- ros-indigo-swri-prefix-tools: 2.6.0-0 -> 2.7.0-0
- ros-indigo-swri-roscpp: 2.6.0-0 -> 2.7.0-0
- ros-indigo-swri-rospy: 2.6.0-0 -> 2.7.0-0
- ros-indigo-swri-route-util: 2.6.0-0 -> 2.7.0-0
- ros-indigo-swri-serial-util: 2.6.0-0 -> 2.7.0-0
- ros-indigo-swri-string-util: 2.6.0-0 -> 2.7.0-0
- ros-indigo-swri-system-util: 2.6.0-0 -> 2.7.0-0
- ros-indigo-swri-transform-util: 2.6.0-0 -> 2.7.0-0
- ros-indigo-swri-yaml-util: 2.6.0-0 -> 2.7.0-0
- ros-indigo-velodyne: 1.5.0-0 -> 1.5.1-0
- ros-indigo-velodyne-driver: 1.5.0-0 -> 1.5.1-0
- ros-indigo-velodyne-laserscan: 1.5.0-0 -> 1.5.1-0
- ros-indigo-velodyne-msgs: 1.5.0-0 -> 1.5.1-0
- ros-indigo-velodyne-pointcloud: 1.5.0-0 -> 1.5.1-0
Removed Packages [0]:
- Alexander Tiderko
- AutonomouStuff Software Team
- David V. Lu!!
- Isaac I. Y. Saito
- Josh Whitley
- Kevin Hallenbeck
- Kris Kozak
- Marc Alban
- Michael Ferguson
- Michele Colledanchise
- Micho Radovnikovich
- P. J. Reed
- Philipp Schillinger
