We have synced another batch of packages for Indigo. There are 6 new packages as well as 53 updated packages. Thank you to all the contributors. The full details are below.
Package Updates for indigo
Added Packages [6]:
- ros-indigo-abseil-cpp: 0.1.2-0
- ros-indigo-libmongocxx-ros: 0.3.6-1
- ros-indigo-marti-status-msgs: 0.3.0-0
- ros-indigo-pheeno-ros: 0.1.1-4
- ros-indigo-pheeno-ros-sim: 0.1.4-0
- ros-indigo-rail-face-detector: 0.0.2-0
Updated Packages [53]:
- ros-indigo-actionlib-lisp: 0.2.9-0 -> 0.2.10-0
- ros-indigo-cl-tf: 0.2.9-0 -> 0.2.10-0
- ros-indigo-cl-tf2: 0.2.9-0 -> 0.2.10-0
- ros-indigo-cl-transforms: 0.2.9-0 -> 0.2.10-0
- ros-indigo-cl-transforms-stamped: 0.2.9-0 -> 0.2.10-0
- ros-indigo-cl-urdf: 0.2.9-0 -> 0.2.10-0
- ros-indigo-cl-utils: 0.2.9-0 -> 0.2.10-0
- ros-indigo-default-cfg-fkie: 0.7.5-0 -> 0.7.6-0
- ros-indigo-grpc: 0.0.2-0 -> 0.0.4-0
- ros-indigo-imagezero: 0.2.3-0 -> 0.2.4-0
- ros-indigo-imagezero-image-transport: 0.2.3-0 -> 0.2.4-0
- ros-indigo-imagezero-ros: 0.2.3-0 -> 0.2.4-0
- ros-indigo-joint-state-publisher: 1.11.14-0 -> 1.11.15-0
- ros-indigo-marti-can-msgs: 0.2.0-0 -> 0.3.0-0
- ros-indigo-marti-common-msgs: 0.2.0-0 -> 0.3.0-0
- ros-indigo-marti-nav-msgs: 0.2.0-0 -> 0.3.0-0
- ros-indigo-marti-perception-msgs: 0.2.0-0 -> 0.3.0-0
- ros-indigo-marti-sensor-msgs: 0.2.0-0 -> 0.3.0-0
- ros-indigo-marti-visualization-msgs: 0.2.0-0 -> 0.3.0-0
- ros-indigo-master-discovery-fkie: 0.7.5-0 -> 0.7.6-0
- ros-indigo-master-sync-fkie: 0.7.5-0 -> 0.7.6-0
- ros-indigo-mongodb-log: 0.1.30-1 -> 0.3.6-1
- ros-indigo-mongodb-store: 0.1.30-1 -> 0.3.6-1
- ros-indigo-mongodb-store-msgs: 0.1.30-1 -> 0.3.6-1
- ros-indigo-multimaster-fkie: 0.7.5-0 -> 0.7.6-0
- ros-indigo-multimaster-msgs-fkie: 0.7.5-0 -> 0.7.6-0
- ros-indigo-node-manager-fkie: 0.7.5-0 -> 0.7.6-0
- ros-indigo-python-trep: 1.0.2-0 -> 1.0.3-0
- ros-indigo-rapid-pbd: 0.1.3-0 -> 0.1.4-0
- ros-indigo-roch: 1.0.13-0 -> 1.0.14-0
- ros-indigo-roch-base: 1.0.14-0 -> 1.0.15-0
- ros-indigo-roch-bringup: 1.0.13-0 -> 1.0.14-0
- ros-indigo-roch-capabilities: 1.0.14-0 -> 1.0.15-0
- ros-indigo-roch-control: 1.0.14-0 -> 1.0.15-0
- ros-indigo-roch-description: 1.0.14-0 -> 1.0.15-0
- ros-indigo-roch-follower: 1.0.13-0 -> 1.0.14-0
- ros-indigo-roch-ftdi: 1.0.14-0 -> 1.0.15-0
- ros-indigo-roch-gazebo: 1.0.11-0 -> 1.0.12-0
- ros-indigo-roch-msgs: 1.0.14-0 -> 1.0.15-0
- ros-indigo-roch-navigation: 1.0.13-0 -> 1.0.14-0
- ros-indigo-roch-rapps: 1.0.13-0 -> 1.0.14-0
- ros-indigo-roch-robot: 1.0.14-0 -> 1.0.15-0
- ros-indigo-roch-safety-controller: 1.0.14-0 -> 1.0.15-0
- ros-indigo-roch-sensorpc: 1.0.14-0 -> 1.0.15-0
- ros-indigo-roch-simulator: 1.0.11-0 -> 1.0.12-0
- ros-indigo-roch-teleop: 1.0.13-0 -> 1.0.14-0
- ros-indigo-roch-viz: 1.0.9-3 -> 1.0.10-0
- ros-indigo-roslisp-common: 0.2.9-0 -> 0.2.10-0
- ros-indigo-roslisp-utilities: 0.2.9-0 -> 0.2.10-0
- ros-indigo-turtlebot-gazebo: 2.2.2-0 -> 2.2.3-0
- ros-indigo-turtlebot-simulator: 2.2.2-0 -> 2.2.3-0
- ros-indigo-turtlebot-stage: 2.2.2-0 -> 2.2.3-0
- ros-indigo-turtlebot-stdr: 2.2.2-0 -> 2.2.3-0
Removed Packages [0]:
- Alexander Tiderko
- Andrew Silva
- Carl
- Chris Burbridge
- Chris Lalancette
- Edmond DuPont
- Elliot Johnson
- Gayane Kazhoyan
- Jarvis Schultz
- Jihoon Lee
- Justin Huang
- Marc Alban
- Marc Hanheide
- Marcus Liebhardt
- Mehdi Tlili
- Nick Hawes
- OSRF
- P. J. Reed
- Shengye Wang
- Zahi Kakish
- dfaconti
- zmk5
