We have another batch of packages for both Indigo and Jade. Jade has just over 100 new or updated packages and Indigo has closer to 200 new or updated packages.
New packages for Kinetic are under testing. (See this thread for more info.)
Thanks as always to all the contributors who make this possible. Details of the updated packages are listed below as well as the primary maintainers for each of the packages.
#Updates to indigo
Added Packages [42]:
- ros-indigo-ackermann-controller: 0.1.2-0
- ros-indigo-aubo-description: 0.1.1-3
- ros-indigo-aubo-gazebo: 0.1.1-3
- ros-indigo-aubo-i5-moveit-config: 0.1.1-3
- ros-indigo-aubo-kinematics: 0.1.1-3
- ros-indigo-aubo-msgs: 0.1.1-3
- ros-indigo-ddynamic-reconfigure-python: 0.0.1-0
- ros-indigo-fetch-arm-control: 0.0.5-0
- ros-indigo-fetch-social-gaze: 0.0.5-0
- ros-indigo-footstep-planner: 0.4.1-2
- ros-indigo-gridmap-2d: 0.4.1-2
- ros-indigo-hey5-description: 1.0.1-0
- ros-indigo-humanoid-localization: 0.4.1-2
- ros-indigo-humanoid-navigation: 0.4.1-2
- ros-indigo-humanoid-planner-2d: 0.4.1-2
- ros-indigo-naoqi-dcm-driver: 0.0.2-0
- ros-indigo-pal-behaviour-msgs: 0.11.3-0
- ros-indigo-pal-common-msgs: 0.11.3-0
- ros-indigo-pal-control-msgs: 0.11.3-0
- ros-indigo-pal-detection-msgs: 0.11.3-0
- ros-indigo-pal-device-msgs: 0.11.3-0
- ros-indigo-pal-interaction-msgs: 0.11.3-0
- ros-indigo-pal-motion-model-msgs: 0.11.3-0
- ros-indigo-pal-msgs: 0.11.3-0
- ros-indigo-pal-multirobot-msgs: 0.11.3-0
- ros-indigo-pal-navigation-msgs: 0.11.3-0
- ros-indigo-pal-tablet-msgs: 0.11.3-0
- ros-indigo-pal-video-recording-msgs: 0.11.3-0
- ros-indigo-pal-vision-msgs: 0.11.3-0
- ros-indigo-pal-visual-localization-msgs: 0.11.3-0
- ros-indigo-pal-walking-msgs: 0.11.3-0
- ros-indigo-pal-web-msgs: 0.11.3-0
- ros-indigo-pal-wifi-localization-msgs: 0.11.3-0
- ros-indigo-pepper-dcm-bringup: 0.0.1-1
- ros-indigo-pepperl-fuchs-r2000: 0.1.3-0
- ros-indigo-rqt-wrapper: 0.1.3-0
- ros-indigo-summit-x-sim-bringup: 1.0.8-0
- ros-indigo-tty0tty: 1.2.0-0
- ros-indigo-waypoint-generator: 0.0.1-0
- ros-indigo-waypoint-meta: 0.0.1-0
- ros-indigo-waypoint-touring: 0.0.1-0
- ros-indigo-webtest: 2.0.18-0
Updated Packages [141]:
- ros-indigo-bwi-common: 0.3.10-0 -> 0.3.12-0
