Open Class - Robot Control Basics
Proportional control is a control system technology based on a response in proportion to the difference between what is set as the desired process variable and the measured value.
In this Open Class, we will see an example of a proportional controller applied to a basic 2DOF robot.
This time, you’ll learn:
  • What is a proportional controller
  • How to create a proportional controller using Matplotlib
  • How to apply a proportional controller to a simple 2DOF robot
You will be using 2DOF Robot throughout the training
Join Open Class Here Learn Robotics from Zero - Robotics & ROS Online Courses
