We’re happy to announce 9 new packages and 57 updated packages for Kinetic.
Thank you to all the contributors and maintainers who have helped make these packages available!
Details are below.
Package Updates for kinetic
Added Packages [9]:
- ros-kinetic-fsrobo-r: 0.7.0-1
- ros-kinetic-fsrobo-r-bringup: 0.7.0-1
- ros-kinetic-fsrobo-r-description: 0.7.0-1
- ros-kinetic-fsrobo-r-driver: 0.7.0-1
- ros-kinetic-fsrobo-r-moveit-config: 0.7.0-1
- ros-kinetic-fsrobo-r-msgs: 0.7.0-1
- ros-kinetic-fsrobo-r-trajectory-filters: 0.7.0-1
- ros-kinetic-px4-msgs: 1.0.0-3
- ros-kinetic-rosbag-editor: 0.3.0-1
Updated Packages [57]:
- ros-kinetic-assisted-teleop: 0.2.1-0 -> 0.2.2-1
- ros-kinetic-avt-vimba-camera: 0.0.10-0 -> 0.0.11-1
- ros-kinetic-costmap-cspace: 0.4.3-1 -> 0.5.0-1
- ros-kinetic-goal-passer: 0.2.1-0 -> 0.2.2-1
- ros-kinetic-grid-map: 1.6.1-0 -> 1.6.2-1
- ros-kinetic-grid-map-core: 1.6.1-0 -> 1.6.2-1
- ros-kinetic-grid-map-costmap-2d: 1.6.1-0 -> 1.6.2-1
- ros-kinetic-grid-map-cv: 1.6.1-0 -> 1.6.2-1
- ros-kinetic-grid-map-demos: 1.6.1-0 -> 1.6.2-1
- ros-kinetic-grid-map-filters: 1.6.1-0 -> 1.6.2-1
- ros-kinetic-grid-map-loader: 1.6.1-0 -> 1.6.2-1
- ros-kinetic-grid-map-msgs: 1.6.1-0 -> 1.6.2-1
- ros-kinetic-grid-map-octomap: 1.6.1-0 -> 1.6.2-1
- ros-kinetic-grid-map-pcl: 1.6.1-0 -> 1.6.2-1
- ros-kinetic-grid-map-ros: 1.6.1-0 -> 1.6.2-1
- ros-kinetic-grid-map-rviz-plugin: 1.6.1-0 -> 1.6.2-1
- ros-kinetic-grid-map-sdf: 1.6.1-0 -> 1.6.2-1
- ros-kinetic-grid-map-visualization: 1.6.1-0 -> 1.6.2-1
- ros-kinetic-joystick-interrupt: 0.4.3-1 -> 0.5.0-1
- ros-kinetic-libmavconn: 0.32.2-1 -> 0.33.0-1
- ros-kinetic-map-organizer: 0.4.3-1 -> 0.5.0-1
- ros-kinetic-mavlink: 2019.9.9-1 -> 2019.10.10-1
- ros-kinetic-mavros: 0.32.2-1 -> 0.33.0-1
- ros-kinetic-mavros-extras: 0.32.2-1 -> 0.33.0-1
- ros-kinetic-mavros-msgs: 0.32.2-1 -> 0.33.0-1
- ros-kinetic-mbf-abstract-core: 0.2.4-1 -> 0.2.5-1
- ros-kinetic-mbf-abstract-nav: 0.2.4-1 -> 0.2.5-1
- ros-kinetic-mbf-costmap-core: 0.2.4-1 -> 0.2.5-1
- ros-kinetic-mbf-costmap-nav: 0.2.4-1 -> 0.2.5-1
- ros-kinetic-mbf-msgs: 0.2.4-1 -> 0.2.5-1
- ros-kinetic-mbf-simple-nav: 0.2.4-1 -> 0.2.5-1
- ros-kinetic-mbf-utility: 0.2.4-1 -> 0.2.5-1
- ros-kinetic-mcl-3dl: 0.1.5-1 -> 0.1.6-1
- ros-kinetic-move-base-flex: 0.2.4-1 -> 0.2.5-1
- ros-kinetic-navigation-experimental: 0.2.1-0 -> 0.2.2-1
- ros-kinetic-neonavigation: 0.4.3-1 -> 0.5.0-1
- ros-kinetic-neonavigation-common: 0.4.3-1 -> 0.5.0-1
- ros-kinetic-neonavigation-launch: 0.4.3-1 -> 0.5.0-1
- ros-kinetic-obj-to-pointcloud: 0.4.3-1 -> 0.5.0-1
- ros-kinetic-orocos-kdl: 1.3.1-0 -> 1.3.2-1
- ros-kinetic-orocos-kinematics-dynamics: 1.3.1-0 -> 1.3.2-1
- ros-kinetic-planner-cspace: 0.4.3-1 -> 0.5.0-1
- ros-kinetic-plotjuggler: 2.3.4-2 -> 2.3.6-2
- ros-kinetic-pose-base-controller: 0.2.1-0 -> 0.2.2-1
- ros-kinetic-pose-follower: 0.2.1-0 -> 0.2.2-1
- ros-kinetic-python-orocos-kdl: 1.3.1-0 -> 1.3.2-1
- ros-kinetic-rqt-reconfigure: 0.4.10-0 -> 0.5.0-1
- ros-kinetic-rr-control-input-manager: 0.7.2-1 -> 0.7.3-2
- ros-kinetic-rr-openrover-driver-msgs: 0.7.2-1 -> 0.7.3-2
- ros-kinetic-safety-limiter: 0.4.3-1 -> 0.5.0-1
- ros-kinetic-sbpl-lattice-planner: 0.2.1-0 -> 0.2.2-1
- ros-kinetic-sbpl-recovery: 0.2.1-0 -> 0.2.2-1
- ros-kinetic-tello-driver: 0.2.0-1 -> 0.3.1-1
- ros-kinetic-test-mavros: 0.32.2-1 -> 0.33.0-1
- ros-kinetic-track-odometry: 0.4.3-1 -> 0.5.0-1
- ros-kinetic-trajectory-tracker: 0.4.3-1 -> 0.5.0-1
- ros-kinetic-twist-recovery: 0.2.1-0 -> 0.2.2-1
Removed Packages [0]:
- Atsushi Watanabe
- Davide Faconti
- F-ROSROBO
- Jordy van Appeven
- Jorge Santos
- Martin Günther
- Miquel Massot
- Nicholas Padilla
- Nuno Marques
- Orocos Developers
- Péter Fankhauser
- Ruben Smits
- Scott K Logan
- Sebastian Pütz
- Vladimir Ermakov
- dfaconti