- ros-indigo-bwi-gazebo-entities: 0.3.10-0 -> 0.3.12-0
- ros-indigo-bwi-interruptable-action-server: 0.3.10-0 -> 0.3.12-0
- ros-indigo-bwi-joystick-teleop: 0.3.10-0 -> 0.3.12-0
- ros-indigo-bwi-kr-execution: 0.3.10-0 -> 0.3.12-0
- ros-indigo-bwi-logging: 0.3.10-0 -> 0.3.12-0
- ros-indigo-bwi-mapper: 0.3.10-0 -> 0.3.12-0
- ros-indigo-bwi-msgs: 0.3.10-0 -> 0.3.12-0
- ros-indigo-bwi-planning-common: 0.3.10-0 -> 0.3.12-0
- ros-indigo-bwi-rqt-plugins: 0.3.10-0 -> 0.3.12-0
- ros-indigo-bwi-scavenger: 0.3.10-0 -> 0.3.12-0
- ros-indigo-bwi-services: 0.3.10-0 -> 0.3.12-0
- ros-indigo-bwi-tasks: 0.3.10-0 -> 0.3.12-0
- ros-indigo-bwi-tools: 0.3.10-0 -> 0.3.12-0
- ros-indigo-bwi-virtour: 0.3.10-0 -> 0.3.12-0
- ros-indigo-catkin-pip: 0.1.11-0 -> 0.1.16-0
- ros-indigo-checkerboard-detector: 0.3.21-0 -> 0.3.25-0
- ros-indigo-default-cfg-fkie: 0.5.4-0 -> 0.5.8-0
- ros-indigo-dynamic-tf-publisher: 2.0.17-0 -> 2.1.2-4
- ros-indigo-dynpick-driver: 0.0.11-0 -> 0.1.0-0
- ros-indigo-eusgazebo: 0.1.10-0 -> 0.1.11-0
- ros-indigo-euslisp: 9.20.0-0 -> 9.21.0-1
- ros-indigo-hokuyo3d: 0.1.0-0 -> 0.1.1-1
- ros-indigo-hrpsys: 315.9.0-0 -> 315.10.0-0
- ros-indigo-hrpsys-gazebo-general: 0.1.10-0 -> 0.1.11-0
- ros-indigo-hrpsys-gazebo-msgs: 0.1.10-0 -> 0.1.11-0
- ros-indigo-image-view2: 2.0.17-0 -> 2.1.2-4
- ros-indigo-imagesift: 0.3.21-0 -> 0.3.25-0
- ros-indigo-imu-complementary-filter: 1.0.10-0 -> 1.0.13-0
- ros-indigo-imu-filter-madgwick: 1.0.10-0 -> 1.0.13-0
- ros-indigo-imu-tools: 1.0.10-0 -> 1.0.13-0
- ros-indigo-interactive-markers: 1.11.1-0 -> 1.11.3-0
- ros-indigo-jsk-apc2016-common: 0.8.1-0 -> 1.5.1-0
- ros-indigo-jsk-common: 2.0.17-0 -> 2.1.2-4
- ros-indigo-jsk-common-msgs: 3.0.0-0 -> 4.0.0-0
- ros-indigo-jsk-data: 2.0.17-0 -> 2.1.2-4
- ros-indigo-jsk-footstep-msgs: 3.0.0-0 -> 4.0.0-0
- ros-indigo-jsk-gui-msgs: 3.0.0-0 -> 4.0.0-0
- ros-indigo-jsk-hark-msgs: 3.0.0-0 -> 4.0.0-0
- ros-indigo-jsk-interactive: 1.0.32-0 -> 1.0.33-0
- ros-indigo-jsk-interactive-marker: 1.0.32-0 -> 1.0.33-0
- ros-indigo-jsk-interactive-test: 1.0.32-0 -> 1.0.33-0
- ros-indigo-jsk-network-tools: 2.0.17-0 -> 2.1.2-4
- ros-indigo-jsk-pcl-ros: 0.3.21-0 -> 0.3.25-0
- ros-indigo-jsk-pcl-ros-utils: 0.3.21-0 -> 0.3.25-0
