Talker example issue with Beta 1
Hi Dirk,
I should have stated the difference
For ./talker error message was terminate called after throwing an instance of ‘Poco::LibraryLoadException’ what(): Cannot load library
I did install Poco
libpoco-dev is already the newest version (1.3.6p1-5.1build1).
libpocofoundation9v5 is already the newest version (1.3.6p1-5.1build1).
libpocofoundation9v5-dbg is already the newest version (1.3.6p1-5.1build1).
I didn’t not install # dependencies for testing and # dependencies for fastrtps
For ./talker__rmw-connext-cpp as shown above
Thanks for the pointer on test_results. These are the results:
Summary: 9962 tests, 9 errors, 85 failures, 24 skipped
Here are the list of errors
build/demo_nodes_cpp/test_results/demo_nodes_cpp/test_tutorial_add_two_ints_server_add_two_ints_client__rmw_connext_cpp.xunit.xml: 1 tests, 0 skipped, 1 errors, 0 failures
build/demo_nodes_cpp/test_results/demo_nodes_cpp/test_tutorial_add_two_ints_server_add_two_ints_client_async__rmw_connext_cpp.xunit.xml: 1 tests, 0 skipped, 1 errors, 0 failures
build/demo_nodes_cpp/test_results/demo_nodes_cpp/test_tutorial_list_parameters__rmw_connext_cpp.xunit.xml: 1 tests, 0 skipped, 1 errors, 0 failures
build/demo_nodes_cpp/test_results/demo_nodes_cpp/test_tutorial_list_parameters_async__rmw_connext_cpp.xunit.xml: 1 tests, 0 skipped, 1 errors, 0 failures
build/demo_nodes_cpp/test_results/demo_nodes_cpp/test_tutorial_parameter_events__rmw_connext_cpp.xunit.xml: 1 tests, 0 skipped, 1 errors, 0 failures
build/demo_nodes_cpp/test_results/demo_nodes_cpp/test_tutorial_parameter_events_async__rmw_connext_cpp.xunit.xml: 1 tests, 0 skipped, 1 errors, 0 failures
build/demo_nodes_cpp/test_results/demo_nodes_cpp/test_tutorial_set_and_get_parameters__rmw_connext_cpp.xunit.xml: 1 tests, 0 skipped, 1 errors, 0 failures
build/demo_nodes_cpp/test_results/demo_nodes_cpp/test_tutorial_set_and_get_parameters_async__rmw_connext_cpp.xunit.xml: 1 tests, 0 skipped, 1 errors, 0 failures
build/demo_nodes_cpp/test_results/demo_nodes_cpp/test_tutorial_talker_listener__rmw_connext_cpp.xunit.xml: 1 tests, 0 skipped, 1 errors, 0 failures
Most of the failures were related to the
build/intra_process_demo/test_results/intra_process_demo/test_demo_cyclic_pipeline__rmw_connext_cpp.xunit.xml: 1 tests, 0 skipped, 0 errors, 1 failures
build/osrf_pycommon/test_results/osrf_pycommon/nosetests.xunit.xml: 32 tests, 0 skipped, 0 errors, 1 failures
build/pendulum_control/test_results/pendulum_control/test_demo_pendulum_teleop__rmw_connext_cpp.xunit.xml: 1 tests, 0 skipped, 0 errors, 1 failures
build/test_communication/test_results/test_communication/test_publisher_subscriber__BoundedArrayNested__rclcpp__rclpy__rmw_connext_cpp__rmw_fastrtps_cpp.xunit.xml: 1 tests, 0 skipped, 0 errors, 1 failures
To (Most of the failure cases are here)
build/test_communication/test_results/test_communication/test_publisher_subscriber__StaticArrayPrimitives__rclpy__rmw_fastrtps_cpp__rmw_connext_cpp.xunit.xml: 1 tests, 0 skipped, 0 errors, 1 failures
build/test_communication/test_results/test_communication/test_requester_replier__Primitives__rclcpp__rclpy__rmw_fastrtps_cpp.xunit.xml: 1 tests, 0 skipped, 0 errors, 1 failures
build/test_communication/test_results/test_communication/test_requester_replier__Primitives__rclpy__rmw_fastrtps_cpp.xunit.xml: 1 tests, 0 skipped, 0 errors, 1 failures
Thanks
Vince
