I’m trying to create something that needs to dynamically manage and spawn nodes. I’m launching a LaunchDescription
but running into an issue where if a parameter is set after launching, and the node crashes and respawns, the parameter gets reset to its “default” value specified in the LaunchDescription
This is understandable why this happens, but is there a clean way to update the LaunchDescription after it launches? For example something like:
launch_description = LaunchDescription([
Node(
package='foo_package',
executable='foo_node,
output='screen',
name='foo_node',
respawn=True,
respawn_delay=2,
parameters=[{"my_param": "my_value"}],
service = LaunchService()
service.include_launch_description(launch_description)
service.run()
But then in some thread, be able to do something like:
service.launch_description[0].parameters[0] = {"my_param": "my_value_new"}
with the expectation that if foo_node
gets respawned, it now gets respawned with my_param
set to "my_value_new"
Thanks!
