@tomoyafujita Thank you for talking the time to go over this
according to the implementation, it generates the new dependency for ros2_spdlog_logger
spdlog
and fmt
and as far as i see the implementation, this is for configuring spdlog
with different sink or managing the logger threads in ros2_spdlog_logger
Sort of, I had two goals here basically:
- Replace
rcl/rcutils
logging backend entirely with spdlog
. I wanted to use spdlog
since it’s pretty easy to use and safe (much safer than vsnprintf
, which already caused me too many headaches with segfaults…), and to try out some custom spdlog
sinks easily, like this one;
- But ensure I couldn’t break compatibility with any existing code that relies on the normal
rclcpp
macros (meaning I needed somehow to maintain the vsnprintf
calls to format the messages, but only in these cases), but still have those messages being somehow forwarded to spdlog to leverage those data sinks.
Since the backend is just spdlog, it’s very easy to add new data sinks to process the messages (even ones that were previously using rclcpp logging macros).
You can even easily setup per-logger data sinks (e.g. logging to different files on different loggers), which I think is pretty useful at times.
i think that if the application wants to use the specific logger, they can use it in the application with the dependency without any interfaces such as rcl_logging_interface
that is the most performative for user application, i think.
While this is true, I do feel like getting any customization out of the logging system is quite cumbersome currently. If I want a custom backend I would need to make my own based off of rcl_logging_interface
, and recompile rcl to link to my custom backend, which doesn’t seem like the most practical approach.
I would like for there to be some sort of easier API I could leverage in my node to add it, but I don’t know how much portability / modularity you would lose out on with something like this.
we actually have our own proprietary logging backend, which is lock-free with using CAS
instruction, in-memory logging implementation.
but we have that implementation behind rcl_logging_interface
as well, all this is for application modularity and portability depends on the use cases and business logics. (i believe this is why and what interfaces are for.)
I assume in that case you replaced the rcl_logging_spdlog with you own external library. But I do have a couple of questions about that:
- Did you notice any meaningful performance difference by having this lock-free implementation here? Since all logging calls from rclcpp are under a
global mutex, I would assume that this would be the bigger bottleneck. In this implementation, I replaced it entirely with a thread-safe handler, that formats the message and forwards it to spdlog, which should improve multi-threaded performance.
- How do you customize your logging backend – do you also use the config_file parameter you mentioned during initialization to set everything up?
besides, if that is the problem is how flexibly to configure the logging backend behind rcl_logging_interface
, i would suggest that we probably want to consider ROS 2 logging configuration spec below.
so that we can have abstracted ROS 2 generic configuration that can be mapped to the backend specific configuration, and we can configure the backend logging implementation via rcl_logging_interface
. i actually am interested in this development and discussion, so if you are interested, maybe we can discuss on this.
I think this is a ongoing discussion for some time right?
From my limited experience, I think there would be some benefit towards promoting spdlog to be used as the main logging backend (as it seemed to be suggested in that issue as well, though definitely not in the way I did it), since I feel like it’s a bit underwhelming to just use it to log to files
But I wouldn’t mind contributing towards improving the logging system in some way or another if you feel like I could be of help, feel free to reach out
