We’re happy to announce 35 new packages and 171 updated packages for Kinetic Kame. The full details are below.
Thank you to the contributors and maintainers who have helped make these packages available to the community.
Package Updates for kinetic
Added Packages [35]:
- ros-kinetic-arduino-daq: 1.0.1-0
- ros-kinetic-bagger: 0.1.2-0
- ros-kinetic-costmap-cspace: 0.2.3-0
- ros-kinetic-handle-detector: 1.3.1-0
- ros-kinetic-ibeo-lux: 2.0.0-0
- ros-kinetic-joystick-interrupt: 0.2.3-0
- ros-kinetic-map-organizer: 0.2.3-0
- ros-kinetic-mir-actions: 1.0.1-0
- ros-kinetic-mir-description: 1.0.1-0
- ros-kinetic-mir-driver: 1.0.1-0
- ros-kinetic-mir-gazebo: 1.0.1-0
- ros-kinetic-mir-msgs: 1.0.1-0
- ros-kinetic-mir-navigation: 1.0.1-0
- ros-kinetic-neonavigation: 0.2.3-0
- ros-kinetic-neonavigation-common: 0.2.3-0
- ros-kinetic-neonavigation-launch: 0.2.3-0
- ros-kinetic-obj-to-pointcloud: 0.2.3-0
- ros-kinetic-pilz-robots: 0.2.1-0
- ros-kinetic-planner-cspace: 0.2.3-0
- ros-kinetic-pr2-gripper-sensor: 1.0.10-0
- ros-kinetic-pr2-gripper-sensor-action: 1.0.10-0
- ros-kinetic-pr2-gripper-sensor-controller: 1.0.10-0
- ros-kinetic-pr2-gripper-sensor-msgs: 1.0.10-0
- ros-kinetic-prbt-ikfast-manipulator-plugin: 0.2.1-0
- ros-kinetic-prbt-moveit-config: 0.2.1-0
- ros-kinetic-prbt-support: 0.2.1-0
- ros-kinetic-ps4eye: 0.0.4-1
- ros-kinetic-pybind11-catkin: 2.2.3-0
- ros-kinetic-roseus-mongo: 1.7.1-0
- ros-kinetic-rr-openrover-basic: 0.0.4-0
- ros-kinetic-rr-swiftnav-piksi: 0.0.1-1
- ros-kinetic-safety-limiter: 0.2.3-0
- ros-kinetic-towr-ros: 1.3.2-0
- ros-kinetic-track-odometry: 0.2.3-0
- ros-kinetic-trajectory-tracker: 0.2.3-0
Updated Packages [171]:
- ros-kinetic-cob-3d-mapping-msgs: 0.6.11-0 -> 0.6.12-0
- ros-kinetic-cob-base-drive-chain: 0.6.11-0 -> 0.6.12-0
- ros-kinetic-cob-base-velocity-smoother: 0.7.1-0 -> 0.7.2-0
- ros-kinetic-cob-bms-driver: 0.6.11-0 -> 0.6.12-0
- ros-kinetic-cob-bringup: 0.6.8-0 -> 0.6.9-0
- ros-kinetic-cob-bringup-sim: 0.6.9-0 -> 0.6.10-0
- ros-kinetic-cob-calibration-data: 0.6.8-0 -> 0.6.9-0
- ros-kinetic-cob-cam3d-throttle: 0.6.11-0 -> 0.6.12-0
- ros-kinetic-cob-camera-sensors: 0.6.11-0 -> 0.6.12-0
- ros-kinetic-cob-canopen-motor: 0.6.11-0 -> 0.6.12-0
- ros-kinetic-cob-cartesian-controller: 0.7.1-0 -> 0.7.2-0
