Announcing ROS 2 Easy Mode
Hi everyone,
When using ROS 2 in its default configuration, you may encounter challenges in the following scenarios:
  • Lossy Wi-Fi networks
  • Network congestion
  • Large data transmission (e.g., video streams, LIDAR data)
  • Discovery issues in large-scale deployments or environments without multicast support
We’re excited to announce ROS 2 Easy Mode, a new feature designed to optimize ROS 2 and Fast DDS for these situations with just a single configuration setting. This enhancement significantly improves performance and simplifies the out-of-the-box experience for users.
Want to try it right away? Download our ROS 2 distribution, Vulcanexus, and explore the benefits of Easy Mode today. This feature will also be included in the official ROS 2 distribution soon.
Documentation and Resources:
Have questions? Feel free to reach out!
Thanks for making this available @Jaime_Martin_Losa et al.
To enable this feature the user only needs to set the environment variable ROS2_EASY_MODE=<ip>.
Hm. ROS_MASTER_URI was already taken I understand? :slight_smile:
Edit:
could you say something about which distributions this will be supported in? Only Rolling, or will it be backported?
It is not exactly the same, as we create a discovery server per machine, but yes.
Hi @gavanderhoorn
This feature is already available in Vulcanexus Jazzy and will be available in ROS 2 Rolling and the upcoming ROS 2 Kilted.
It cannot be backported as this is something coming in Fast DDS v3, which breaks API compatibility with Fast DDS v2.14 (ROS 2 Jazzy).
Hi, I browse the doc quickly (and maybe lost some thing), as @gavanderhoorn said, I would also like to know, create a discovery server per machine
What will happen if that machine <host_a_ip> just down after some running?
If we have more questions, where do you suggest to disscuss?
Hi @MiaoDX
Nothing, at that point, you have a network of redundant discovery servers.
Is it available in Kilted right now? Not needing multi-cast would be very helpful.
