I am customizing the .yaml file inside config folder. Here my config file:
arm:
type: ur10
sensors:
# break_beam_1:
# type: break_beam
# pose:
# xyz: [1.6, 2.25, 0.91]
# rpy: [0, 0, 'pi']
# proximity_sensor_1:
# type: proximity_sensor
# pose:
# xyz: [0.9, 2.6, 0.914]
# rpy: [0, 0, 0]
logical_camera_1:
type: logical_camera
pose:
xyz: [-0.3, 0.15, 1.92]
rpy: [0, 'pi/2', 0]
# logical_camera_2:
# type: logical_camera
# pose:
# xyz: [1.6, 2.25, 1.92]
# rpy: [0, 'pi/2', 0]
# laser_profiler_1:
# type: laser_profiler
# pose:
# xyz: [1.21, 4, 1.64]
# rpy: ['-pi', 'pi/2', 'pi/2']
I only want to have one camera or at least 2 and the arm for now but I am having problems launching gazebo.
This is what I am having:
[ INFO] [1485780266.491014687]: Finished loading Gazebo ROS API Plugin.
[ INFO] [1485780266.491853663]: waitForService: Service [/gazebo/set_physics_properties] has not been advertised, waiting...
[INFO] [WallTime: 1485780266.508732] [0.000000] Loading model xml from ros parameter
[INFO] [WallTime: 1485780266.514374] [0.000000] Waiting for service /gazebo/spawn_urdf_model
[INFO] [WallTime: 1485780268.627435] [0.000000] Calling service /gazebo/spawn_urdf_model
gzserver: symbol lookup error: /opt/ros/indigo/lib/libROSLogicalCameraPlugin.so: undefined symbol: _ZN2tf20TransformBroadcasterC1Ev
Service call failed: transport error completing service call: unable to receive data from sender, check sender's logs for details
[INFO] [WallTime: 1485780268.639078] [0.000000] Waiting for service /gazebo/set_model_configuration
[INFO] [WallTime: 1485780268.640444] [0.000000] temporary hack to **fix** the -J joint position option (issue #93), sleeping for 1 second to avoid race condition.
================================================================================REQUIRED process [gazebo-4] has died!
process has died [pid 16150, exit code 127, cmd /opt/ros/indigo/lib/gazebo_ros/gzserver -u -e ode -r --record_path=/home/jlamperez/.ariac/log/gazebo /tmp/ariac/gear.world joint_states:=ariac/joint_states __name:=gazebo __log:=/home/jlamperez/.ros/log/d4c89eec-e6e9-11e6-b7d1-5404a68aab23/gazebo-4.log].
log file: /home/jlamperez/.ros/log/d4c89eec-e6e9-11e6-b7d1-5404a68aab23/gazebo-4*.log
Initiating shutdown!
[arm_controller_spawner-10] killing on exit
[joint_state_controller_spawner-9] killing on exit
File "/opt/ros/indigo/lib/controller_manager/controller_manager", line 63, in <module>
controller_manager_interface.load_controller(c)
File "/opt/ros/indigo/lib/python2.7/dist-packages/controller_manager/controller_manager_interface.py", line 64, in load_controller
rospy.wait_for_service('controller_manager/load_controller')
File "/opt/ros/indigo/lib/python2.7/dist-packages/rospy/impl/tcpros_service.py", line 149, in wait_for_service
[fake_joint_calibration-8] killing on exit
time.sleep(0.3)
KeyboardInterrupt
However, if I uncomment the laser_profiler sensor lines, gazebo launches correctly.
Is there a minimum number of sensors in config file or it is necessary to set the laser_profiler?
Regards
