Ros 2 monitor
How can we monitor ROS-2 nodes.?
The question as-is doesn’t provide enough information to give you a “good” answer. Can you please eloaborate what your are trying to do / want to achieve.
Moved to ROS2 category aka “Next Generation ROS”
I mean in order to monitor ros-1 we have ‘rqt_top’ command which can be executed in the command line to view the various phenomenons.
Similarly ,what command or is there any procedure to monitor in ros-2??
Is it clear enough???
rqt is not available in ROS 2 yet. Only command line tools to e.g. list running nodes is available (ros2 node list).
You could always resort to use top for process monitoring.
