tl;dr: The packages below will be removed from the bootstrap, ROS 1, and ROS 2 repositories on 2021-03-16T07:00:00Z
As part of an ongoing background effort to improve the reliability and reproducibility of the ROS build farm we’ve been updating packages in the bootstrap repository (which is used to provide packages that 1. are required for ROS, 2. not available upstream, and 3. not built on the ROS buildfarm itself. The primary examples are tools like catkin-pkg, rosdep, bloom, and ros-buildfarm.
There are some packages which have been added to the bootstrap repository over the years without an accompanying source package for reproducibility and are not currently used by packages on the ROS build farm.
Once these packages are removed from the bootstrap repositories, they also be manually removed from the ROS and ROS 2 repositories. Manual intervention will be needed by build farm maintainers if they wish to remove the packages from their farms as well. There is no outstanding issue with these packages but if you want to keep parity with the official build farms removal is recommended. We will be performing these removals on 2021-03-16T07:00:00Z
In Ubuntu 16.04 (Xenial)
- libpcl-doc 1.7.2-14ubuntu0.1
In Ubuntu 18.04 (Bionic)
- libpyside-py3-2.0 2.0.0+dev-0~201712012232~rev1779~pkg53~ubuntu18.04.1
- libpyside-py3-2.0 2.0.0+dev-0~201712291010~rev1791~pkg76~ubuntu18.04.1
- libpyside2-dev 2.0.0+dev-0~201712012232~rev1779~pkg53~ubuntu18.04.1
- libpyside2-dev 2.0.0+dev-0~201712291010~rev1791~pkg76~ubuntu18.04.1
- libpyside2.0 2.0.0+dev-0~201712012232~rev1779~pkg53~ubuntu18.04.1
- libpyside2.0 2.0.0+dev-0~201712291010~rev1791~pkg76~ubuntu18.04.1
- python-pyside2-dbg 2.0.0+dev-0~201712012232~rev1779~pkg53~ubuntu18.04.1
- python-pyside2-dbg 2.0.0+dev-0~201712291010~rev1791~pkg76~ubuntu18.04.1
- python-pyside2.qtcharts-dbg 2.0.0+dev-0~201712291010~rev1791~pkg76~ubuntu18.04.1
- python-pyside2.qtcharts 2.0.0+dev-0~201712291010~rev1791~pkg76~ubuntu18.04.1
- python-pyside2.qtconcurrent-dbg 2.0.0+dev-0~201712012232~rev1779~pkg53~ubuntu18.04.1
- python-pyside2.qtconcurrent-dbg 2.0.0+dev-0~201712291010~rev1791~pkg76~ubuntu18.04.1
- python-pyside2.qtconcurrent 2.0.0+dev-0~201712012232~rev1779~pkg53~ubuntu18.04.1
- python-pyside2.qtconcurrent 2.0.0+dev-0~201712291010~rev1791~pkg76~ubuntu18.04.1
- python-pyside2.qtcore-dbg 2.0.0+dev-0~201712012232~rev1779~pkg53~ubuntu18.04.1
- python-pyside2.qtcore-dbg 2.0.0+dev-0~201712291010~rev1791~pkg76~ubuntu18.04.1
- python-pyside2.qtcore 2.0.0+dev-0~201712012232~rev1779~pkg53~ubuntu18.04.1
- python-pyside2.qtcore 2.0.0+dev-0~201712291010~rev1791~pkg76~ubuntu18.04.1
- python-pyside2.qtgui-dbg 2.0.0+dev-0~201712012232~rev1779~pkg53~ubuntu18.04.1
- python-pyside2.qtgui-dbg 2.0.0+dev-0~201712291010~rev1791~pkg76~ubuntu18.04.1
- python-pyside2.qtgui 2.0.0+dev-0~201712012232~rev1779~pkg53~ubuntu18.04.1
- python-pyside2.qtgui 2.0.0+dev-0~201712291010~rev1791~pkg76~ubuntu18.04.1
- python-pyside2.qthelp-dbg 2.0.0+dev-0~201712012232~rev1779~pkg53~ubuntu18.04.1
- python-pyside2.qthelp-dbg 2.0.0+dev-0~201712291010~rev1791~pkg76~ubuntu18.04.1
- python-pyside2.qthelp 2.0.0+dev-0~201712012232~rev1779~pkg53~ubuntu18.04.1
- python-pyside2.qthelp 2.0.0+dev-0~201712291010~rev1791~pkg76~ubuntu18.04.1
- python-pyside2.qtmultimedia-dbg 2.0.0+dev-0~201712012232~rev1779~pkg53~ubuntu18.04.1
