Description:
This pull request aims to enhance the functionality by porting the ROS1 service set_model_configuration to ROS2 (Humble). Upon launching the empty.world, users gain the ability to specify initial joint angles, facilitating entity spawning at custom configurations.
Changes Made:
Ported ROS1 Service to ROS2 (Humble):
The primary focus of this pull request is the migration of the ROS1 service to ROS2 (Humble), ensuring compatibility with the latest ROS ecosystem advancements.
How to Test:
Set up ROS2 (Humble) dependencies in your environment.
Build and compile the project with the latest changes.
Launch empty. world in your ROS2 environment.
Write a service call to test the functionality: (check the example)
void SetModelConfiguration::set_model_configuration()
set_model_configuration_client_ =
this->create_client<gazebo_msgs::srv::SetModelConfiguration>("/gazebo/set_model_configuration");
if (set_model_configuration_client_->service_is_ready())
auto srv = std::make_shared<gazebo_msgs::srv::SetModelConfiguration::Request>();
srv->model_name = std::string("<>");
srv->urdf_param_name = std::string("robot_description");
std::map<std::string, double> joint_map = {
{"<>", 0.0}, {"<>", 1.56}, {"<>", -3.0},
for (auto & it : joint_map)
srv->joint_names.push_back(it.first);
srv->joint_positions.push_back(it.second);
auto setmodel_future_ = set_model_configuration_client_->async_send_request(srv);
else
RCLCPP_WARN(
get_logger(),
"[SetSimulationConfiguration]: not calling service using a callback, service not ready!");
// <> : Enter the respective arguments, this example is for a 12DOF robot.
Request maintainers of gazebo_ros_pkgs to merge the pull request. @davetcoleman
