Hi , I’m trying to start a discussion about what type should uint8[]
be converted to
Background:
In ROS1 , `uint8[]` is transported into `string` while other `uint` is transported to `list` .
In Ros 2 , all the `uint` types are transported into `builtins.list`.
But in our tests , we find that when we transport the images using `uint8[]` , the `builtins.list` type shows high latency , cause the transport to `list` in python takes a lot of time
So we changed some codes and transport the `uint8[]` type to `builtins.bytes` and test again , the result is much better
Test comparison result:
transport 2M image in ROS2 to type `builtins.list` in python : 270ms
transport 2M image in ROS2 to type 'builtins.bytes' in python : 10ms
issue description :
In our program , low time latency is very important , and bytes is more suitable in python too .
So whether it's better to let the `uint8[]` type convert to `builtins.bytes` instead of `builtins.list` in ROS2.
(Just like in ROS)
Our attempts
1. change the code in rosidl to make `uint8[]` convert to `builtins.bytes` directly
this work well and the time latency is much lower than the original `builtins.list` type
but we don't know whether this modification will effect the upper application and algorithm
2. trying to add a new Primitive type like `imguint8` to convert to `bytes` and `uint8` is still `list` , but i have some problems in codes , and it's really complicated
So if the attempt 1 seems good to you , we’d like just use the attempt 1 in our code .
But if the builtins.list
is important for some upper application or algorithm in existing codes , then we will try to finish attempt 2
link to the attempt 2
Opinion Invitation:
@dirk-thomas
@marguedas
Appreciating your opinion !
