Dear ROS developers, we just released a new ROS course - Advanced Modern C++ for Robotics.
Here are the course description and link:
New course: Advanced Modern C++ for Robotics
Start learning: Learn Robotics from Zero - Robotics & ROS Online Courses
Master the basics of C++ for robot programming, you’ll learn:
- How to build C++ programs
- How to create a library
- Understand the Standard Template Library (STL) and how it can help you create better code
- How to use C++ classes to optimize your code
- Inheritance
- Function overriding and function overloading
- How to use pointers and references for optimal memory management
- Templates and Lambda expressions
- How to use threads to parallelize tasks in C++
- How to deal with unexpected or exceptional errors in your code
You will learn this course by practicing with a simulated ** Turtlebot**:
