Problem in installation of ros kinetic
I followed the steps mentioned in the ros installation document. when i run sudo apt-get update ,I get following error
W: The repository ‘http://packages.ros.org/ros/ubuntu $ Release’ does not have a Release file.
N: Data from such a repository can’t be authenticated and is therefore potentially dangerous to use.
N: See apt-secure(8) manpage for repository creation and user configuration details.
E: Failed to fetch http://packages.ros.org/ros/ubuntu/dists/$/(lsb_release/binary-i386/Packages 404 Not Found [IP: 2600:3404:200:237::2 80]
E: Some index files failed to download. They have been ignored, or old ones used instead.
please help with solution.
Thanks for your question. However, please ask your question on http://answers.ros.org following our support guidelines: http://wiki.ros.org/Support
ROS Discourse is for news and general interest discussions. ROS Answers provides a forum which can be filtered by tags to make sure the relevant people are included and not overload everyone.
Also please ready through the guidelines for asking a good question. In particular please provide enough background to reproduce your problem, including your platform, steps taken prior to the error, as well as links to any instructions you’re following.
