We’re happy to announce 13 new packages and 71 updated packages for ROS Kinetic.
Thank you to all the maintainers who helped make this possible as well as the many more contributors. Full details are below.
Package Updates for kinetic
Added Packages [13]:
- ros-kinetic-access-point-control: 1.0.12-0
- ros-kinetic-asmach: 1.0.12-0
- ros-kinetic-asmach-tutorials: 1.0.12-0
- ros-kinetic-behaviortree-cpp-v3: 3.0.1-0
- ros-kinetic-ddwrt-access-point: 1.0.12-0
- ros-kinetic-hostapd-access-point: 1.0.12-0
- ros-kinetic-hpp-fcl: 1.0.1-1
- ros-kinetic-ieee80211-channels: 1.0.12-0
- ros-kinetic-linksys-access-point: 1.0.12-0
- ros-kinetic-ml-classifiers: 0.4.0-0
- ros-kinetic-network-detector: 1.0.12-0
- ros-kinetic-network-traffic-control: 1.0.12-0
- ros-kinetic-ros-ethercat-eml: 0.3.1-0
Updated Packages [71]:
- ros-kinetic-async-comm: 0.1.0-0 -> 0.1.1-0
- ros-kinetic-checkerboard-detector: 1.2.7-0 -> 1.2.9-0
- ros-kinetic-default-cfg-fkie: 0.8.9-0 -> 0.8.11-0
- ros-kinetic-grid-map: 1.6.0-0 -> 1.6.1-0
- ros-kinetic-grid-map-core: 1.6.0-0 -> 1.6.1-0
- ros-kinetic-grid-map-costmap-2d: 1.6.0-0 -> 1.6.1-0
- ros-kinetic-grid-map-cv: 1.6.0-0 -> 1.6.1-0
- ros-kinetic-grid-map-demos: 1.6.0-0 -> 1.6.1-0
- ros-kinetic-grid-map-filters: 1.6.0-0 -> 1.6.1-0
- ros-kinetic-grid-map-loader: 1.6.0-0 -> 1.6.1-0
- ros-kinetic-grid-map-msgs: 1.6.0-0 -> 1.6.1-0
- ros-kinetic-grid-map-octomap: 1.6.0-0 -> 1.6.1-0
- ros-kinetic-grid-map-pcl: 1.6.0-0 -> 1.6.1-0
- ros-kinetic-grid-map-ros: 1.6.0-0 -> 1.6.1-0
- ros-kinetic-grid-map-rviz-plugin: 1.6.0-0 -> 1.6.1-0
- ros-kinetic-grid-map-sdf: 1.6.0-0 -> 1.6.1-0
- ros-kinetic-grid-map-visualization: 1.6.0-0 -> 1.6.1-0
- ros-kinetic-imagesift: 1.2.7-0 -> 1.2.9-0
- ros-kinetic-industrial-core: 0.6.0-0 -> 0.7.0-0
- ros-kinetic-industrial-deprecated: 0.6.0-0 -> 0.7.0-0
- ros-kinetic-industrial-msgs: 0.6.0-0 -> 0.7.0-0
- ros-kinetic-industrial-robot-client: 0.6.0-0 -> 0.7.0-0
- ros-kinetic-industrial-robot-simulator: 0.6.0-0 -> 0.7.0-0
- ros-kinetic-industrial-trajectory-filters: 0.6.0-0 -> 0.7.0-0
- ros-kinetic-industrial-utils: 0.6.0-0 -> 0.7.0-0
- ros-kinetic-jsk-pcl-ros: 1.2.7-0 -> 1.2.9-0
- ros-kinetic-jsk-pcl-ros-utils: 1.2.7-0 -> 1.2.9-0
- ros-kinetic-jsk-perception: 1.2.7-0 -> 1.2.9-0
- ros-kinetic-jsk-recognition: 1.2.7-0 -> 1.2.9-0
- ros-kinetic-jsk-recognition-msgs: 1.2.7-0 -> 1.2.9-0
- ros-kinetic-jsk-recognition-utils: 1.2.7-0 -> 1.2.9-0
- ros-kinetic-master-discovery-fkie: 0.8.9-0 -> 0.8.11-0
- ros-kinetic-master-sync-fkie: 0.8.9-0 -> 0.8.11-0
