We’re happy to announce 9 new packages and 29 updated packages for Indigo. Full details are below. Thank you to all the maintainers and contributors who help make this possible.
Package Updates for indigo
Added Packages [9]:
- ros-indigo-alfred-bot: 0.1.121-0
- ros-indigo-neonavigation-rviz-plugins: 0.3.0-0
- ros-indigo-rosjava-dynamic-reconfigure: 0.2.4-0
- ros-indigo-sick-safetyscanners: 1.0.2-0
- ros-indigo-smarthome-common-driver: 0.1.61-0
- ros-indigo-smarthome-media-kodi-driver: 0.1.57-0
- ros-indigo-smarthome-media-onkyo-driver: 0.1.64-0
- ros-indigo-smarthome-media-samsungtv-driver: 0.1.58-0
- ros-indigo-trajectory-tracker-rviz-plugins: 0.3.0-0
Updated Packages [29]:
- ros-indigo-assisted-teleop: 0.2.0-0 -> 0.2.1-0
- ros-indigo-behaviortree-cpp: 2.4.4-0 -> 2.5.1-0
- ros-indigo-costmap-cspace: 0.2.3-0 -> 0.3.1-0
- ros-indigo-costmap-cspace-msgs: 0.3.0-0 -> 0.3.1-0
- ros-indigo-goal-passer: 0.2.0-0 -> 0.2.1-0
- ros-indigo-joystick-interrupt: 0.2.3-0 -> 0.3.1-0
- ros-indigo-jskeus: 1.2.0-2 -> 1.2.1-0
- ros-indigo-map-organizer: 0.2.3-0 -> 0.3.1-0
- ros-indigo-map-organizer-msgs: 0.3.0-0 -> 0.3.1-0
- ros-indigo-navigation-experimental: 0.2.0-0 -> 0.2.1-0
- ros-indigo-neonavigation: 0.2.3-0 -> 0.3.1-0
- ros-indigo-neonavigation-common: 0.2.3-0 -> 0.3.1-0
- ros-indigo-neonavigation-launch: 0.2.3-0 -> 0.3.1-0
- ros-indigo-neonavigation-msgs: 0.3.0-0 -> 0.3.1-0
- ros-indigo-obj-to-pointcloud: 0.2.3-0 -> 0.3.1-0
- ros-indigo-planner-cspace: 0.2.3-0 -> 0.3.1-0
- ros-indigo-planner-cspace-msgs: 0.3.0-0 -> 0.3.1-0
- ros-indigo-pose-base-controller: 0.2.0-0 -> 0.2.1-0
- ros-indigo-pose-follower: 0.2.0-0 -> 0.2.1-0
- ros-indigo-rospy-message-converter: 0.4.0-0 -> 0.5.0-0
- ros-indigo-safety-limiter: 0.2.3-0 -> 0.3.1-0
- ros-indigo-sbpl-lattice-planner: 0.2.0-0 -> 0.2.1-0
- ros-indigo-sbpl-recovery: 0.2.0-0 -> 0.2.1-0
- ros-indigo-sick-tim: 0.0.13-0 -> 0.0.14-0
- ros-indigo-track-odometry: 0.2.3-0 -> 0.3.1-0
- ros-indigo-trajectory-tracker: 0.2.3-0 -> 0.3.1-0
- ros-indigo-trajectory-tracker-msgs: 0.3.0-0 -> 0.3.1-0
- ros-indigo-twist-recovery: 0.2.0-0 -> 0.2.1-0
- ros-indigo-ypspur: 1.15.2-0 -> 1.15.3-0
Removed Packages [0]:
- Atsushi Watanabe
- Kei Okada
- Lennart Puck
- Martin Günther
- Michele Colledanchise
- Mickaël Gaillard
