@nuclearsandwich Now that you probably have even better insight for the maintenance cost of snapshots, do you have any update for the plan? E.g. Is 6-month still the plan? I see for Kinetic there’s even 2018-12, more than 1.5 years ago, which is great.
Also, if possible, what turned out to be the most costly if you don’t mind talking about? Disk, labor or else?
I found the snapshot very helpful for building our production system. It helps us to remove one big unknown for sure. It’s just 6-month period is a little bit of mental burden as it might be a bit too quick for my team (but from security standpoint it may be practically sufficient. Discussion is active in my team).