- ros-kinetic-cob-collision-velocity-filter: 0.7.1-0 -> 0.7.2-0
- ros-kinetic-cob-command-gui: 0.6.7-0 -> 0.6.9-0
- ros-kinetic-cob-command-tools: 0.6.7-0 -> 0.6.9-0
- ros-kinetic-cob-common: 0.6.8-0 -> 0.6.9-0
- ros-kinetic-cob-control: 0.7.1-0 -> 0.7.2-0
- ros-kinetic-cob-control-mode-adapter: 0.7.1-0 -> 0.7.2-0
- ros-kinetic-cob-control-msgs: 0.7.1-0 -> 0.7.2-0
- ros-kinetic-cob-dashboard: 0.6.7-0 -> 0.6.9-0
- ros-kinetic-cob-default-robot-behavior: 0.6.8-0 -> 0.6.9-0
- ros-kinetic-cob-default-robot-config: 0.6.8-0 -> 0.6.9-0
- ros-kinetic-cob-description: 0.6.8-0 -> 0.6.9-0
- ros-kinetic-cob-driver: 0.6.11-0 -> 0.6.12-0
- ros-kinetic-cob-elmo-homing: 0.6.11-0 -> 0.6.12-0
- ros-kinetic-cob-footprint-observer: 0.7.1-0 -> 0.7.2-0
- ros-kinetic-cob-frame-tracker: 0.7.1-0 -> 0.7.2-0
- ros-kinetic-cob-gazebo: 0.6.9-0 -> 0.6.10-0
- ros-kinetic-cob-gazebo-objects: 0.6.9-0 -> 0.6.10-0
- ros-kinetic-cob-gazebo-worlds: 0.6.9-0 -> 0.6.10-0
- ros-kinetic-cob-generic-can: 0.6.11-0 -> 0.6.12-0
- ros-kinetic-cob-hand: 0.6.3-0 -> 0.6.5-0
- ros-kinetic-cob-hand-bridge: 0.6.3-0 -> 0.6.5-0
- ros-kinetic-cob-hardware-config: 0.6.8-0 -> 0.6.9-0
- ros-kinetic-cob-helper-tools: 0.6.7-0 -> 0.6.9-0
- ros-kinetic-cob-image-flip: 0.6.11-0 -> 0.6.12-0
- ros-kinetic-cob-interactive-teleop: 0.6.7-0 -> 0.6.9-0
- ros-kinetic-cob-light: 0.6.11-0 -> 0.6.12-0
- ros-kinetic-cob-linear-nav: 0.6.6-0 -> 0.6.7-0
- ros-kinetic-cob-map-accessibility-analysis: 0.6.6-0 -> 0.6.7-0
- ros-kinetic-cob-mapping-slam: 0.6.6-0 -> 0.6.7-0
- ros-kinetic-cob-mimic: 0.6.11-0 -> 0.6.12-0
- ros-kinetic-cob-model-identifier: 0.7.1-0 -> 0.7.2-0
- ros-kinetic-cob-monitoring: 0.6.7-0 -> 0.6.9-0
- ros-kinetic-cob-moveit-config: 0.6.8-0 -> 0.6.9-0
- ros-kinetic-cob-msgs: 0.6.8-0 -> 0.6.9-0
- ros-kinetic-cob-navigation: 0.6.6-0 -> 0.6.7-0
- ros-kinetic-cob-navigation-config: 0.6.6-0 -> 0.6.7-0
- ros-kinetic-cob-navigation-global: 0.6.6-0 -> 0.6.7-0
- ros-kinetic-cob-navigation-local: 0.6.6-0 -> 0.6.7-0
- ros-kinetic-cob-navigation-slam: 0.6.6-0 -> 0.6.7-0
- ros-kinetic-cob-object-detection-msgs: 0.6.11-0 -> 0.6.12-0
- ros-kinetic-cob-object-detection-visualizer: 0.6.11-0 -> 0.6.12-0
- ros-kinetic-cob-obstacle-distance: 0.7.1-0 -> 0.7.2-0
- ros-kinetic-cob-omni-drive-controller: 0.7.1-0 -> 0.7.2-0
