How to edit PlanningScene collision checking method to add objects to the environment?
#1
Hello all,
I’ve been using MoveIt! to add an extra constraint during the collision checking process. To do this, I add a rectangular prism to the environment based on the position of the End Effector of my manipulator. I planned on adding the geometry by the method:
processCollisionObjectMsg()
I would call this method from:
void PlanningScene::checkCollision(const collision_detection::CollisionRequest& req,
collision_detection::CollisionResult& res,
const robot_state::RobotState& kstate) const
However, checkCollision is const and processCollisionObjectMsg() is not, and thus is uncallable. I am using OMPL (and the default fcl collision detection) to plan my paths. What is a good way for me add a simple rectangular prism into the collision environment ? Note, each rectangular prism should only apply to its respective sample; one sample’s rectangular prism should not affect another sample’s collision checking.
#2
I’ve found the answer!
There’s a similar method
without a constant robotstate that calls the checkCollision method I mentioned above in planning_scene. RobotState can be altered to include an attached Body, which will be used for collision checking (make sure to call update() on the robot state afterwards).
I imagine you could create an imaginary link frame if you wanted to add the object to the robot for full robot collision-detection against the primitive.
