Question Regarding ros2_control Design
Although the linked post is two years old, the arguments of @destogl are still valid IMHO.
Keep in mind that one focus of ros2_control was real-time safe control loops, and they can run without any ROS networking magic (e.g., the joint_trajectory_controller performing an action goal → there is no ROS node involved any more). This was successfully tested with control loops faster than 1kHz, where you will have problems with most of the DDS implementations if you don’t know exactly how to configure that (latency, jitter,…).
About the use case you are describing with temperature as a measured state: You won’t need fast control loops and you are perfectly fine with ROS nodes without ros2_control. Additionally, you don’t get any benefit with the simulator integrations, because you won’t simulate temperature in gazebo.
