PCL is a common library used for processing Point Clouds in ROS. As such, we’d like to get an insight into how you use and acquire the library, what features are most anticipated as well as what in PCL is important to you. We’ve created a survey that allows us to understand some of these questions or helps us ask better questions.
If you or your team uses (or used) PCL (directly or via perception_pcl), please find the survey at https://tinyurl.com/pcl-2020-survey. If you have shifted (or plan to shift) to some other solution, please inform us the reasons for that at the same link.
It’s a small survey of 10 questions. We’ll keep it open till 2020-Aug-20 and will provide a summary in this thread by Aug 30th.
If you’re able to edit, it might be good to clarify on the 1-N scoring questions that 1 or N is the highest score. I assume it was N but wanted to clarify.
Keep up the awesome work and I’d love to chat more or learn more about the PCL roadmap and wishlists. It’s been awesome seeing the recent documentation push!
I’m cutting it close to my self-imposed deadline for the results. Please bear in mind that this is a survey within a ecosystem and is not a representative sample of the kind of users that PCL has.
How long have you used PCL?
2 or more years: 42%
6 months to 2 years: 35%
Less than 6 months: 25%
Never: 1 kind soul
Preferred OS for using PCL (percentages don’t add to 100% for obvious reasons)
Debian and friends: 85% (wasn’t a big surprise that this was the largest group, but the margin was shocking)
Windows: 20%
MacOS, ArchLinux, BusyBox, Gentoo, NixOS: 1 representation each
