For some reason, I have to compile ROS1 from the source.
I just follow the steps here: http://wiki.ros.org/kinetic/Installation/Source
However, when I execute ./src/catkin/bin/catkin_make_isolated --install -DCMAKE_BUILD_TYPE=Release
, I get an error about boost: No rule to make target '/usr/lib/libboost_thread.so'
My system is Ubuntu and I’ve installed boost: apt install libboost-all-dev
. I found all libboost files here: /usr/lib/x86_64-linux-gnu
. This is why it can’t find boost in usr/lib/
I just want to know how to tell ROS to find boost at some specific path?
I’ve tried export ROS_BOOST_ROOT=/usr/lib/x86_64-linux-gnu
and export ROS_BOOST_PATH=/usr/lib/x86_64-linux-gnu
but it doesn’t work.
