Published revision 13 of OpenEmbedded Build Instructions (meta-ros)
This revision announces that [thud-draft] now contains a greatly improved re-implementation of the per-device confirmation scheme. It also contains tweaks to the ROS 1 and TurtleBot 3 documentation.
The document is here. Its change log is here. A “rich diff” of the changes made since the previous revision is here.
