I’m currently near the end of a rewrite of robot_state_publisher
. There are a few goals to this rewrite:
- Simplify the code, as it was too complicated before.
- Bring the code up to modern ROS 2 standards.
- Reinstate some of the features that were missed during the original port.
- Allow the
robot_description
to be changed during runtime.
I want to discuss the last point a bit further, and get some thoughts from the community. To start with, I want to make it clear that I am not trying to solve the entire problem of “make a URDF changeable across a robot”. That involves a lot more pieces than just robot_state_publisher
. However, adding some level of dynamicity to robot_state_publisher
at least solves part of the problem.
With ROS 2, we have a bunch of tools that make solving the problem of a dynamic robot_description
possible. We have the ability to get and set parameters (and get notified when they change), we have the ability to publish transient_local
(latched) topics, etc. Here are a few different ways I’ve though about to make the robot_description
changeable:
Make the
robot_description
a required parameter during node startup. To access therobot_description
, consumers have to do the equivalent ofros2 param get /robot_state_publisher robot_description
, and to change it, the equivalent ofros2 param set /robot_state_publisher robot_description <new_description>
.- Pros: Most like ROS 1 in concept. Makes
the “owner” of therobot_description
. Uses existing ROS 2 parameter infrastructure to the fullest. - Cons: Most unlike existing ROS 2 (meaning we have to make changes to things like rviz2). Makes
. Therobot_description
is no longer anonymous; consumers have to know the name of therobot_state_publisher
node.
Make the
robot_description
a required parameter during node startup. Publish the currentrobot_description
on a latched topic. To changerobot_description
has to be run.- Pros: Uses the parameter infrastructure for initial configuration and setting. Keeps the topic “anonymous” for getting the
robot_description
. Doesn’t require changes to RViz2. - Cons: Setting the
robot_description
isn’t anonymous; the name of the node is necessary. Is a bit inconsistent, in that getting and setting therobot_description
is done via different mechanisms.
Make the
robot_description
on a latched topic. Provide a service to allow changes to therobot_description
, which would then propagate to the topic.- Pros: Makes getting the
robot_description
anonymous, sorobot_state_publisher
no longer “owns” therobot_description
. Same for the service. RViz2 doesn’t have to change. - Cons: Only uses parameters as an “initialization” mechanism; doesn’t take full advantage of the parameters infrastructure.
Make the
robot_description
not provided during node startup.robot_state_publisher
would do nothing until something called a service to set therobot_description
, at which point it would start publishing transforms. Changes to therobot_description
would be done via the same service call. There would be a latched topic that publishes the current state ofrobot_description
for downstream consumers.- Pros: Ensures that
isn’t the “owner” of therobot_description
is no longer standalone; it needs an external “something” to tell it the initialrobot_description
These are the options I’ve thought of; there are some others in this same vein. The ros2-refactor currently implements solution 2, but I’m looking for opinions from the community on any of these options, or an option I haven’t thought of. Thoughts?
Ping @jacob, @sloretz, @IanTheEngineer, @peci1, @karsten as a (non-exhaustive) list of people who have expressed interest in this topic.
