We’re happy to announce the availability of 18 new packages and 21 updated packages for ROS Lunar.
As always thank you to all the maintainers who are making these releases as well as all the contributors who have helped contribute to these releases. Full details are below.
Package Updates for lunar
Added Packages [18]:
- ros-lunar-costmap-cspace-msgs: 0.2.0-0
- ros-lunar-hector-components-description: 0.5.0-0
- ros-lunar-hector-gazebo: 0.5.1-0
- ros-lunar-hector-gazebo-plugins: 0.5.1-0
- ros-lunar-hector-gazebo-thermal-camera: 0.5.1-0
- ros-lunar-hector-gazebo-worlds: 0.5.1-0
- ros-lunar-hector-models: 0.5.0-0
- ros-lunar-hector-sensors-description: 0.5.0-0
- ros-lunar-hector-sensors-gazebo: 0.5.1-0
- ros-lunar-hector-xacro-tools: 0.5.0-0
- ros-lunar-map-organizer-msgs: 0.2.0-0
- ros-lunar-neonavigation-msgs: 0.2.0-0
- ros-lunar-planner-cspace-msgs: 0.2.0-0
- ros-lunar-rc-cloud-accumulator: 1.0.4-0
- ros-lunar-trajectory-tracker-msgs: 0.2.0-0
- ros-lunar-velodyne-description: 1.0.7-0
- ros-lunar-velodyne-gazebo-plugins: 1.0.7-0
- ros-lunar-velodyne-simulator: 1.0.7-0
Updated Packages [21]:
- ros-lunar-diff-drive-controller: 0.13.3-0 -> 0.13.4-0
- ros-lunar-effort-controllers: 0.13.3-0 -> 0.13.4-0
- ros-lunar-force-torque-sensor-controller: 0.13.3-0 -> 0.13.4-0
- ros-lunar-forward-command-controller: 0.13.3-0 -> 0.13.4-0
- ros-lunar-four-wheel-steering-controller: 0.13.3-0 -> 0.13.4-0
- ros-lunar-gripper-action-controller: 0.13.3-0 -> 0.13.4-0
- ros-lunar-imu-sensor-controller: 0.13.3-0 -> 0.13.4-0
- ros-lunar-joint-state-controller: 0.13.3-0 -> 0.13.4-0
- ros-lunar-joint-trajectory-controller: 0.13.3-0 -> 0.13.4-0
- ros-lunar-mcl-3dl: 0.1.2-0 -> 0.1.3-0
- ros-lunar-position-controllers: 0.13.3-0 -> 0.13.4-0
- ros-lunar-rc-dynamics-api: 0.6.0-0 -> 0.7.0-0
- ros-lunar-rc-genicam-api: 1.3.8-0 -> 1.3.11-0
- ros-lunar-rc-visard: 2.1.0-0 -> 2.2.0-0
- ros-lunar-rc-visard-description: 2.1.0-0 -> 2.2.0-0
- ros-lunar-rc-visard-driver: 2.1.0-0 -> 2.2.0-0
- ros-lunar-ros-controllers: 0.13.3-0 -> 0.13.4-0
- ros-lunar-rqt-joint-trajectory-controller: 0.13.3-0 -> 0.13.4-0
- ros-lunar-rqt-rviz: 0.5.8-0 -> 0.6.0-0
- ros-lunar-teb-local-planner-tutorials: 0.2.1-0 -> 0.2.2-0
- ros-lunar-velocity-controllers: 0.13.3-0 -> 0.13.4-0
Removed Packages [0]:
- Adolfo Rodriguez Tsouroukdissian
- Atsushi Watanabe
- Bence Magyar
- Christoph Rösmann
- Felix Endres
- Felix Ruess
- Johannes Meyer
- Kevin Hallenbeck
- Louise Poubel
- Monika Florek-Jasinska
- Sachin Chitta
- Stefan Kohlbrecher
- Vincent Rousseau
