Technically that is not true. In RTI the message hierarchy is retained by the intermediate representation FlatMessage.
Anyway, I am not interested to publish the type erased messages, only to parse those I receive, therefore I will not implement that feature in the future.
Summarizing, RTI and RBF have a 80% overlap in functionalities and user should just choose the one that better adapt to his/her needs.
I am not familiar with neither RTI nor RBF. But do you think it could be used in a proxy like rosserial_server? Currently it uses a service that calls a Python node to deal with messages type at runtime.
If you point me to some instances in the code where that is done I could give you a definite answer but I suspect yes.
RBF can send (almost) any messages that python can.
RBF does not use Python. There’s an implementation of a description provider (this is the interface that looks up the message definition, md5 sum etc.) that calls the genmsg python package methods using Python 2.7 in C++. However, I’ve since implemented a native C++ version of the message lookup which is the default. The python version can be enabled as an option in the CMakeLists.txt but it’s disabled by default.
EDIT:
I’ve found the code I assume you were referring to. Yes, the description provider in RBF could be used to get the information. BUT it looks up the message definition on the local machine. The service server for rosserial_server may run on a different computer and that computer may have messages that don’t exist on the computer running the rosserial_server. So, the actual answer is NO, the behavior can not be replicated without a service server. RBF would allow implementing that service server in C++ but I don’t see anything to gain from that.
I see that the message definition is missing. But then, how RTI and Plotjuggler manage to get this information? Because they can run on system with custom messages without re-building them.
A small example on how to use RTI like the one RBF has in its README would be nice
A publisher is created from a topic_tools::ShapeShifter this is created from the name and the message type from the rosserial client and the message definition returned by the Python service.
I have never though of that use case before, Python service on another computer with more message definition. I am not sure this feature is really leveraged in real use cases.
Thank you, I did not look for a separate repository for the tests and examples
I ask these questions because I am thinking of writing something close to rosserial but for another user case so I will think about adding the definition. Thanks.
What you could do is first look up the message definition on the local machine using the integrated description provider and if that fails, you could fall back to a service call. The description provider will also cache message definitions which in the case of dependencies significantly improves performance if you look up multiple messages. Hence, you should reuse the instance of the description provider.
I’ve just released some changes including some significant optimizations.
The updated benchmark can be found here. @facontidavide you should take a look at the benchmark code and whether you still have some changes because I got significantly higher timings for the image and pointcloud messages. I have built ros_type_introspection from source in the latest version available on GitHub so there might be some issue with the benchmark code.
Here are the updated results (RTI=ros_type_introspection, RBF=ros_babel_fish):
Benchmark Time CPU Iterations
RTI_ParseMessageDefinition<geometry_msgs::Pose> 76 us 76 us 9124
RBF_ParseMessageDefinition<geometry_msgs::Pose> 46 us 46 us 15431
RTI_ParseMessageDefinition<sensor_msgs::JointState> 172 us 172 us 4087
RBF_ParseMessageDefinition<sensor_msgs::JointState> 104 us 104 us 6800
RTI_ParseMessageDefinition<nav_msgs::Odometry> 324 us 324 us 2188
RBF_ParseMessageDefinition<nav_msgs::Odometry> 261 us 261 us 2716
RTI_ParseMessageDefinition<tf::tfMessage> 217 us 217 us 3113
RBF_ParseMessageDefinition<tf::tfMessage> 170 us 170 us 4137
RTI_ParseMessageDefinition<sensor_msgs::PointCloud2> 294 us 294 us 2434
RBF_ParseMessageDefinition<sensor_msgs::PointCloud2> 148 us 148 us 4709
RTI_ParseMessageDefinition<sensor_msgs::Image> 185 us 185 us 3714
RBF_ParseMessageDefinition<sensor_msgs::Image> 131 us 131 us 5335
RTI_ParseMessage<geometry_msgs::Pose> 334 ns 334 ns 2078223
RBF_ParseMessage<geometry_msgs::Pose> 349 ns 349 ns 2044464
RTI_ParseMessage<sensor_msgs::JointState> 581 ns 581 ns 1215252
RBF_ParseMessage<sensor_msgs::JointState> 335 ns 335 ns 2009207
RTI_ParseMessage<nav_msgs::Odometry> 1159 ns 1159 ns 614297
RBF_ParseMessage<nav_msgs::Odometry> 1009 ns 1009 ns 695203
RTI_ParseMessage<tf::tfMessage> 1946 ns 1946 ns 353818
RBF_ParseMessage<tf::tfMessage> 1889 ns 1889 ns 377316
RTI_ParseMessage<sensor_msgs::PointCloud2> 8827 ns 8826 ns 79320
RBF_ParseMessage<sensor_msgs::PointCloud2> 586 ns 586 ns 1219825
RTI_ParseMessage<sensor_msgs::Image> 62604 ns 62604 ns 11197
RBF_ParseMessage<sensor_msgs::Image> 354 ns 354 ns 2012739