- ros-indigo-jsk-perception: 0.3.21-0 -> 0.3.25-0
- ros-indigo-jsk-pr2eus: 0.3.4-0 -> 0.3.5-0
- ros-indigo-jsk-recognition: 0.3.21-0 -> 0.3.25-0
- ros-indigo-jsk-recognition-msgs: 0.3.21-0 -> 0.3.25-0
- ros-indigo-jsk-recognition-utils: 0.3.21-0 -> 0.3.25-0
- ros-indigo-jsk-rqt-plugins: 1.0.32-0 -> 1.0.33-0
- ros-indigo-jsk-rviz-plugins: 1.0.32-0 -> 1.0.33-0
- ros-indigo-jsk-tilt-laser: 2.0.17-0 -> 2.1.2-4
- ros-indigo-jsk-tools: 2.0.17-0 -> 2.1.2-4
- ros-indigo-jsk-topic-tools: 2.0.17-0 -> 2.1.2-4
- ros-indigo-jsk-visualization: 1.0.32-0 -> 1.0.33-0
- ros-indigo-marshmallow: 2.9.1-4 -> 2.9.1-5
- ros-indigo-master-discovery-fkie: 0.5.4-0 -> 0.5.8-0
- ros-indigo-master-sync-fkie: 0.5.4-0 -> 0.5.8-0
- ros-indigo-micros-swarm-framework: 0.0.13-0 -> 0.0.14-0
- ros-indigo-moveit-resources: 0.6.0-0 -> 0.6.1-0
- ros-indigo-mrpt-bridge: 0.1.11-0 -> 0.1.14-0
- ros-indigo-mrpt-local-obstacles: 0.1.11-0 -> 0.1.14-0
- ros-indigo-mrpt-localization: 0.1.11-0 -> 0.1.14-0
- ros-indigo-mrpt-map: 0.1.11-0 -> 0.1.14-0
- ros-indigo-mrpt-msgs: 0.1.11-0 -> 0.1.14-0
- ros-indigo-mrpt-navigation: 0.1.11-0 -> 0.1.14-0
- ros-indigo-mrpt-rawlog: 0.1.11-0 -> 0.1.14-0
- ros-indigo-mrpt-reactivenav2d: 0.1.11-0 -> 0.1.14-0
- ros-indigo-mrpt-tutorials: 0.1.11-0 -> 0.1.14-0
- ros-indigo-multi-level-map-msgs: 0.3.10-0 -> 0.3.12-0
- ros-indigo-multi-level-map-server: 0.3.10-0 -> 0.3.12-0
- ros-indigo-multi-level-map-utils: 0.3.10-0 -> 0.3.12-0
- ros-indigo-multi-map-server: 2.0.17-0 -> 2.1.2-4
- ros-indigo-multimaster-fkie: 0.5.4-0 -> 0.5.8-0
- ros-indigo-multimaster-msgs-fkie: 0.5.4-0 -> 0.5.8-0
- ros-indigo-nao-moveit-config: 0.0.9-0 -> 0.0.10-0
- ros-indigo-naoqi-apps: 0.5.3-0 -> 0.5.5-0
- ros-indigo-naoqi-bridge: 0.5.3-0 -> 0.5.5-0
- ros-indigo-naoqi-driver-py: 0.5.3-0 -> 0.5.5-0
- ros-indigo-naoqi-pose: 0.5.3-0 -> 0.5.5-0
- ros-indigo-naoqi-sensors-py: 0.5.3-0 -> 0.5.5-0
- ros-indigo-naoqi-tools: 0.5.3-0 -> 0.5.5-0
- ros-indigo-node-manager-fkie: 0.5.4-0 -> 0.5.8-0
- ros-indigo-ocl: 2.8.3-0 -> 2.8.3-1
- ros-indigo-opencv-apps: 1.11.13-0 -> 1.11.14-0
- ros-indigo-openrtm-aist-python: 1.1.0-6 -> 1.1.0-7
- ros-indigo-pepper-control: 0.0.2-3 -> 0.0.3-0
- ros-indigo-pepper-gazebo-plugin: 0.0.2-3 -> 0.0.3-0
