Hello,
I have been using ROS1 in my lab for a while, and felt like trying ROS2 after its Beta1 release. I began with a bare bones Ubuntu 16.04 container and followed the install from source instructions found here - https://github.com/ros2/ros2/wiki/Linux-Development-Setup
During the build, I got the following error:
+++ Building 'rmw_fastrtps_cpp'
Running cmake because arguments have changed.
==> '. /root/ros2_copy_ws/build/rmw_fastrtps_cpp/cmake__build.sh && /usr/bin/cmake /root/ros2_copy_ws/src/ros2/rmw_fastrtps/rmw_fastrtps_cpp -DBUILD_TESTING=1 -DAMENT_CMAKE_SYMLINK_INSTALL=1 -DCMAKE_INSTALL_PREFIX=/root/ros2_copy_ws/install' in '/root/ros2_copy_ws/build/rmw_fastrtps_cpp'
-- The C compiler identification is GNU 5.4.0
-- The CXX compiler identification is GNU 5.4.0
-- Check for working C compiler: /usr/bin/cc
-- Check for working C compiler: /usr/bin/cc -- works
-- Detecting C compiler ABI info
-- Detecting C compiler ABI info - done
-- Detecting C compile features
-- Detecting C compile features - done
-- Check for working CXX compiler: /usr/bin/c++
-- Check for working CXX compiler: /usr/bin/c++ -- works
-- Detecting CXX compiler ABI info
-- Detecting CXX compiler ABI info - done
-- Detecting CXX compile features
-- Detecting CXX compile features - done
-- Found ament_cmake: 0.0.0 (/root/ros2_copy_ws/install/share/ament_cmake/cmake)
-- Found PythonInterp: /usr/bin/python3 (found suitable version "3.5.2", minimum required is "3")
-- Using PYTHON_EXECUTABLE: /usr/bin/python3
-- Override CMake install command with custom implementation using symlinks instead of copying resources
-- Found fastrtps_cmake_module: 0.0.0 (/root/ros2_copy_ws/install/share/fastrtps_cmake_module/cmake)
-- Found rmw: 0.0.0 (/root/ros2_copy_ws/install/share/rmw/cmake)
-- Found rosidl_generator_cpp: 0.0.0 (/root/ros2_copy_ws/install/share/rosidl_generator_cpp/cmake)
-- Found rosidl_typesupport_introspection_c: 0.0.0 (/root/ros2_copy_ws/install/share/rosidl_typesupport_introspection_c/cmake)
-- Found rosidl_typesupport_introspection_cpp: 0.0.0 (/root/ros2_copy_ws/install/share/rosidl_typesupport_introspection_cpp/cmake)
-- Found rosidl_typesupport_cpp: 0.0.0 (/root/ros2_copy_ws/install/share/rosidl_typesupport_cpp/cmake)
-- Found ament_lint_auto: 0.0.0 (/root/ros2_copy_ws/install/share/ament_lint_auto/cmake)
Error parsing '/root/ros2_copy_ws/src/ros2/rmw_fastrtps/rmw_fastrtps_cpp/package.xml':
File "/root/ros2_copy_ws/install/share/ament_cmake_core/cmake/core/package_xml_2_cmake.py", line 141, in <module>
main()
File "/root/ros2_copy_ws/install/share/ament_cmake_core/cmake/core/package_xml_2_cmake.py", line 56, in main
raise e
File "/root/ros2_copy_ws/install/share/ament_cmake_core/cmake/core/package_xml_2_cmake.py", line 53, in main
package = parse_package_string(args.package_xml.read())
File "/usr/lib/python3.5/encodings/ascii.py", line 26, in decode
return codecs.ascii_decode(input, self.errors)[0]
UnicodeDecodeError: 'ascii' codec can't decode byte 0xc3 in position 409: ordinal not in range(128)
CMake Error at /root/ros2_copy_ws/install/share/ament_cmake_core/cmake/core/ament_package_xml.cmake:94 (message):
execute_process(/usr/bin/python3
/root/ros2_copy_ws/build/rmw_fastrtps_cpp/ament_cmake_core/package.cmake)
returned error code 1
Call Stack (most recent call first):
/root/ros2_copy_ws/install/share/ament_cmake_core/cmake/core/ament_package_xml.cmake:49 (_ament_package_xml)
/root/ros2_copy_ws/install/share/ament_lint_auto/cmake/ament_lint_auto_find_test_dependencies.cmake:30 (ament_package_xml)
CMakeLists.txt:72 (ament_lint_auto_find_test_dependencies)
-- Configuring incomplete, errors occurred!
See also "/root/ros2_copy_ws/build/rmw_fastrtps_cpp/CMakeFiles/CMakeOutput.log".
<== Command '. /root/ros2_copy_ws/build/rmw_fastrtps_cpp/cmake__build.sh && /usr/bin/cmake /root/ros2_copy_ws/src/ros2/rmw_fastrtps/rmw_fastrtps_cpp -DBUILD_TESTING=1 -DAMENT_CMAKE_SYMLINK_INSTALL=1 -DCMAKE_INSTALL_PREFIX=/root/ros2_copy_ws/install' failed in '/root/ros2_copy_ws/build/rmw_fastrtps_cpp' with exit code '1'
I looked at the culprit package.xml file and found the following snippet as the issue:
<maintainer email="ricardogonzalez@eprosima.com">Ricardo González</maintainer>
I could figure it out only because it has an á
which is usually not present in python’s unicode decoder. Changing the á
to a regular a
- fixed the error, and rest of the source code compiled perfectly.
Sincere apologies to Ricardo for changing your name. (@richiprosima )
