I tried out TRAC_IK, but got similar results. I think OMPL with RTTConnect is the problem but couldn’t figure out how to change it in the parameters. Whatever I do RTTConnect is the one doing the planning.
I basically want to move a cube from front to rear (modeled as a cube in moveit but it is a cup). I think the most confusing thing here are these lines:
orientation_constraint.absolute_x_axis_tolerance = 0.5
orientation_constraint.absolute_y_axis_tolerance = 0.5
orientation_constraint.absolute_z_axis_tolerance = 3.14
There is zero documentation on how those values should be set. What do they represent? How can one translate them into “You can turn the endeffector around world’s z axis as much as you want but around the two other axis it should be limited to few degrees to not spill the cup”. I tried all combinations of values, nothing seems to work well. Most of the times it doesn’t find a trajectory but in few cases it does and here is what it looks like:
Here are my constraints:
joint_constraints: []
position_constraints: []
orientation_constraints:
header:
seq: 0
stamp:
secs: 349
nsecs: 157000000
frame_id: "world"
orientation:
x: -0.70761630062
y: 0.000350377689552
z: -0.706596714945
w: 0.000361608916337
link_name: "panda_link8"
absolute_x_axis_tolerance: 3.14
absolute_y_axis_tolerance: 0.1
absolute_z_axis_tolerance: 0.1
weight: 1.0
visibility_constraints: []
i don’t know why for those value (x 3.14, y 0.1, z 0.1 it managed to find a path, totally unintuitive)
Here is the log from RTT
[/move_group INFO 1563826183.386238577, 352.138000000]: panda_arm: Allocating specialized state sampler for state space
[/move_group INFO 1563826183.386365074, 352.138000000]: RRTConnect: Starting planning with 1 states already in datastructure
[/move_group INFO 1563826191.847614911, 360.447000000]: RRTConnect: Created 8 states (2 start + 6 goal)
[/move_group INFO 1563826191.847754873, 360.447000000]: Solution found in 8.462048 seconds
[/move_group INFO 1563826192.703497689, 361.262000000]: panda_arm: Allocating specialized state sampler for state space
[/move_group INFO 1563826193.788332731, 362.328000000]: panda_arm: Allocating specialized state sampler for state space
[/move_group INFO 1563826198.994204393, 367.406000000]: SimpleSetup: Path simplification took 7.146335 seconds and changed from 4 to 4 states
And my ros params for the move group:
allow_trajectory_execution: true
controller_list:
- action_ns: follow_joint_trajectory
default: true
joints: [panda_joint1, panda_joint2, panda_joint3, panda_joint4, panda_joint5, panda_joint6,
panda_joint7]
type: FollowJointTrajectory
hand:
planner_configs: [SBLkConfigDefault, ESTkConfigDefault, LBKPIECEkConfigDefault,
BKPIECEkConfigDefault, KPIECEkConfigDefault, RRTkConfigDefault, RRTConnectkConfigDefault,
RRTstarkConfigDefault, TRRTkConfigDefault, PRMkConfigDefault, PRMstarkConfigDefault,
FMTkConfigDefault, BFMTkConfigDefault, PDSTkConfigDefault, STRIDEkConfigDefault,
BiTRRTkConfigDefault, LBTRRTkConfigDefault, BiESTkConfigDefault, ProjESTkConfigDefault,
LazyPRMkConfigDefault, LazyPRMstarkConfigDefault, SPARSkConfigDefault, SPARStwokConfigDefault,
TrajOptDefault]
jiggle_fraction: 0.05
max_range: 5.0
max_safe_path_cost: 1
moveit_controller_manager: moveit_simple_controller_manager/MoveItSimpleControllerManager
moveit_manage_controllers: true
octomap_frame: world
octomap_resolution: 0.05
ompl: {display_random_valid_states: false, link_for_exploration_tree: '', maximum_waypoint_distance: 0.0,
minimum_waypoint_count: 10, simplify_solutions: true}
panda_arm:
TrajOptDefault]
panda_arm_hand:
TrajOptDefault]
plan_execution: {max_replan_attempts: 5, record_trajectory_state_frequency: 10.0}
planner_configs:
BFMTkConfigDefault: {balanced: 0, cache_cc: 1, extended_fmt: 1, heuristics: 1, nearest_k: 1,
num_samples: 1000, optimality: 1, radius_multiplier: 1.0, type: 'geometric::BFMT'}
BKPIECEkConfigDefault: {border_fraction: 0.9, failed_expansion_score_factor: 0.5,
min_valid_path_fraction: 0.5, range: 0.0, type: 'geometric::BKPIECE'}
BiESTkConfigDefault: {range: 0.0, type: 'geometric::BiEST'}
BiTRRTkConfigDefault: {cost_threshold: 1e300, frountier_node_ratio: 0.1, frountier_threshold: 0.0,
