ROS2: How to use custom message in project where it's declared?
I’ve created C++ ROS2 project with a custom message as explained here: https://github.com/ros2/ros2/wiki/Defining-custom-interfaces-(msg-srv)
I can see the message is generated properly and .h.hpp files are installed.
Now I want to use this custom message in the same project where it’s generated. But I can’t reference the header file of my generated message from the same project.
Here is my CMakeList.txt:
cmake_minimum_required(VERSION 3.5)
project(bridge_test_msgs)
if(NOT WIN32)
  set(CMAKE_CXX_FLAGS "${CMAKE_CXX_FLAGS} -std=c++14 -Wall -Wextra -Wpedantic")
endif()
find_package(ament_cmake REQUIRED)
find_package(rosidl_default_generators REQUIRED)
find_package(std_msgs REQUIRED)
find_package(rclcpp REQUIRED)
find_package(rclcpp_lifecycle REQUIRED)
set(msg_files
  "msg/BridgeTestMessage.msg"
rosidl_generate_interfaces(${PROJECT_NAME}
  ${msg_files}
  ADD_LINTER_TESTS
include_directories(
  ${rclcpp_INCLUDE_DIRS}
  ${rclcpp_lifecycle_INCLUDE_DIRS}
  ${std_msgs_INCLUDE_DIRS}
#    ${${PROJECT_NAME}_INCLUDE_DIRS}
add_executable(my_publisher
    src/my_publisher.cpp
target_link_libraries(my_publisher
  ${rclcpp_LIBRARIES}
  ${rclcpp_lifecycle_LIBRARIES}
  ${std_msgs_LIBRARIES}
#        ${PROJECT_NAME}
#        ${PROJECT_NAME}_LIBRARIES
#        ${${PROJECT_NAME}_LIBRARIES}
add_dependencies(my_publisher ${PROJECT_NAME})
ament_target_dependencies(my_publisher
        "rclcpp"
        "rclcpp_lifecycle"
        "std_msgs"
        "${PROJECT_NAME}"
install(TARGETS
        my_publisher
        DESTINATION bin
ament_export_dependencies(rosidl_default_runtime)
ament_package()
Inside src/my_publisher.cpp I have a line:
#include “bridge_test_msgs/msg/bridge_test_message.hpp”
Command ‘ament build’ fails with message:
my_publisher.cpp:7:56: fatal error: bridge_test_msgs/msg/bridge_test_message.hpp: No such file or directory
compilation terminated.
CMakeFiles/my_publisher.dir/build.make:62: recipe for target 'CMakeFiles/my_publisher.dir/src/my_publisher.cpp.o' failed
make[2]: *** [CMakeFiles/my_publisher.dir/src/my_publisher.cpp.o] Error 1
CMakeFiles/Makefile2:288: recipe for target 'CMakeFiles/my_publisher.dir/all' failed
make[1]: *** [CMakeFiles/my_publisher.dir/all] Error 2
Makefile:127: recipe for target 'all' failed
make: *** [all] Error 2
I can see header file exists:
$ ls install/include/bridge_test_msgs/msg/bridge_test_message.hpp
-rw-r--r-- 1 mc mc 415 Jun 27 15:00 install/include/bridge_test_msgs/msg/bridge_test_message.hpp
Could you hint me how to reference custom message from the project itself?
It’s true that most our message package are pure message packages and thus do not try to include/link against themselves. The trick here is that you need to use the macro rosidl_target_interfaces
rosidl_target_interfaces(MY_TARGET_NAME
      ${PROJECT_NAME} "rosidl_typesupport_cpp")
You can look at the composition demo CMake code for an example.
I agree that this is not well documented and that an addition to https://github.com/ros2/ros2/wiki/Defining-custom-interfaces-(msg-srv) would be valuable
Yeah. That worked for me. Thank you!
For closure: I added this documentation: https://github.com/ros2/ros2_documentation/pull/339
That works. Many thanks : )
