We’re happy to announce another sync of packages for Lunar with 62 new and updated packages.
The only package not available on all platforms if grpc
that is not available on Debian Stretch arm64.
Thanks to the many contributors and maintainers who have made these packages available. The full details are below:
Package Updates for lunar
Added Packages [12]:
- ros-lunar-grpc: 0.0.2-0
- ros-lunar-joy: 1.11.0-0
- ros-lunar-joystick-drivers: 1.11.0-0
- ros-lunar-novatel-gps-driver: 3.3.0-0
- ros-lunar-novatel-gps-msgs: 3.3.0-0
- ros-lunar-ps3joy: 1.11.0-0
- ros-lunar-rosapi: 0.8.3-0
- ros-lunar-rosbridge-library: 0.8.3-0
- ros-lunar-rosbridge-server: 0.8.3-0
- ros-lunar-rosbridge-suite: 0.8.3-0
- ros-lunar-spacenav-node: 1.11.0-0
- ros-lunar-wiimote: 1.11.0-0
Updated Packages [50]:
- ros-lunar-actionlib-lisp: 0.2.9-0 -> 0.2.10-0
- ros-lunar-can-msgs: 0.7.5-0 -> 0.7.6-0
- ros-lunar-canopen-402: 0.7.5-0 -> 0.7.6-0
- ros-lunar-canopen-chain-node: 0.7.5-0 -> 0.7.6-0
- ros-lunar-canopen-master: 0.7.5-0 -> 0.7.6-0
- ros-lunar-canopen-motor-node: 0.7.5-0 -> 0.7.6-0
- ros-lunar-cl-tf: 0.2.9-0 -> 0.2.10-0
- ros-lunar-cl-tf2: 0.2.9-0 -> 0.2.10-0
- ros-lunar-cl-transforms: 0.2.9-0 -> 0.2.10-0
- ros-lunar-cl-transforms-stamped: 0.2.9-0 -> 0.2.10-0
- ros-lunar-cl-urdf: 0.2.9-0 -> 0.2.10-0
- ros-lunar-cl-utils: 0.2.9-0 -> 0.2.10-0
- ros-lunar-joint-state-publisher: 1.12.11-0 -> 1.12.12-0
- ros-lunar-laser-filters: 1.8.4-1 -> 1.8.5-0
- ros-lunar-libmavconn: 0.19.0-0 -> 0.21.0-0
- ros-lunar-marti-can-msgs: 0.0.9-0 -> 0.2.0-0
- ros-lunar-marti-common-msgs: 0.0.9-0 -> 0.2.0-0
- ros-lunar-marti-data-structures: 0.3.0-0 -> 1.1.0-0
- ros-lunar-marti-nav-msgs: 0.0.9-0 -> 0.2.0-0
- ros-lunar-marti-perception-msgs: 0.0.9-0 -> 0.2.0-0
- ros-lunar-marti-sensor-msgs: 0.0.9-0 -> 0.2.0-0
- ros-lunar-marti-visualization-msgs: 0.0.9-0 -> 0.2.0-0
- ros-lunar-mavlink: 2017.8.8-0 -> 2017.9.9-0
- ros-lunar-mavros: 0.19.0-0 -> 0.21.0-0
- ros-lunar-mavros-extras: 0.19.0-0 -> 0.21.0-0
- ros-lunar-mavros-msgs: 0.19.0-0 -> 0.21.0-0
- ros-lunar-plotjuggler: 1.1.3-0 -> 1.2.1-0
- ros-lunar-ros-canopen: 0.7.5-0 -> 0.7.6-0
- ros-lunar-ros-type-introspection: 0.6.3-0 -> 0.9.0-0
- ros-lunar-roslisp-common: 0.2.9-0 -> 0.2.10-0
- ros-lunar-roslisp-utilities: 0.2.9-0 -> 0.2.10-0
- ros-lunar-rqt-shell: 0.4.8-0 -> 0.4.9-0
- ros-lunar-socketcan-bridge: 0.7.5-0 -> 0.7.6-0
- ros-lunar-socketcan-interface: 0.7.5-0 -> 0.7.6-0
- ros-lunar-swri-console-util: 0.3.0-0 -> 1.1.0-0
- ros-lunar-swri-geometry-util: 0.3.0-0 -> 1.1.0-0
- ros-lunar-swri-image-util: 0.3.0-0 -> 1.1.0-0
- ros-lunar-swri-math-util: 0.3.0-0 -> 1.1.0-0
- ros-lunar-swri-nodelet: 0.3.0-0 -> 1.1.0-0
- ros-lunar-swri-opencv-util: 0.3.0-0 -> 1.1.0-0
- ros-lunar-swri-prefix-tools: 0.3.0-0 -> 1.1.0-0
- ros-lunar-swri-roscpp: 0.3.0-0 -> 1.1.0-0
- ros-lunar-swri-rospy: 0.3.0-0 -> 1.1.0-0
- ros-lunar-swri-route-util: 0.3.0-0 -> 1.1.0-0
- ros-lunar-swri-serial-util: 0.3.0-0 -> 1.1.0-0
- ros-lunar-swri-string-util: 0.3.0-0 -> 1.1.0-0
- ros-lunar-swri-system-util: 0.3.0-0 -> 1.1.0-0
- ros-lunar-swri-transform-util: 0.3.0-0 -> 1.1.0-0
- ros-lunar-swri-yaml-util: 0.3.0-0 -> 1.1.0-0
- ros-lunar-test-mavros: 0.19.0-0 -> 0.21.0-0
Removed Packages [0]:
- Chris Lalancette
- Davide Faconti
- Dorian Scholz
- Ed Venator
- Edmond DuPont
- Elliot Johnson
- Gayane Kazhoyan
- Jon Binney
- Jonathan Bohren
- Kris Kozak
- Marc Alban
- Mathias Lüdtke
- P. J. Reed
- Russell Toris
- Shengye Wang
- Vladimir Ermakov
