This revision updates the document for the many changes introduced by meta-ros
layer version 3, the first phase of which will be pushed in the next day or two. It also contains noteworthy changes to the milestones.
The document is here. Its change log is here. A diff of the changes made since the previous revision is here. (GitHub is unable to render the usual “rich diff” of the changes.)