- ros-kinetic-melfa-description: 0.0.3-0 -> 0.0.4-0
- ros-kinetic-melfa-driver: 0.0.3-0 -> 0.0.4-0
- ros-kinetic-melfa-robot: 0.0.3-0 -> 0.0.4-0
- ros-kinetic-multimaster-fkie: 0.8.9-0 -> 0.8.11-0
- ros-kinetic-multimaster-msgs-fkie: 0.8.9-0 -> 0.8.11-0
- ros-kinetic-node-manager-fkie: 0.8.9-0 -> 0.8.11-0
- ros-kinetic-odva-ethernetip: 0.1.2-0 -> 0.1.4-0
- ros-kinetic-pilz-extensions: 0.3.5-0 -> 0.3.6-0
- ros-kinetic-pilz-industrial-motion: 0.3.5-0 -> 0.3.6-0
- ros-kinetic-pilz-industrial-motion-testutils: 0.3.5-0 -> 0.3.6-0
- ros-kinetic-pilz-msgs: 0.3.5-0 -> 0.3.6-0
- ros-kinetic-pilz-robot-programming: 0.3.5-0 -> 0.3.6-0
- ros-kinetic-pilz-trajectory-generation: 0.3.5-0 -> 0.3.6-0
- ros-kinetic-plotjuggler: 2.1.3-0 -> 2.1.5-0
- ros-kinetic-py-trees: 0.5.10-0 -> 0.5.12-0
- ros-kinetic-resized-image-transport: 1.2.7-0 -> 1.2.9-0
- ros-kinetic-rv4fl-moveit-config: 0.0.3-0 -> 0.0.4-0
- ros-kinetic-rv7fl-moveit-config: 0.0.3-0 -> 0.0.4-0
- ros-kinetic-simple-message: 0.6.0-0 -> 0.7.0-0
- ros-kinetic-spatio-temporal-voxel-layer: 1.2.0-0 -> 1.2.1-0
- ros-kinetic-uuv-assistants: 0.6.7-0 -> 0.6.9-0
- ros-kinetic-uuv-auv-control-allocator: 0.6.7-0 -> 0.6.9-0
- ros-kinetic-uuv-control-cascaded-pid: 0.6.7-0 -> 0.6.9-0
- ros-kinetic-uuv-control-msgs: 0.6.7-0 -> 0.6.9-0
- ros-kinetic-uuv-control-utils: 0.6.7-0 -> 0.6.9-0
- ros-kinetic-uuv-gazebo: 0.6.7-0 -> 0.6.9-0
- ros-kinetic-uuv-gazebo-plugins: 0.6.7-0 -> 0.6.9-0
- ros-kinetic-uuv-gazebo-ros-plugins: 0.6.7-0 -> 0.6.9-0
- ros-kinetic-uuv-gazebo-ros-plugins-msgs: 0.6.7-0 -> 0.6.9-0
- ros-kinetic-uuv-gazebo-worlds: 0.6.7-0 -> 0.6.9-0
- ros-kinetic-uuv-sensor-ros-plugins: 0.6.7-0 -> 0.6.9-0
- ros-kinetic-uuv-sensor-ros-plugins-msgs: 0.6.7-0 -> 0.6.9-0
- ros-kinetic-uuv-teleop: 0.6.7-0 -> 0.6.9-0
- ros-kinetic-uuv-thruster-manager: 0.6.7-0 -> 0.6.9-0
- ros-kinetic-uuv-trajectory-control: 0.6.7-0 -> 0.6.9-0
- ros-kinetic-uuv-world-plugins: 0.6.7-0 -> 0.6.9-0
- ros-kinetic-uuv-world-ros-plugins: 0.6.7-0 -> 0.6.9-0
- ros-kinetic-uuv-world-ros-plugins-msgs: 0.6.7-0 -> 0.6.9-0
Removed Packages [0]:
- Alexander Gutenkunst
- Alexander Tiderko
- Daniel Koch
- Daniel Stonier
- Davide Faconti
- Devon Ash
- Kei Okada
- Luiz Ricardo Douat
- Mike Purvis
- Musa Morena Marcusso Manhaes
- Péter Fankhauser
- Ryohei Ueda
- Shadow Robot’s software team
- Shaun Edwards
- Steve Macenski
- Tokyo Opensource Robotics Kyokai (TORK) Developer Team
- Tokyo Opensource Robotics Kyokai(TORK) Developer Team
- Wolfgang Merkt
- Yohei Kakiuchi
- Youhei Kakiuchi
