Hello, I was trying to install the ROS2 according to the instruction here: GitHub - ros2/ros2: The Robot Operating System, is a meta operating system for robots.
Everything was fine until the section “Get the ROS2 code”
mkdir -p ~/ros2_ws/src
cd ~/ros2_ws
wget https://raw.githubusercontent.com/ros2/ros2/release-latest/ros2.repos
vcs import src < ros2.repos
when I try to execute the last command, I get this error:
$ vcs import src < ros2.repos
stty: stdin isn’t a terminal
Video Contact Sheet *NIX v1.13.2, (c) 2007-2014 Toni Corvera
Unable to locate DejaVu Sans font. Falling back to helvetica.
File “import” doesn’t exist
File “src” doesn’t exist
Anyone knows why?
Another question is, what’s the difference between building from binariy packages and building from source ?
If I want to build a ROS1<->2 bridge, then I have to build from source right?
(For the website maintainer:
You might want to consider adding “–user” in the following instruction:
python3 -m pip install empy setuptools nose vcstool pep8 pydocstyle pyflakes flake8 mock coverage
in case that any newbies like me who doesn’t have root permission, to have problems installing.)