- ros-kinetic-cob-perception-common: 0.6.11-0 -> 0.6.12-0
- ros-kinetic-cob-perception-msgs: 0.6.11-0 -> 0.6.12-0
- ros-kinetic-cob-phidget-em-state: 0.6.11-0 -> 0.6.12-0
- ros-kinetic-cob-phidget-power-state: 0.6.11-0 -> 0.6.12-0
- ros-kinetic-cob-phidgets: 0.6.11-0 -> 0.6.12-0
- ros-kinetic-cob-relayboard: 0.6.11-0 -> 0.6.12-0
- ros-kinetic-cob-robots: 0.6.8-0 -> 0.6.9-0
- ros-kinetic-cob-scan-unifier: 0.6.11-0 -> 0.6.12-0
- ros-kinetic-cob-script-server: 0.6.7-0 -> 0.6.9-0
- ros-kinetic-cob-sick-lms1xx: 0.6.11-0 -> 0.6.12-0
- ros-kinetic-cob-sick-s300: 0.6.11-0 -> 0.6.12-0
- ros-kinetic-cob-simulation: 0.6.9-0 -> 0.6.10-0
- ros-kinetic-cob-sound: 0.6.11-0 -> 0.6.12-0
- ros-kinetic-cob-srvs: 0.6.8-0 -> 0.6.9-0
- ros-kinetic-cob-supported-robots: 0.6.8-0 -> 0.6.9-0
- ros-kinetic-cob-teleop: 0.6.7-0 -> 0.6.9-0
- ros-kinetic-cob-trajectory-controller: 0.7.1-0 -> 0.7.2-0
- ros-kinetic-cob-twist-controller: 0.7.1-0 -> 0.7.2-0
- ros-kinetic-cob-undercarriage-ctrl: 0.6.11-0 -> 0.6.12-0
- ros-kinetic-cob-utilities: 0.6.11-0 -> 0.6.12-0
- ros-kinetic-cob-vision-utils: 0.6.11-0 -> 0.6.12-0
- ros-kinetic-cob-voltage-control: 0.6.11-0 -> 0.6.12-0
- ros-kinetic-default-cfg-fkie: 0.7.8-0 -> 0.8.0-0
- ros-kinetic-dynamixel-sdk: 3.5.4-0 -> 3.6.2-0
- ros-kinetic-dynamixel-workbench: 0.3.1-0 -> 1.0.0-0
- ros-kinetic-dynamixel-workbench-controllers: 0.3.1-0 -> 1.0.0-0
- ros-kinetic-dynamixel-workbench-msgs: 0.2.0-0 -> 1.0.0-0
- ros-kinetic-dynamixel-workbench-operators: 0.3.1-0 -> 1.0.0-0
- ros-kinetic-dynamixel-workbench-single-manager: 0.3.1-0 -> 1.0.0-0
- ros-kinetic-dynamixel-workbench-single-manager-gui: 0.3.1-0 -> 1.0.0-0
- ros-kinetic-dynamixel-workbench-toolbox: 0.3.1-0 -> 1.0.0-0
- ros-kinetic-eus-assimp: 0.3.5-0 -> 0.4.0-0
- ros-kinetic-euscollada: 0.3.5-0 -> 0.4.0-0
- ros-kinetic-euslisp: 9.23.0-0 -> 9.25.0-0
- ros-kinetic-eusurdf: 0.3.5-0 -> 0.4.0-0
- ros-kinetic-generic-throttle: 0.6.7-0 -> 0.6.9-0
- ros-kinetic-geometry2: 0.5.17-0 -> 0.5.18-0
- ros-kinetic-ifopt: 2.0.2-0 -> 2.0.4-0
- ros-kinetic-interactive-markers: 1.11.3-0 -> 1.11.4-0
- ros-kinetic-jsk-model-tools: 0.3.5-0 -> 0.4.0-0
- ros-kinetic-jsk-roseus: 1.6.3-0 -> 1.7.1-0
- ros-kinetic-jskeus: 1.1.0-0 -> 1.2.0-1
- ros-kinetic-kdl-parser: 1.12.10-0 -> 1.12.11-0
