For my C# wrapper I wrote my own message generator and implemented a rosidl_generator_cs package ( GitHub - firesurfer/rosidl_generator_cs: ROS2 Message generator for C# ).
This works fine when doing a normal build but today I tried building ros2 with the --build-tests option. With this option the build fails at the builtin_interfaces package.
Scanning dependencies of target builtin_interfaces__py
Scanning dependencies of target generate_cs_messages_Time
make[2]: *** Keine Regel vorhanden, um das Ziel „/home/firesurfer/workspace/ros2_ws/src/ros2/common_interfaces/builtin_interfaces/ros2cs_message_generator“,
benötigt von „CMakeFiles/generate_cs_messages_Duration“, zu erstellen. Schluss.
CMakeFiles/Makefile2:520: die Regel für Ziel „CMakeFiles/generate_cs_messages_Duration.dir/all“ scheiterte
make[1]: *** [CMakeFiles/generate_cs_messages_Duration.dir/all] Fehler 2
make[1]: *** Es wird auf noch nicht beendete Prozesse gewartet...
benötigt von „CMakeFiles/generate_cs_messages_Time“, zu erstellen. Schluss.
CMakeFiles/Makefile2:1378: die Regel für Ziel „CMakeFiles/generate_cs_messages_Time.dir/all“ scheiterte
make[1]: *** [CMakeFiles/generate_cs_messages_Time.dir/all] Fehler 2
Only english (sry that I’m working on a german system) the error is (translated):
No rule exists to create the target „/home/firesurfer/workspace/ros2_ws/src/ros2/common_interfaces/builtin_interfaces/ros2cs_message_generator“,
needed from „CMakeFiles/generate_cs_messages_Duration“, Exit.
CMakeFiles/Makefile2:520: the rule for target „CMakeFiles/generate_cs_messages_Duration.dir/all“ failed.
Then it says the same for the Time message.
I’ve got absolutely no idea why everything works fine if I’m building without tests but fails with tests enabled.
