This revision announces that [thud-draft]
is now at Milestone 8:
- The
meta-ros
layer has been split into sublayers and the webOS OSE integration subliayer split off into a separate repo meta-ros-webos. -
mcf and its configuration files are now in a separately-rooted branch
[build-draft]
DISTRO
no longer needs to be set inconf/bblayers.conf
; however,ROS_DISTRO
still must be (until Milestone 12). - The image names have been simplified.
- It should be easier to use
meta-ros
without using mcf.
If you have been building from the [thud-draft]
branch, please start again from scratch as soon as you can. To allow you to transition, a branch [legacy-v2]
has been created from the previous [thud-draft]
. Its files will not be changed nor its commits rebased.
The document is here. Its change log is here. A “rich diff” of the changes made since the previous revision is here.
