Hello everyone,
We’re planning for the third patch release for Iron on 2023-11-17T01:00:00Z.
I will be bumping versions of the core ROS 2 packages this week and will follow up with a sync.
Currently are currently no regressions and 19+ packages to release
We will hold Iron backports and rosdistro
PRs for the sync starting today 2023-11-13T10:00:00Z and will do the sync once the core pkgs have been released into testing and without any regressions.
I’ll make an announcement here once the sync is complete and we can resume merging into rosdistro
The patch and sync are complete.
Important announcement
We’ve recently made an important update to ROS 2: loaned messages are
now disabled by default. If you don’t know what loaned messages are,
then you can stop reading now. If you are using loaned messages,
continue reading.
We disabled the loaned messages by default to address safety
concerns, as there were instances of shared pointers being unsafely
reused across multiple callbacks. While this adjustment temporarily
limits loaned message capabilities in callbacks, it’s a necessary step to
ensure the reliability and safety of the system. See Disable the loaned messages inside the executor. by clalancette · Pull Request #2335 · ros2/rclcpp · GitHub for more details.
If you understand the risks of using loaned messages and want to enable them,
you can set ROS_DISABLE_LOANED_MESSAGE=0 in the environment before launching your nodes.
Rest assured, we’re exploring options to safely reintroduce this feature in the future. Your
understanding and support in this matter are greatly appreciated.