- ros-indigo-pepper-moveit-config: 0.0.4-1 -> 0.0.6-0
- ros-indigo-phantomx-reactor-arm: 0.1.3-0 -> 0.1.4-0
- ros-indigo-phantomx-reactor-arm-controller: 0.1.3-0 -> 0.1.4-0
- ros-indigo-phantomx-reactor-arm-description: 0.1.3-0 -> 0.1.4-0
- ros-indigo-posedetection-msgs: 3.0.0-0 -> 4.0.0-0
- ros-indigo-pr2eus: 0.3.4-0 -> 0.3.5-0
- ros-indigo-pr2eus-moveit: 0.3.4-0 -> 0.3.5-0
- ros-indigo-pr2eus-tutorials: 0.3.4-0 -> 0.3.5-0
- ros-indigo-pyros-config: 0.1.3-1 -> 0.1.5-0
- ros-indigo-rail-segmentation: 0.1.9-0 -> 0.1.10-0
- ros-indigo-rb1-base-common: 1.0.3-0 -> 1.0.6-0
- ros-indigo-rb1-base-description: 1.0.3-0 -> 1.0.6-0
- ros-indigo-rb1-base-pad: 1.0.3-0 -> 1.0.6-0
- ros-indigo-realsense-camera: 1.3.0-0 -> 1.4.0-0
- ros-indigo-resized-image-transport: 0.3.21-0 -> 0.3.25-0
- ros-indigo-rgbd-launch: 2.1.2-0 -> 2.1.3-0
- ros-indigo-robotnik-sensors: 1.0.1-0 -> 1.0.3-0
- ros-indigo-rtt: 2.8.3-0 -> 2.8.3-2
- ros-indigo-rviz-imu-plugin: 1.0.10-0 -> 1.0.13-0
- ros-indigo-segbot: 0.3.4-0 -> 0.3.5-0
- ros-indigo-segbot-bringup: 0.3.4-0 -> 0.3.5-0
- ros-indigo-segbot-description: 0.3.4-0 -> 0.3.5-0
- ros-indigo-segbot-firmware: 0.3.4-0 -> 0.3.5-0
- ros-indigo-segbot-gazebo: 0.3.4-0 -> 0.3.5-0
- ros-indigo-segbot-gui: 0.3.4-0 -> 0.3.5-0
- ros-indigo-segbot-led: 0.3.4-0 -> 0.3.5-0
- ros-indigo-segbot-logical-translator: 0.3.4-0 -> 0.3.5-0
- ros-indigo-segbot-navigation: 0.3.4-0 -> 0.3.5-0
- ros-indigo-segbot-sensors: 0.3.4-0 -> 0.3.5-0
- ros-indigo-segbot-simulation-apps: 0.3.4-0 -> 0.3.5-0
- ros-indigo-sick-tim: 0.0.8-0 -> 0.0.9-0
- ros-indigo-sophus-ros-conversions: 0.1.1-0 -> 0.1.3-0
- ros-indigo-speech-recognition-msgs: 3.0.0-0 -> 4.0.0-0
- ros-indigo-srdfdom: 0.3.1-0 -> 0.3.3-0
- ros-indigo-staro-moveit-config: 0.1.10-0 -> 0.1.11-0
- ros-indigo-stop-base: 0.3.10-0 -> 0.3.12-0
- ros-indigo-summit-x-control: 1.0.7-0 -> 1.0.8-0
- ros-indigo-summit-x-gazebo: 1.0.7-0 -> 1.0.8-0
- ros-indigo-summit-x-robot-control: 1.0.7-0 -> 1.0.8-0
- ros-indigo-summit-x-sim: 1.0.7-0 -> 1.0.8-0
- ros-indigo-summit-xl-common: 1.0.9-0 -> 1.0.10-0
- ros-indigo-summit-xl-description: 1.0.9-0 -> 1.0.10-0
- ros-indigo-summit-xl-localization: 1.0.9-0 -> 1.0.10-0
- ros-indigo-summit-xl-navigation: 1.0.9-0 -> 1.0.10-0