init_temperature: 100, range: 0.0, temp_change_factor: 0.1, type: 'geometric::BiTRRT'}
ESTkConfigDefault: {goal_bias: 0.05, range: 0.0, type: 'geometric::EST'}
FMTkConfigDefault: {cache_cc: 1, extended_fmt: 1, heuristics: 0, nearest_k: 1, num_samples: 1000,
radius_multiplier: 1.1, type: 'geometric::FMT'}
goal_bias: 0.05, min_valid_path_fraction: 0.5, range: 0.0, type: 'geometric::KPIECE'}
LBKPIECEkConfigDefault: {border_fraction: 0.9, min_valid_path_fraction: 0.5, range: 0.0,
type: 'geometric::LBKPIECE'}
LBTRRTkConfigDefault: {epsilon: 0.4, goal_bias: 0.05, range: 0.0, type: 'geometric::LBTRRT'}
LazyPRMkConfigDefault: {range: 0.0, type: 'geometric::LazyPRM'}
LazyPRMstarkConfigDefault: {type: 'geometric::LazyPRMstar'}
PDSTkConfigDefault: {type: 'geometric::PDST'}
PRMkConfigDefault: {max_nearest_neighbors: 10, type: 'geometric::PRM'}
PRMstarkConfigDefault: {type: 'geometric::PRMstar'}
ProjESTkConfigDefault: {goal_bias: 0.05, range: 0.0, type: 'geometric::ProjEST'}
RRTConnectkConfigDefault: {range: 0.1, type: 'geometric::RRTConnect'}
RRTkConfigDefault: {goal_bias: 0.05, range: 0.0, type: 'geometric::RRT'}
RRTstarkConfigDefault: {delay_collision_checking: 1, goal_bias: 0.05, range: 0.0,
type: 'geometric::RRTstar'}
SBLkConfigDefault: {range: 0.0, type: 'geometric::SBL'}
SPARSkConfigDefault: {dense_delta_fraction: 0.001, max_failures: 1000, sparse_delta_fraction: 0.25,
stretch_factor: 3.0, type: 'geometric::SPARS'}
SPARStwokConfigDefault: {dense_delta_fraction: 0.001, max_failures: 5000, sparse_delta_fraction: 0.25,
stretch_factor: 3.0, type: 'geometric::SPARStwo'}
STRIDEkConfigDefault: {degree: 16, estimated_dimension: 0.0, goal_bias: 0.05, max_degree: 18,
max_pts_per_leaf: 6, min_degree: 12, min_valid_path_fraction: 0.2, range: 0.0,
type: 'geometric::STRIDE', use_projected_distance: 0}
TRRTkConfigDefault: {frountierNodeRatio: 0.1, frountier_threshold: 0.0, goal_bias: 0.05,
init_temperature: 10e-6, k_constant: 0.0, max_states_failed: 10, min_temperature: 10e-10,
range: 0.0, temp_change_factor: 2.0, type: 'geometric::TRRT'}
TrajOptDefault: {type: 'geometric::TrajOpt'}
planning_plugin: ompl_interface/OMPLPlanner
planning_scene_monitor: {publish_geometry_updates: true, publish_planning_scene: true,
publish_planning_scene_hz: 4.0, publish_state_updates: true, publish_transforms_updates: true}
request_adapters: default_planner_request_adapters/AddTimeParameterization default_planner_request_adapters/FixWorkspaceBounds default_planner_request_adapters/FixStartStateBounds default_planner_request_adapters/FixStartStateCollision default_planner_request_adapters/FixStartStatePathConstraints
sense_for_plan: {discard_overlapping_cost_sources: 0.8, max_cost_sources: 100, max_look_attempts: 3,
max_safe_path_cost: 0.01}
sensors:
- {filtered_cloud_topic: filtered_cloud, max_range: 5.0, max_update_rate: 1.0, padding_offset: 0.1,
padding_scale: 1.0, point_cloud_topic: /camera/depth/points2, point_subsample: 1,
sensor_plugin: occupancy_map_monitor/PointCloudOctomapUpdater}
start_state_max_bounds_error: 0.1
trajectory_execution: {allowed_execution_duration_scaling: 1.2, allowed_goal_duration_margin: 0.5,
allowed_start_tolerance: 0.01, execution_duration_monitoring: true, execution_velocity_scaling: 1.0,
wait_for_trajectory_completion: true}
Finally, the resulting planned trajectory that you see in the GIF:
joint_trajectory:
header:
seq: 0
stamp:
secs: 0
nsecs: 0
frame_id: "world"
joint_names: [panda_joint1, panda_joint2, panda_joint3, panda_joint4, panda_joint5, panda_joint6,
panda_joint7]
positions: [-2.213983065136418, -1.2906379420367688, 2.3273649916983246, -1.9678602917554295, -2.650969141769095, 2.0039492641542935, -2.476349470124318]
velocities: [0.0, 0.0, 0.0, 0.0, 0.0, 0.0, 0.0]
accelerations: [1.9632485719663737, 0.0, 0.0, 0.0, 0.0, 0.0, 0.0]
effort: []
time_from_start:
secs: 0
nsecs: 0
positions: [-1.9027151256478418, -1.5880583544291564, 2.1292902456872462, -2.154423175484103, -2.4068879685174527, 2.2317096667180625, -2.152342548895806]
velocities: [0.4298869667738717, -0.4556318780073839, -0.19791464189962368, -0.34017229377693714, 0.30441774361787766, 0.3997345551847432, 0.5112288002771675]
