Posted by @cwrx777:
Reference: handle_api_request
I would like to check with you on RMF behavior on task API requests handling behavior.
- if the task is a direct task request and the robot is already executing a task (task_id = task_1), if there is another task request with task_id task_1. does RMF see this as a different task and queue the task for this robot and publish a response? or RMF still responds but there the task is not queued since there is already a task with the same task_id.
- For task cancellation, kill, interrupt, etc, if the task does not exist in RMF, does RMF respond?
- When the task is already completed,killed, cancelled, and if RMF receives another task request with the same task_id, does RMF see this as another task and provide API response as queued?
- How often does the dispatcher provide task_state_update via the websocket, including for completed task?
- is there any API to check the status of a task?