- ros-indigo-summit-xl-pad: 1.0.9-0 -> 1.0.10-0
- ros-indigo-teleop-twist-joy: 0.1.1-0 -> 0.1.2-0
- ros-indigo-ubiquity-motor: 0.4.1-0 -> 0.5.0-0
- ros-indigo-ueye-cam: 1.0.14-1 -> 1.0.15-0
- ros-indigo-utexas-gdc: 0.3.10-0 -> 0.3.12-0
- ros-indigo-virtual-force-publisher: 2.0.17-0 -> 2.1.2-4
- ros-indigo-visp: 3.0.0-3 -> 3.0.0-4
- ros-indigo-wts-driver: 1.0.2-0 -> 1.0.4-0
Removed Packages [0]:
Maintainers
- Adolfo Rodriguez Tsouroukdissian
- Alex Gonzales
- AlexV
- Alexander Tiderko
- Anqi Xu
- Armin Hornung
- Atsushi Watanabe
- Benjamin Singer
- Carlos Villar
- Chittaranjan Srinivas Swaminathan
- Daniel Stonier
- Dave Coleman
- Denis Dillenberger
- Elena Gambaro
- Fabien Spindler
- Hilario Tome
- Jack O’Quin
- Jeremie Deray
- Jihoon Lee
- Jordi Adell
- Jordi Pages
- Jose-Luis Blanco-Claraco
- KazutoMurase
- Kei Okada
- Kentaro Wada
- Liuxin
- Luca Marchionni
- Markus Bader
- Martin Günther
- Mikael Arguedas
- Mike Purvis
- MoveIt Setup Assistant
- Natalia Lyubova
- Orocos Developers
- Pato Lankenau
- Paul Mathieu
- Piyush Khandelwal
- Rajvi Jingar
- Roberto G. Valenti
- Roberto Guzmán
- Rohan Agrawal
- Román Navarro
- Russell Toris
- Ryohei Ueda
- Sam Pfeiffer
- Sarah Elliott
- Sergio Ramos
- Severin Lemaignan
- Shohei Fujii
- Surya Ambrose
- Séverin Lemaignan
- TORK
- Victor Lopez
- Vincent Rousseau
- Víctor López
- William Woodall
- Xuefeng Chang
- Yohei Kakiuchi
- YoheiKakiuchi
- Youhei Kakiuchi
- Yuki Furuta
- Yusuke Furuta
- furuta
- liuxin
Updates to jade
Added Packages [18]:
- ros-jade-hokuyo3d: 0.1.1-1
- ros-jade-jsk-interactive: 1.0.33-0
- ros-jade-jsk-interactive-marker: 1.0.33-0
- ros-jade-jsk-interactive-test: 1.0.33-0
- ros-jade-jsk-rqt-plugins: 1.0.33-0
- ros-jade-jsk-rviz-plugins: 1.0.33-0
- ros-jade-jsk-visualization: 1.0.33-0
- ros-jade-marshmallow: 2.9.1-2
- ros-jade-naoqi-dcm-driver: 0.0.2-0
- ros-jade-pepper-control: 0.0.3-0
- ros-jade-pepper-dcm-bringup: 0.0.1-0
- ros-jade-pepper-gazebo-plugin: 0.0.3-0
- ros-jade-pepperl-fuchs-r2000: 0.1.3-0
- ros-jade-romeo-control: 0.2.2-0
- ros-jade-romeo-gazebo-plugin: 0.2.2-0
- ros-jade-view-controller-msgs: 0.1.2-0
- ros-jade-webtest: 2.0.18-0
- ros-jade-wts-driver: 1.0.4-0
Updated Packages [83]:
