Where about in RosWiki should a write a guide on using ROS with Anaconda
Hello I was going to write a short blurb on how to get anaconda to work on a system with ROS installed. I was wondering where in the wiki would be a good place to put it?
Thanks
I can’t think of a specific place, but maybe in the article about IDEs? http://wiki.ros.org/IDEs
I write many gist files in github, they get indexed in google, so if you clearly write something with the keywords “anaconda ros” it may be found easily.
Good luck!
I’d recommend somewhere like http://wiki.ros.org/Anaconda Don’t worry too much about the specific name. It can always be moved at a later date.
