out of curiosity, i would really like to know ROS/ROS2/Micro-ROS product in the market. if anyone has any idea or information about the marketing, please leave some comments here
Best,
Best,
Hereâs a list from the ROS wiki, but there are more than this. There are a lot of platforms Iâve heard about from peers where the intended use-case doesnât involve providing a ROS API, so the fact that itâs leveraging ROS doesnât get mentioned really.
From my experience, a lot of companies use ROS under the hood in their products while not publishing anything about it. So such a list is likely to be only a fraction of real applications.
Iâm not sure if this helps but I have a private list of companies that I maintain (unfortunately I canât share it). I can tell you that it is well over 300 companies. I usually refer people to the ROS 2 TSC and the ROS Industrial Consortium members.
A good way to gauge the number of users is to search job websites for, âROS.â
Here is the slide I use on this topic.
Another good source of information about whoâs using ROS is also to look at the ROSCon sponsors over the years: 2021, 2020, 2019, 2019 FR, 2019 JP, 2018, 2018 JP, 2017, 2016, 2015, 2014, 2013, 2012
Hello tomoyafujita, i would also recommend that you join the Micro-ROS Slack if you havenât done already. The people are very friendly and helpfull there.
most use ROS and the rest are lying
As you are no doubt aware, âusing ROSâ is a continuum â having all of a robotâs software based on ROS is one end (achieved by very few, most have at least some custom micro-controllers in there somewhere), having a driver or using âjustâ some of the tools is the other end. Many mixtures are in-between.
I mention this, because one of the problems with many current lists is that they do not differentiate these use cases, and thus when you ask âwhat is the experience with using ROS for use case xyâ, there is often no good answer.
@Katherine_Scott - does the 300 number really mean companies using ROS internally or creating products with ROS in them? I think the original question was how many products are in market with ROS in them?
@mkhansen That isnât quite a distinction we track. There are varying levels of ROS usage.
I donât think people appreciate how many compnies use ROS to build their product or service. For example, two more companies that use ROS closed rounds today Scythe, and Dusty Robotics.
People get so hung up on âproductsâ on the market. How many ârobot productsâ do most people interact with on a daily basis besides a vaccum? The real question is how many ROS robots touched a product that you purchased. If a ROS robot helped deliver a product or moved it around a fullfillment center, or helped it grow, does that count?
Kat, thatâs what I thought, I was just trying to clarify the 300 number. I donât know if anyone knows exactly how many products are in the market with ROS in them, but I think that was the original question in the thread.
Even then, many of those use ROS/ROS2 now . Using âROSâ as a communication system is a different question than companies that use much of the other higher level tools like MoveIt or Navigation in a product. But so many use ROS, I canât tell you how many demo videos I see where thereâs a âlook how cool the robot sees the worldâ thatâs very clearly rviz.
There are companies doing it, in fact I have a little book on my desk I jot down names of companies when they reach out to me with questions because theyâre using it. I donât want to âoutâ anyone, but thereâs already35 companies known to me using Nav2 in production (implying not just Nav2 usage, but ROS2 and the broader ecosystem as well). But its also not unusual to hit a point where you need more than what the open source implementations will provide and you need to build up the highest levels yourself. And thatâs totally OK and expected in any really narrowly focused company â eventually the general tools donât do what you need specifically done as specifically as youâd like. Iâd hope at that point theyâd contribute back, but in many cases, they have not .
Part of my aim with Nav2, for instance, is to reduce or largely remove that need so that everyone can use the same platform from undergraduates to Fortune 500 companies. Itâs why Iâm very focused on getting adopters and really listening to their issues. Weâre stronger as a field if we have these common capabilities shared across large swaths of the corporate world. But that doesnât just happen, there are passionate people behind any of those packages that seem like everyone uses them (@tfoote with TF and the folks at Amazon @emersonknapp for rosbag2 come to mind).
Thanks for sharing that information @Katherine_Scott. It seems that ROS 2 is present in many important companies.
that is an important point, so it is not only about products but also about services that are related to ROS to some extent.
Peace be upon all of you
Iâm currently establishing Al Jazari agricultural robotics startup, and nearly all startups in this field are using ROS, this is our Autonomous Crop Sprayer DoDo and this is a sample of crop row detection using ROS and OpenCV
Great choice of name! Guessing it is after the inventor Ismail Al Jazari?
Yes, the startup named after Ismail Al Jazari, with his vicegerent vision of introducing an affordable self-reliant modern agricultural system from robotic implements to renewable power sources and eco-friendly shelters. DoDo is targetet to be sold at 2500 USD only and the 2 kW wind turbine at 640 USD, InshaâAllah
Hi Tomoya!
microROS is playing an important role since it facilitates the entry to new applications based on Low resource devices. It is already present in several HW platforms, embedded is ramping up!
Real commercial product/applications are around the corner. So, stay tuned!
As an appetiser, check on
Taking a quick look, Iâve got to some existing ROS 2 products here
Hello,
I liked your project so much. Especially at the point of detection of crop rows.
I am working on the same project too. But with the different sensors
List of (mostly automotive) Companies using ROS
. The list has 200 entries and I have to concur with ROS/ROS2/Micro-ROS Product in Market - #7 by joespeed