- ros-jade-catkin-pip: 0.1.11-0 -> 0.1.16-0
- ros-jade-checkerboard-detector: 0.3.21-0 -> 0.3.25-0
- ros-jade-default-cfg-fkie: 0.5.4-0 -> 0.5.8-0
- ros-jade-dynamic-tf-publisher: 2.0.17-0 -> 2.1.2-1
- ros-jade-dynpick-driver: 0.0.11-0 -> 0.1.0-0
- ros-jade-euslisp: 9.20.0-0 -> 9.21.0-0
- ros-jade-hrpsys: 315.9.0-0 -> 315.10.0-0
- ros-jade-image-view2: 2.0.17-0 -> 2.1.2-1
- ros-jade-imagesift: 0.3.21-0 -> 0.3.25-0
- ros-jade-imu-complementary-filter: 1.1.0-0 -> 1.1.2-0
- ros-jade-imu-filter-madgwick: 1.1.0-0 -> 1.1.2-0
- ros-jade-imu-tools: 1.1.0-0 -> 1.1.2-0
- ros-jade-interactive-markers: 1.11.1-0 -> 1.11.3-0
- ros-jade-jsk-common: 2.0.17-0 -> 2.1.2-1
- ros-jade-jsk-common-msgs: 3.0.0-0 -> 4.0.0-0
- ros-jade-jsk-data: 2.0.17-0 -> 2.1.2-1
- ros-jade-jsk-footstep-msgs: 3.0.0-0 -> 4.0.0-0
- ros-jade-jsk-gui-msgs: 3.0.0-0 -> 4.0.0-0
- ros-jade-jsk-hark-msgs: 3.0.0-0 -> 4.0.0-0
- ros-jade-jsk-network-tools: 2.0.17-0 -> 2.1.2-1
- ros-jade-jsk-pcl-ros: 0.3.21-0 -> 0.3.25-0
- ros-jade-jsk-pcl-ros-utils: 0.3.21-0 -> 0.3.25-0
- ros-jade-jsk-perception: 0.3.21-0 -> 0.3.25-0
- ros-jade-jsk-pr2eus: 0.3.4-0 -> 0.3.5-0
- ros-jade-jsk-recognition: 0.3.21-0 -> 0.3.25-0
- ros-jade-jsk-recognition-msgs: 0.3.21-0 -> 0.3.25-0
- ros-jade-jsk-recognition-utils: 0.3.21-0 -> 0.3.25-0
- ros-jade-jsk-tilt-laser: 2.0.17-0 -> 2.1.2-1
- ros-jade-jsk-tools: 2.0.17-0 -> 2.1.2-1
- ros-jade-jsk-topic-tools: 2.0.17-0 -> 2.1.2-1
- ros-jade-master-discovery-fkie: 0.5.4-0 -> 0.5.8-0
- ros-jade-master-sync-fkie: 0.5.4-0 -> 0.5.8-0
- ros-jade-moveit-resources: 0.5.0-0 -> 0.6.1-0
- ros-jade-mrpt-bridge: 0.1.11-0 -> 0.1.13-0
- ros-jade-mrpt-local-obstacles: 0.1.11-0 -> 0.1.13-0
- ros-jade-mrpt-localization: 0.1.11-0 -> 0.1.13-0
- ros-jade-mrpt-map: 0.1.11-0 -> 0.1.13-0
- ros-jade-mrpt-msgs: 0.1.11-0 -> 0.1.13-0
- ros-jade-mrpt-navigation: 0.1.11-0 -> 0.1.13-0
- ros-jade-mrpt-rawlog: 0.1.11-0 -> 0.1.13-0
- ros-jade-mrpt-reactivenav2d: 0.1.11-0 -> 0.1.13-0
- ros-jade-mrpt-tutorials: 0.1.11-0 -> 0.1.13-0
- ros-jade-multi-map-server: 2.0.17-0 -> 2.1.2-1
- ros-jade-multimaster-fkie: 0.5.4-0 -> 0.5.8-0
- ros-jade-multimaster-msgs-fkie: 0.5.4-0 -> 0.5.8-0
- ros-jade-nao-moveit-config: 0.0.9-0 -> 0.0.10-0
- ros-jade-naoqi-apps: 0.5.3-0 -> 0.5.5-0