- python-pyside2.qtmultimedia-dbg 2.0.0+dev-0~201712291010~rev1791~pkg76~ubuntu18.04.1
- python-pyside2.qtmultimedia 2.0.0+dev-0~201712012232~rev1779~pkg53~ubuntu18.04.1
- python-pyside2.qtmultimedia 2.0.0+dev-0~201712291010~rev1791~pkg76~ubuntu18.04.1
- python-pyside2.qtmultimediawidgets-dbg 2.0.0+dev-0~201712012232~rev1779~pkg53~ubuntu18.04.1
- python-pyside2.qtmultimediawidgets-dbg 2.0.0+dev-0~201712291010~rev1791~pkg76~ubuntu18.04.1
- python-pyside2.qtmultimediawidgets 2.0.0+dev-0~201712012232~rev1779~pkg53~ubuntu18.04.1
- python-pyside2.qtmultimediawidgets 2.0.0+dev-0~201712291010~rev1791~pkg76~ubuntu18.04.1
- python-pyside2.qtnetwork-dbg 2.0.0+dev-0~201712012232~rev1779~pkg53~ubuntu18.04.1
- python-pyside2.qtnetwork-dbg 2.0.0+dev-0~201712291010~rev1791~pkg76~ubuntu18.04.1
- python-pyside2.qtnetwork 2.0.0+dev-0~201712012232~rev1779~pkg53~ubuntu18.04.1
- python-pyside2.qtnetwork 2.0.0+dev-0~201712291010~rev1791~pkg76~ubuntu18.04.1
- python-pyside2.qtopengl-dbg 2.0.0+dev-0~201712012232~rev1779~pkg53~ubuntu18.04.1
- python-pyside2.qtopengl-dbg 2.0.0+dev-0~201712291010~rev1791~pkg76~ubuntu18.04.1
- python-pyside2.qtopengl 2.0.0+dev-0~201712012232~rev1779~pkg53~ubuntu18.04.1
- python-pyside2.qtopengl 2.0.0+dev-0~201712291010~rev1791~pkg76~ubuntu18.04.1
- python-pyside2.qtprintsupport-dbg 2.0.0+dev-0~201712012232~rev1779~pkg53~ubuntu18.04.1
- python-pyside2.qtprintsupport-dbg 2.0.0+dev-0~201712291010~rev1791~pkg76~ubuntu18.04.1
- python-pyside2.qtprintsupport 2.0.0+dev-0~201712012232~rev1779~pkg53~ubuntu18.04.1
- python-pyside2.qtprintsupport 2.0.0+dev-0~201712291010~rev1791~pkg76~ubuntu18.04.1
- python-pyside2.qtqml-dbg 2.0.0+dev-0~201712012232~rev1779~pkg53~ubuntu18.04.1
- python-pyside2.qtqml-dbg 2.0.0+dev-0~201712291010~rev1791~pkg76~ubuntu18.04.1
- python-pyside2.qtqml 2.0.0+dev-0~201712012232~rev1779~pkg53~ubuntu18.04.1
- python-pyside2.qtqml 2.0.0+dev-0~201712291010~rev1791~pkg76~ubuntu18.04.1
- python-pyside2.qtquick-dbg 2.0.0+dev-0~201712012232~rev1779~pkg53~ubuntu18.04.1
- python-pyside2.qtquick-dbg 2.0.0+dev-0~201712291010~rev1791~pkg76~ubuntu18.04.1
- python-pyside2.qtquick 2.0.0+dev-0~201712012232~rev1779~pkg53~ubuntu18.04.1
- python-pyside2.qtquick 2.0.0+dev-0~201712291010~rev1791~pkg76~ubuntu18.04.1
- python-pyside2.qtquickwidgets-dbg 2.0.0+dev-0~201712012232~rev1779~pkg53~ubuntu18.04.1
- python-pyside2.qtquickwidgets-dbg 2.0.0+dev-0~201712291010~rev1791~pkg76~ubuntu18.04.1
- python-pyside2.qtquickwidgets 2.0.0+dev-0~201712012232~rev1779~pkg53~ubuntu18.04.1
- python-pyside2.qtquickwidgets 2.0.0+dev-0~201712291010~rev1791~pkg76~ubuntu18.04.1
- python-pyside2.qtscript-dbg 2.0.0+dev-0~201712012232~rev1779~pkg53~ubuntu18.04.1
- python-pyside2.qtscript-dbg 2.0.0+dev-0~201712291010~rev1791~pkg76~ubuntu18.04.1
- python-pyside2.qtscript 2.0.0+dev-0~201712012232~rev1779~pkg53~ubuntu18.04.1
- python-pyside2.qtscript 2.0.0+dev-0~201712291010~rev1791~pkg76~ubuntu18.04.1
- python-pyside2.qtsql-dbg 2.0.0+dev-0~201712012232~rev1779~pkg53~ubuntu18.04.1
- python-pyside2.qtsql-dbg 2.0.0+dev-0~201712291010~rev1791~pkg76~ubuntu18.04.1
- python-pyside2.qtsql 2.0.0+dev-0~201712012232~rev1779~pkg53~ubuntu18.04.1
- python-pyside2.qtsql 2.0.0+dev-0~201712291010~rev1791~pkg76~ubuntu18.04.1
- python-pyside2.qtsvg-dbg 2.0.0+dev-0~201712012232~rev1779~pkg53~ubuntu18.04.1
