ROS-I Developers Meeting
ROS-I Americas will host a ROS-I Developers’ Meeting on Jan 14. Info on all regional monthly developer meetings may be found here and each region will post up more info as their event gets closer.
Though developer meetings are monthly the hosting is rotated by region and is detailed here: Developers Meeting — ROS-Industrial
Looking forward to seeing folks online on the 14th!
MR
ROS-I Consortium Americas PM
The recording from the most recent ROS-Industrial Developers’ Meeting is now up over at the ROS-I YouTube channel. You can check it out here: https://youtu.be/2Z52ZY5414U
The presentation/slides shared are attached below! The next developer meeting is slated for Feb, and will be hosted by the ROS-I EU team! Check out the details over at ros-i.org.
ROS-I Developers Meeting - Jan 2025.pdf (181.1 KB)