- ros-jade-naoqi-bridge: 0.5.3-0 -> 0.5.5-0
- ros-jade-naoqi-driver-py: 0.5.3-0 -> 0.5.5-0
- ros-jade-naoqi-pose: 0.5.3-0 -> 0.5.5-0
- ros-jade-naoqi-sensors-py: 0.5.3-0 -> 0.5.5-0
- ros-jade-naoqi-tools: 0.5.3-0 -> 0.5.5-0
- ros-jade-node-manager-fkie: 0.5.4-0 -> 0.5.8-0
- ros-jade-ocl: 2.8.3-0 -> 2.8.3-1
- ros-jade-opencv-apps: 1.11.13-0 -> 1.11.14-0
- ros-jade-pepper-moveit-config: 0.0.5-0 -> 0.0.6-0
- ros-jade-posedetection-msgs: 3.0.0-0 -> 4.0.0-0
- ros-jade-pr2eus: 0.3.4-0 -> 0.3.5-0
- ros-jade-pr2eus-moveit: 0.3.4-0 -> 0.3.5-0
- ros-jade-pr2eus-tutorials: 0.3.4-0 -> 0.3.5-0
- ros-jade-pyros-config: 0.1.2-0 -> 0.1.5-0
- ros-jade-rail-segmentation: 0.1.9-0 -> 0.1.10-1
- ros-jade-resized-image-transport: 0.3.21-0 -> 0.3.25-0
- ros-jade-rgbd-launch: 2.2.1-0 -> 2.2.2-0
- ros-jade-rosserial: 0.7.3-0 -> 0.7.4-0
- ros-jade-rosserial-arduino: 0.7.3-0 -> 0.7.4-0
- ros-jade-rosserial-client: 0.7.3-0 -> 0.7.4-0
- ros-jade-rosserial-embeddedlinux: 0.7.3-0 -> 0.7.4-0
- ros-jade-rosserial-mbed: 0.7.3-0 -> 0.7.4-0
- ros-jade-rosserial-msgs: 0.7.3-0 -> 0.7.4-0
- ros-jade-rosserial-python: 0.7.3-0 -> 0.7.4-0
- ros-jade-rosserial-server: 0.7.3-0 -> 0.7.4-0
- ros-jade-rosserial-tivac: 0.7.3-0 -> 0.7.4-0
- ros-jade-rosserial-windows: 0.7.3-0 -> 0.7.4-0
- ros-jade-rosserial-xbee: 0.7.3-0 -> 0.7.4-0
- ros-jade-rtt: 2.8.3-0 -> 2.8.3-2
- ros-jade-rviz-imu-plugin: 1.1.0-0 -> 1.1.2-0
- ros-jade-sick-tim: 0.0.8-0 -> 0.0.9-0
- ros-jade-speech-recognition-msgs: 3.0.0-0 -> 4.0.0-0
- ros-jade-srdfdom: 0.3.1-0 -> 0.3.3-0
- ros-jade-teleop-twist-joy: 0.1.1-0 -> 0.1.2-0
- ros-jade-ueye-cam: 1.0.14-0 -> 1.0.15-0
- ros-jade-virtual-force-publisher: 2.0.17-0 -> 2.1.2-1
Maintainers
- Adam Leeper
- AlexV
- Alexander Tiderko
- Anqi Xu
- Atsushi Watanabe
- Dave Coleman
- Gary Servin
- Ha Dang
- Kareem Shehata
- KazutoMurase
- Kei Okada
- Markus Bader
- Martin Günther
- Mikael Arguedas
- Mike Purvis
- Natalia Lyubova
- Orocos Developers
- Paul Bouchier
- Piyush Khandelwal
- Russell Toris
- Ryohei Ueda
- Severin Lemaignan
- Shohei Fujii
- Surya Ambrose
- Séverin Lemaignan
- TORK
- Vitor Matos
- William Woodall
- Yohei Kakiuchi
- YoheiKakiuchi
- Youhei Kakiuchi
- Yuki Furuta
- Yusuke Furuta
- furuta