- python-pyside2.qtsvg-dbg 2.0.0+dev-0~201712291010~rev1791~pkg76~ubuntu18.04.1
- python-pyside2.qtsvg 2.0.0+dev-0~201712012232~rev1779~pkg53~ubuntu18.04.1
- python-pyside2.qtsvg 2.0.0+dev-0~201712291010~rev1791~pkg76~ubuntu18.04.1
- python-pyside2.qttest-dbg 2.0.0+dev-0~201712012232~rev1779~pkg53~ubuntu18.04.1
- python-pyside2.qttest-dbg 2.0.0+dev-0~201712291010~rev1791~pkg76~ubuntu18.04.1
- python-pyside2.qttest 2.0.0+dev-0~201712012232~rev1779~pkg53~ubuntu18.04.1
- python-pyside2.qttest 2.0.0+dev-0~201712291010~rev1791~pkg76~ubuntu18.04.1
- python-pyside2.qttexttospeech-dbg 2.0.0+dev-0~201712291010~rev1791~pkg76~ubuntu18.04.1
- python-pyside2.qttexttospeech 2.0.0+dev-0~201712291010~rev1791~pkg76~ubuntu18.04.1
- python-pyside2.qtuitools-dbg 2.0.0+dev-0~201712012232~rev1779~pkg53~ubuntu18.04.1
- python-pyside2.qtuitools-dbg 2.0.0+dev-0~201712291010~rev1791~pkg76~ubuntu18.04.1
- python-pyside2.qtuitools 2.0.0+dev-0~201712012232~rev1779~pkg53~ubuntu18.04.1
- python-pyside2.qtuitools 2.0.0+dev-0~201712291010~rev1791~pkg76~ubuntu18.04.1
- python-pyside2.qtwebchannel-dbg 2.0.0+dev-0~201712012232~rev1779~pkg53~ubuntu18.04.1
- python-pyside2.qtwebchannel-dbg 2.0.0+dev-0~201712291010~rev1791~pkg76~ubuntu18.04.1
- python-pyside2.qtwebchannel 2.0.0+dev-0~201712012232~rev1779~pkg53~ubuntu18.04.1
- python-pyside2.qtwebchannel 2.0.0+dev-0~201712291010~rev1791~pkg76~ubuntu18.04.1
- python-pyside2.qtwebenginewidgets-dbg 2.0.0+dev-0~201712291010~rev1791~pkg76~ubuntu18.04.1
- python-pyside2.qtwebenginewidgets 2.0.0+dev-0~201712291010~rev1791~pkg76~ubuntu18.04.1
- python-pyside2.qtwebkit-dbg 2.0.0+dev-0~201712012232~rev1779~pkg53~ubuntu18.04.1
- python-pyside2.qtwebkit 2.0.0+dev-0~201712012232~rev1779~pkg53~ubuntu18.04.1
- python-pyside2.qtwebkitwidgets-dbg 2.0.0+dev-0~201712012232~rev1779~pkg53~ubuntu18.04.1
- python-pyside2.qtwebkitwidgets 2.0.0+dev-0~201712012232~rev1779~pkg53~ubuntu18.04.1
- python-pyside2.qtwebsockets-dbg 2.0.0+dev-0~201712012232~rev1779~pkg53~ubuntu18.04.1
- python-pyside2.qtwebsockets-dbg 2.0.0+dev-0~201712291010~rev1791~pkg76~ubuntu18.04.1
- python-pyside2.qtwebsockets 2.0.0+dev-0~201712012232~rev1779~pkg53~ubuntu18.04.1
- python-pyside2.qtwebsockets 2.0.0+dev-0~201712291010~rev1791~pkg76~ubuntu18.04.1
- python-pyside2.qtwidgets-dbg 2.0.0+dev-0~201712012232~rev1779~pkg53~ubuntu18.04.1
- python-pyside2.qtwidgets-dbg 2.0.0+dev-0~201712291010~rev1791~pkg76~ubuntu18.04.1
- python-pyside2.qtwidgets 2.0.0+dev-0~201712012232~rev1779~pkg53~ubuntu18.04.1
- python-pyside2.qtwidgets 2.0.0+dev-0~201712291010~rev1791~pkg76~ubuntu18.04.1
- python-pyside2.qtx11extras-dbg 2.0.0+dev-0~201712012232~rev1779~pkg53~ubuntu18.04.1
- python-pyside2.qtx11extras-dbg 2.0.0+dev-0~201712291010~rev1791~pkg76~ubuntu18.04.1
- python-pyside2.qtx11extras 2.0.0+dev-0~201712012232~rev1779~pkg53~ubuntu18.04.1
- python-pyside2.qtx11extras 2.0.0+dev-0~201712291010~rev1791~pkg76~ubuntu18.04.1
- python-pyside2.qtxml-dbg 2.0.0+dev-0~201712012232~rev1779~pkg53~ubuntu18.04.1
- python-pyside2.qtxml-dbg 2.0.0+dev-0~201712291010~rev1791~pkg76~ubuntu18.04.1
- python-pyside2.qtxml 2.0.0+dev-0~201712012232~rev1779~pkg53~ubuntu18.04.1
- python-pyside2.qtxml 2.0.0+dev-0~201712291010~rev1791~pkg76~ubuntu18.04.1
- python-pyside2 2.0.0+dev-0~201712291010~rev1791~pkg76~ubuntu18.04.1
