Catkin installation fails in CI Docker
Has anyone seen recently build failures in melodic CI?
Excerpt from step “11. Build Dockerfile - build and install”:
Summary
**19:38:56** Invoking 'apt-get install -q -y -o Debug::pkgProblemResolver=yes build-essential python3 ros-melodic-catkin ros-melodic-pluginlib ros-melodic-rosconsole ros-melodic-roscpp ros-melodic-roslib ros-melodic-rostest'
**19:38:56** Reading package lists...
**19:38:57** Building dependency tree...
**19:38:57** Reading state information...
**19:38:57** Starting pkgProblemResolver with broken count: 5
**19:38:57** Starting 2 pkgProblemResolver with broken count: 5
**19:38:57** Investigating (0) ros-melodic-catkin:amd64 < none -> 0.7.26-1bionic.20200529.204155 @un puN Ib >
**19:38:57** Broken ros-melodic-catkin:amd64 Depends on python-catkin-pkg:amd64 < none | 0.4.21-100 @un uH > (> 0.4.3)
**19:38:57** Considering python-catkin-pkg:amd64 1 as a solution to ros-melodic-catkin:amd64 10010
**19:38:57** Re-Instated tzdata:amd64
**19:38:57** Re-Instated python-dateutil:amd64
**19:38:57** Re-Instated sgml-base:amd64
**19:38:57** Re-Instated xml-core:amd64
**19:38:57** Re-Instated docutils-common:amd64
**19:38:57** Re-Instated python-roman:amd64
**19:38:57** Re-Instated python-docutils:amd64
**19:38:57** Re-Instated python-pyparsing:amd64
**19:38:57** Reinst Failed early because of python2:amd64
I just started noticing these as well.
Seemingly unrelated to whatever the CI was supposed to test.
I’m wondering whether it is something to Build/CI failures with ros-testing repository enabled?.
@nuclearsandwich is something up with Catkin this time?
Example failure:
Invoking 'apt-get install -q -y -o Debug::pkgProblemResolver=yes build-essential python3 ros-melodic-catkin libboost-all-dev ros-melodic-geometry-msgs ros-melodic-joint-state-publisher-gui ros-melodic-message-generation ros-melodic-moveit-core ros-melodic-moveit-kinematics ros-melodic-moveit-ros-planning ros-melodic-pluginlib ros-melodic-robot-state-publisher ros-melodic-roscpp ros-melodic-rviz ros-melodic-std-msgs ros-melodic-tf-conversions ros-melodic-urdf ros-melodic-xacro'
  Considering python-catkin-pkg:amd64 1 as a solution to ros-melodic-catkin:amd64 10038
I was just about to post on the other thread. It was a very similar issue and is resolved by catkin-pkg 0.4.22 which has been imported by the build farms and should be uploading to packages.ros.org shortly.
Apologies for repeating myself then, but would there be any way to test for this?
Are there any other packages which could be affected by the same problem?
I made a reply in Build/CI failures with ros-testing repository enabled? which I think has more context. I’m not sure what the etiquette is on combining the two threads or discontinuing this one.
Thanks, it seems to be solved now :wink:
