We’re happy to announce 23 new packages and 73 updated packages for Kinetic.
Full details are below. Thank you to all the maintainers and contributors who make these packages available for everyone to use.
Package Updates for kinetic
Added Packages [23]:
- ros-kinetic-cog-publisher: 1.0.1-4
- ros-kinetic-costmap-cspace-msgs: 0.2.0-0
- ros-kinetic-dataspeed-pds: 1.0.2-0
- ros-kinetic-dataspeed-pds-can: 1.0.2-0
- ros-kinetic-dataspeed-pds-msgs: 1.0.2-0
- ros-kinetic-dataspeed-pds-rqt: 1.0.2-0
- ros-kinetic-dataspeed-pds-scripts: 1.0.2-0
- ros-kinetic-flir-ptu-description: 0.2.0-0
- ros-kinetic-flir-ptu-driver: 0.2.0-0
- ros-kinetic-flir-ptu-viz: 0.2.0-0
- ros-kinetic-ibeo-core: 2.0.0-0
- ros-kinetic-magni-viz: 0.3.2-0
- ros-kinetic-map-organizer-msgs: 0.2.0-0
- ros-kinetic-modelica-bridge: 0.1.1-0
- ros-kinetic-mrpt-rbpf-slam: 0.1.6-0
- ros-kinetic-mrpt-slam: 0.1.6-0
- ros-kinetic-mvsim: 0.2.0-0
- ros-kinetic-neonavigation-msgs: 0.2.0-0
- ros-kinetic-planner-cspace-msgs: 0.2.0-0
- ros-kinetic-scratch4robots: 0.0.2-0
- ros-kinetic-spatio-temporal-voxel-layer: 1.1.2-0
- ros-kinetic-towr: 1.2.2-0
- ros-kinetic-trajectory-tracker-msgs: 0.2.0-0
Updated Packages [73]:
- ros-kinetic-diff-drive-controller: 0.13.3-0 -> 0.13.4-0
- ros-kinetic-dynamic-tf-publisher: 2.2.6-0 -> 2.2.7-0
- ros-kinetic-effort-controllers: 0.13.3-0 -> 0.13.4-0
- ros-kinetic-force-torque-sensor-controller: 0.13.3-0 -> 0.13.4-0
- ros-kinetic-forward-command-controller: 0.13.3-0 -> 0.13.4-0
- ros-kinetic-four-wheel-steering-controller: 0.13.3-0 -> 0.13.4-0
- ros-kinetic-franka-control: 0.4.0-0 -> 0.5.0-0
- ros-kinetic-franka-description: 0.4.0-0 -> 0.5.0-0
- ros-kinetic-franka-example-controllers: 0.4.0-0 -> 0.5.0-0
- ros-kinetic-franka-gripper: 0.4.0-0 -> 0.5.0-0
- ros-kinetic-franka-hw: 0.4.0-0 -> 0.5.0-0
- ros-kinetic-franka-msgs: 0.4.0-0 -> 0.5.0-0
- ros-kinetic-franka-ros: 0.4.0-0 -> 0.5.0-0
- ros-kinetic-franka-visualization: 0.4.0-0 -> 0.5.0-0
- ros-kinetic-gripper-action-controller: 0.13.3-0 -> 0.13.4-0
- ros-kinetic-grizzly-control: 0.4.0-0 -> 0.4.2-0
- ros-kinetic-grizzly-description: 0.4.0-0 -> 0.4.2-0
- ros-kinetic-grizzly-msgs: 0.4.0-0 -> 0.4.2-0
- ros-kinetic-grizzly-navigation: 0.4.0-0 -> 0.4.2-0
- ros-kinetic-ifopt: 1.0.2-0 -> 2.0.2-0
- ros-kinetic-image-view2: 2.2.6-0 -> 2.2.7-0
- ros-kinetic-imu-sensor-controller: 0.13.3-0 -> 0.13.4-0
- ros-kinetic-joint-state-controller: 0.13.3-0 -> 0.13.4-0
- ros-kinetic-joint-trajectory-controller: 0.13.3-0 -> 0.13.4-0
- ros-kinetic-jsk-common: 2.2.6-0 -> 2.2.7-0
- ros-kinetic-jsk-data: 2.2.6-0 -> 2.2.7-0
- ros-kinetic-jsk-network-tools: 2.2.6-0 -> 2.2.7-0
- ros-kinetic-jsk-tilt-laser: 2.2.6-0 -> 2.2.7-0
- ros-kinetic-jsk-tools: 2.2.6-0 -> 2.2.7-0
- ros-kinetic-jsk-topic-tools: 2.2.6-0 -> 2.2.7-0
- ros-kinetic-libfranka: 0.3.0-0 -> 0.4.0-0
- ros-kinetic-magni-bringup: 0.2.5-0 -> 0.3.2-0
- ros-kinetic-magni-demos: 0.2.5-0 -> 0.3.2-0
- ros-kinetic-magni-description: 0.2.5-0 -> 0.3.2-0
- ros-kinetic-magni-nav: 0.2.5-0 -> 0.3.2-0
- ros-kinetic-magni-robot: 0.2.5-0 -> 0.3.2-0
- ros-kinetic-magni-teleop: 0.2.5-0 -> 0.3.2-0
- ros-kinetic-mcl-3dl: 0.1.1-0 -> 0.1.3-0
- ros-kinetic-multi-map-server: 2.2.6-0 -> 2.2.7-0
- ros-kinetic-panda-moveit-config: 0.4.0-0 -> 0.5.0-0
- ros-kinetic-position-controllers: 0.13.3-0 -> 0.13.4-0
- ros-kinetic-rc-cloud-accumulator: 1.0.0-0 -> 1.0.4-0
- ros-kinetic-rc-dynamics-api: 0.6.0-0 -> 0.7.0-0
- ros-kinetic-rc-genicam-api: 1.3.8-0 -> 1.3.11-0
- ros-kinetic-rc-visard: 2.1.0-0 -> 2.2.0-0
- ros-kinetic-rc-visard-description: 2.1.0-0 -> 2.2.0-0
- ros-kinetic-rc-visard-driver: 2.1.0-0 -> 2.2.0-0
- ros-kinetic-ros-controllers: 0.13.3-0 -> 0.13.4-0
- ros-kinetic-rqt-joint-trajectory-controller: 0.13.3-0 -> 0.13.4-0
- ros-kinetic-rqt-rviz: 0.5.7-0 -> 0.5.10-0
- ros-kinetic-teb-local-planner: 0.6.9-0 -> 0.6.10-0
- ros-kinetic-tracetools: 0.1.0-1 -> 0.2.1-0
- ros-kinetic-tuw-airskin-msgs: 0.0.7-2 -> 0.0.7-3
- ros-kinetic-tuw-gazebo-msgs: 0.0.7-2 -> 0.0.7-3
- ros-kinetic-tuw-geometry-msgs: 0.0.7-2 -> 0.0.7-3
- ros-kinetic-tuw-msgs: 0.0.7-2 -> 0.0.7-3
- ros-kinetic-tuw-multi-robot-msgs: 0.0.7-2 -> 0.0.7-3
- ros-kinetic-tuw-nav-msgs: 0.0.7-2 -> 0.0.7-3
- ros-kinetic-tuw-object-msgs: 0.0.7-2 -> 0.0.7-3
- ros-kinetic-tuw-vehicle-msgs: 0.0.7-2 -> 0.0.7-3
- ros-kinetic-velocity-controllers: 0.13.3-0 -> 0.13.4-0
- ros-kinetic-velodyne-description: 1.0.6-0 -> 1.0.7-0
- ros-kinetic-velodyne-gazebo-plugins: 1.0.6-0 -> 1.0.7-0
- ros-kinetic-velodyne-simulator: 1.0.6-0 -> 1.0.7-0
- ros-kinetic-virtual-force-publisher: 2.2.6-0 -> 2.2.7-0
- ros-kinetic-web-video-server: 0.0.7-0 -> 0.1.0-0
- ros-kinetic-xpp: 1.0.6-0 -> 1.0.7-0
- ros-kinetic-xpp-examples: 1.0.6-0 -> 1.0.7-0
- ros-kinetic-xpp-hyq: 1.0.6-0 -> 1.0.7-0
- ros-kinetic-xpp-msgs: 1.0.6-0 -> 1.0.7-0
- ros-kinetic-xpp-quadrotor: 1.0.6-0 -> 1.0.7-0
- ros-kinetic-xpp-states: 1.0.6-0 -> 1.0.7-0
- ros-kinetic-xpp-vis: 1.0.6-0 -> 1.0.7-0
Removed Packages [0]:
- Adolfo Rodriguez Tsouroukdissian
- Alexander W. Winkler
- Atsushi Watanabe
- Bence Magyar
- Benjamin Binder
- Christoph Rösmann
- Devon Ash
- Felix Endres
- Felix Ruess
- Franka Emika GmbH
- George Todoran
- Ingo Luetkebohle
- Jose-Luis Blanco-Claraco
- Kei Okada
- Kevin Hallenbeck
- Louise Poubel
- Markus Bader
- Masaya Kataoka
- Mike Purvis
- Monika Florek-Jasinska
- Raphael Hauk
- Rohan Agrawal
- Russell Toris
- Ryohei Ueda
- Sachin Chitta
- Santiago Carrion
- Shashank Swaminathan
- Steve Macenski
- Tony Baltovski
- Vincent Rousseau
- Vladislav Tananaev
- YoheiKakiuchi