- ros-kinetic-kdl-parser-py: 1.12.10-0 -> 1.12.11-0
- ros-kinetic-libmavconn: 0.26.0-0 -> 0.26.1-0
- ros-kinetic-master-discovery-fkie: 0.7.8-0 -> 0.8.0-0
- ros-kinetic-master-sync-fkie: 0.7.8-0 -> 0.8.0-0
- ros-kinetic-mavlink: 2018.6.6-0 -> 2018.7.18-0
- ros-kinetic-mavros: 0.26.0-0 -> 0.26.1-0
- ros-kinetic-mavros-extras: 0.26.0-0 -> 0.26.1-0
- ros-kinetic-mavros-msgs: 0.26.0-0 -> 0.26.1-0
- ros-kinetic-mrpt-bridge: 0.1.24-0 -> 0.1.25-0
- ros-kinetic-multimaster-fkie: 0.7.8-0 -> 0.8.0-0
- ros-kinetic-multimaster-msgs-fkie: 0.7.8-0 -> 0.8.0-0
- ros-kinetic-node-manager-fkie: 0.7.8-0 -> 0.8.0-0
- ros-kinetic-novatel-gps-driver: 3.4.0-0 -> 3.5.0-0
- ros-kinetic-novatel-gps-msgs: 3.4.0-0 -> 3.5.0-0
- ros-kinetic-openni2-camera: 0.3.0-0 -> 0.4.0-0
- ros-kinetic-openni2-launch: 0.3.0-0 -> 0.4.0-0
- ros-kinetic-pid: 0.0.25-0 -> 0.0.27-0
- ros-kinetic-plotjuggler: 1.6.2-0 -> 1.7.1-1
- ros-kinetic-raw-description: 0.6.8-0 -> 0.6.9-0
- ros-kinetic-rc-genicam-api: 1.3.11-0 -> 1.3.12-0
- ros-kinetic-robot-calibration: 0.5.5-0 -> 0.6.0-0
- ros-kinetic-robot-calibration-msgs: 0.5.5-0 -> 0.6.0-0
- ros-kinetic-robotnik-msgs: 0.2.3-0 -> 0.2.4-0
- ros-kinetic-roseus: 1.6.3-0 -> 1.7.1-0
- ros-kinetic-roseus-smach: 1.6.3-0 -> 1.7.1-0
- ros-kinetic-roseus-tutorials: 1.6.3-0 -> 1.7.1-0
- ros-kinetic-rqt-image-view: 0.4.11-0 -> 0.4.13-0
- ros-kinetic-sbg-driver: 1.1.6-0 -> 1.1.7-0
- ros-kinetic-schunk-description: 0.6.10-0 -> 0.6.11-0
- ros-kinetic-schunk-libm5api: 0.6.10-0 -> 0.6.11-0
- ros-kinetic-schunk-modular-robotics: 0.6.10-0 -> 0.6.11-0
- ros-kinetic-schunk-powercube-chain: 0.6.10-0 -> 0.6.11-0
- ros-kinetic-schunk-sdh: 0.6.10-0 -> 0.6.11-0
- ros-kinetic-schunk-simulated-tactile-sensors: 0.6.10-0 -> 0.6.11-0
- ros-kinetic-service-tools: 0.6.7-0 -> 0.6.9-0
- ros-kinetic-test-mavros: 0.26.0-0 -> 0.26.1-0
- ros-kinetic-tf2: 0.5.17-0 -> 0.5.18-0
- ros-kinetic-tf2-bullet: 0.5.17-0 -> 0.5.18-0
- ros-kinetic-tf2-eigen: 0.5.17-0 -> 0.5.18-0
- ros-kinetic-tf2-geometry-msgs: 0.5.17-0 -> 0.5.18-0
- ros-kinetic-tf2-kdl: 0.5.17-0 -> 0.5.18-0
- ros-kinetic-tf2-msgs: 0.5.17-0 -> 0.5.18-0
- ros-kinetic-tf2-py: 0.5.17-0 -> 0.5.18-0
- ros-kinetic-tf2-ros: 0.5.17-0 -> 0.5.18-0
- ros-kinetic-tf2-sensor-msgs: 0.5.17-0 -> 0.5.18-0
- ros-kinetic-tf2-tools: 0.5.17-0 -> 0.5.18-0
