I’m not an expert on ROS2. I’m trying to achieve the following from a Java application (using ros2-java). Mind that actions are not (yet) supported in ros2-java.
- Send navigation goal to a navigation goal
- Determine whether the robot arrived to the navigation goal.
I achieved the first point by using a publisher to post a message on move_base_simple/goal
, which gets picked up by an action client (/bt_navigator_rclpp_node
When I post to move_base_simple/goal
, the robot calculates a route and drives to the given coordinates, which is great.
However, I cannot manage to determine whether the robot is finished with its navigation action.
In the console, messages such as ‘Navigation succeeded’ are thrown by /tmp/binarydeb/ros-dashing-nav2-bt-navigator-0.2.6/src/bt_navigator.cpp:navigateToPose:206
But these messages are not thrown in the topic /NavigateToPose/_action/status
, where gives the following data:
/niels@laptop:~$ ros2 topic echo /NavigateToPose/_action/status
status_list:
- goal_info:
goal_id:
uuid: [252, 126, 236, 51, 95, 235, 87, 156, 252, 98, 102, 225, 45, 118, 160, 13]
stamp:
sec: 1586252361
nanosec: 703727920
status: 6
- goal_info:
goal_id:
uuid: [41, 55, 100, 99, 191, 18, 167, 153, 57, 243, 1, 90, 68, 37, 116, 3]
stamp:
sec: 1586252365
nanosec: 466342743
status: 4
- goal_info:
goal_id:
uuid: [236, 4, 47, 230, 142, 173, 162, 72, 214, 90, 203, 227, 250, 192, 60, 180]
stamp:
sec: 1586253246
nanosec: 14198261
status: 4
- goal_info:
goal_id:
uuid: [15, 142, 123, 28, 148, 183, 150, 200, 227, 38, 255, 190, 197, 21, 148, 231]
stamp:
sec: 1586253278
nanosec: 662794261
status: 4
I get similar (but more frequent) data on topic /FollowPath/_action/status
. Can I assume that the status codes correspond with the list that is visible on this page for ROS1? This would mean that status ‘4’ equals SUCCEEDED
. However, status code 4 gets thrown multiple times, which I find remarkable.
My question, how do I know (for sure) if a navigation goal is succeeded? Is there a certain topic I missed? Or is there a certain service I need to call?
