I am trying to create a ROS wrapper for caffe2 (Ros Kinetic, opencv version-3.4.1) and I get the following error:
[ERROR] [1532132328.463265]: bad callback: <bound method image_converter.callback of <main.image_converter instance at 0x7f01bdc8e7a0>>
File “/opt/ros/kinetic/lib/python2.7/dist-packages/rospy/topics.py”, line 750, in _invoke_callback
cb(msg)
File “ros_mercnn.py”, line 72, in callback
cv_image = self.bridge.imgmsg_to_cv2(data, ‘bgr8’)
File “/opt/ros/kinetic/lib/python2.7/dist-packages/cv_bridge/core.py”, line 182, in imgmsg_to_cv2
res = cvtColor2(im, img_msg.encoding, desired_encoding)
ArgumentError: Python argument types in
cv_bridge.boost.cv_bridge_boost.cvtColor2(numpy.ndarray, str, unicode)
did not match C++ signature:
cvtColor2(boost::python::api::object, std::__cxx11::basic_string<char, std::char_traits, std::allocator >, std::__cxx11::basic_string<char, std::char_traits, std::allocator >)
Any help will be highly appreciated
#!/usr/bin/env python
"""Perform inference on a single image or all images with a certain extension
(e.g., .jpg) in a folder.
from __future__ import absolute_import
from __future__ import division
from __future__ import print_function
from __future__ import unicode_literals
from collections import defaultdict
import argparse
import cv2 # NOQA (Must import before importing caffe2 due to bug in cv2)
import glob
import logging
import os
import sys
import time
from caffe2.python import workspace
import roslib
#roslib.load_manifest('my_package')
import sys
import rospy
#import cv2
from std_msgs.msg import String
from sensor_msgs.msg import Image
from cv_bridge import CvBridge, CvBridgeError
import numpy as np
class image_converter:
def __init__(self):
self.bridge = CvBridge()
self.image_sub = rospy.Subscriber("/usb_cam/image_raw",Image,self.callback)
cv2.waitKey(1000000)
def callback(self, data):
currentframe = 0
try:
while True:
cv_image = self.bridge.imgmsg_to_cv2(data, 'bgr8')
except CvBridgeError as e:
print(e)
def main(args):
ic = image_converter()
rospy.init_node('image_converter', anonymous=True)
try:
cv2.waitKey(1000)
rospy.spin()
except KeyboardInterrupt:
print('Shutting Down')
cv2.destroyAllWindows()
if __name__ == '__main__':
workspace.GlobalInit(['caffe2', '--caffe2_log_level=0'])
# setup_logging(__name__)
main(sys.argv)