- ros-kinetic-towr: 1.2.2-0 -> 1.3.2-0
- ros-kinetic-turtlebot3: 1.0.0-0 -> 1.1.0-0
- ros-kinetic-turtlebot3-bringup: 1.0.0-0 -> 1.1.0-0
- ros-kinetic-turtlebot3-description: 1.0.0-0 -> 1.1.0-0
- ros-kinetic-turtlebot3-example: 1.0.0-0 -> 1.1.0-0
- ros-kinetic-turtlebot3-fake: 1.0.2-0 -> 1.1.0-0
- ros-kinetic-turtlebot3-gazebo: 1.0.2-0 -> 1.1.0-0
- ros-kinetic-turtlebot3-navigation: 1.0.0-0 -> 1.1.0-0
- ros-kinetic-turtlebot3-simulations: 1.0.2-0 -> 1.1.0-0
- ros-kinetic-turtlebot3-slam: 1.0.0-0 -> 1.1.0-0
- ros-kinetic-turtlebot3-teleop: 1.0.0-0 -> 1.1.0-0
- ros-kinetic-tuw-airskin-msgs: 0.0.7-3 -> 0.0.8-1
- ros-kinetic-tuw-gazebo-msgs: 0.0.7-3 -> 0.0.8-1
- ros-kinetic-tuw-geometry-msgs: 0.0.7-3 -> 0.0.8-1
- ros-kinetic-tuw-msgs: 0.0.7-3 -> 0.0.8-1
- ros-kinetic-tuw-multi-robot-msgs: 0.0.7-3 -> 0.0.8-1
- ros-kinetic-tuw-nav-msgs: 0.0.7-3 -> 0.0.8-1
- ros-kinetic-tuw-object-msgs: 0.0.7-3 -> 0.0.8-1
- ros-kinetic-tuw-vehicle-msgs: 0.0.7-3 -> 0.0.8-1
- ros-kinetic-video-stream-opencv: 1.1.2-0 -> 1.1.4-0
- ros-kinetic-xpp: 1.0.7-0 -> 1.0.8-0
- ros-kinetic-xpp-examples: 1.0.7-0 -> 1.0.8-0
- ros-kinetic-xpp-hyq: 1.0.7-0 -> 1.0.8-0
- ros-kinetic-xpp-msgs: 1.0.7-0 -> 1.0.8-0
- ros-kinetic-xpp-quadrotor: 1.0.7-0 -> 1.0.8-0
- ros-kinetic-xpp-states: 1.0.7-0 -> 1.0.8-0
- ros-kinetic-xpp-vis: 1.0.7-0 -> 1.0.8-0
- ros-kinetic-xsens-driver: 2.1.0-0 -> 2.2.0-0
Removed Packages [0]:
- Alexander Bubeck
- Alexander Tiderko
- Alexander W. Winkler
- Andreas ten Pas
- Andy Zelenak
- Angel Soriano
- Atsushi Watanabe
- Benjamin Binder
- Benjamin Maidel
- Brenden Gibbons
- Bruno Brito
- Chris Lalancette
- Davide Faconti
- Dirk Thomas
- Felipe Garcia Lopez
- Felix Messmer
- Felix Ruess
- Felix Zeltner
- Florian Weisshardt
- Francis Colas
- George Todoran
- Isaac I. Y. Saito
- Jack Kilian
- Jannik Abbenseth
- Jose Luis Blanco Claraco
- Jose-Luis Blanco-Claraco
- Joshua Hampp
- Kei Okada
- Koji Terada
- Markus Bader
- Martin Günther
- Matthias Gruhler
- Michael Ferguson
- P. J. Reed
- Pilz GmbH and Co. KG
- Pyo
- ROS Orphaned Package Maintainers
- Raphael Hauk
- Richard Bormann
- Ron Tajima
- Sammy Pfeiffer
- Thomas Le Mézo
- Tully Foote
- Vincent Rabaud
- Vladimir Ermakov
- Vladimir Ivan
- William Woodall
- Yohei Kakiuchi
- Yuki Furuta
- nick fragale