accelerations: [-0.48222665458307257, 0.28468497464592474, 0.6037223941527191, -0.0347912472704278, -0.5063849797233159, -0.018574417137113254, -0.2517847982946746]
effort: []
time_from_start:
secs: 0
nsecs: 563111696
positions: [-1.7626767727462216, -1.7627999782562256, 2.1091842473515934, -2.313631894582778, -2.32688859444776, 2.4118842614471276, -1.9484171891276754]
velocities: [0.7725408157720929, 0.5650829187666142, -0.8316923201322326, -0.27305036858669096, -0.059530639605950175, -0.061749502808752355, -0.07950400818817896]
accelerations: [0.9210476893316034, 1.8759505680749602, -1.5582839960917374, 0.15033970271106387, -0.4647774006985861, -0.9036767076602864, -1.0418225664459562]
effort: []
time_from_start:
secs: 1
nsecs: 19248097
positions: [0.17565969203819773, 0.6063682213183783, -0.42601548374175996, -2.622155852089251, -2.787875987452324, 1.6001150559915056, -2.8973000049591064]
velocities: [0.7341210653027398, 0.17826847159587578, -1.2539442120327753, -0.10109952836094367, 1.1382694873282135, -0.1157564282770443, 0.8649658386396004]
accelerations: [-0.5642507779739733, -1.494725563291784, 0.40907869952418036, 0.1074461840484824, 1.6041465406503854, 0.4509343400663588, 1.6470621546324373]
effort: []
time_from_start:
secs: 2
nsecs: 584857169
positions: [0.6375933836556927, -1.715076928250512, -2.209330963234938, -2.632463081337065, 2.3718884042035207, 2.1760768007872247, 1.7908894452450517]
velocities: [-0.9724148421082567, -0.2786311262121256, -0.24537416592234756, -0.26398524373559246, 1.44979787515851, 0.2962246413803101, 1.290045413951348]
accelerations: [-2.265003772396396, 1.6538319407711919, 1.2114483097018662, -0.487528778117418, -2.11169503151197, 0.017397240400491905, -1.970018757212809]
effort: []
time_from_start:
secs: 4
nsecs: 591778392
positions: [0.3834534679918675, -1.6450327699773575, -2.162845633190281, -2.693554186091228, 2.4102852338042835, 2.2117687437513056, 1.8194092168206337]
velocities: [-1.1057388901973995, 0.8980283437714662, 0.4753569299354654, -0.2870429342055714, -1.1406946326917613, 0.03847686947447697, -0.979036762608576]
accelerations: [2.0414500089035927, 0.5700363748479903, 0.14800728500760188, 0.45017721838671665, -2.805220752606676, -0.5097313468909557, -2.3351938685388656]
effort: []
time_from_start:
secs: 4
nsecs: 708624330
positions: [0.3112911056336616, 0.7221461800472077, -1.0691088496407837, -2.794942188403328, -2.752961096330716, 1.7597219293004558, -2.5370129169004394]
velocities: [-0.0822034140150121, 0.0563778643209657, 0.06241899490750913, 0.009631387551305472, -0.04317740752954591, 0.007597584700165083, -0.06108272493000144]
accelerations: [-0.044676352708033114, -1.114056427200839, -0.47920574077546685, 0.059485517010125465, 2.5079208837789757, 0.23068742186582555, 2.091939080935357]
effort: []
time_from_start:
secs: 6
nsecs: 686879629
positions: [0.040632926504200945, -1.5709306382845338, -1.9747118816096683, -2.6457564442484136, 2.586289239312852, 2.2753218635486214, 1.8635968755718382]
velocities: [-0.06009464200741561, 0.01035520782793864, 0.011239616211776271, 0.19739327656239786, 1.5482026347918063, -0.09049110448083351, 1.5112201506008778]
accelerations: [0.11551318402015218, 1.8632784697111437, 0.7480386999626303, 0.21605893607126836, -1.6610519949815388, -0.5690891519633852, -0.9685381356141484]
effort: []
time_from_start:
secs: 8
nsecs: 802569413
positions: [0.042438501686269905, -1.3132541245940084, -1.8696118945480387, -2.5701083356817946, 2.719905903184296, 2.176248933172528, 2.0834573521176147]
velocities: [0.15573369117473462, 1.3060182524842707, 0.2446091442826451, 0.43154671194466215, 0.6698886942074038, -0.3859866968381853, 1.095575846120204]
accelerations: [1.2786570114914173, 1.7406367365035307, -1.779061494769991, 0.9268410833867544, 0.8391842806571446, 0.33435233962341, 1.3229782988651269]
effort: []
time_from_start:
secs: 9
nsecs: 35854985
positions: [0.11219902594267216, -0.9670137344592727, -1.8607237937442624, -2.4463513115140865, 2.896075358727299, 2.0964833643778933, 2.3702601747158014]
velocities: [0.873628433929553, 1.1809565592328568, 1.1004671280578466, 0.18584474939185258, 0.34463552985202156, -0.13847991364238274, 0.7789881107068108]
accelerations: [1.178829035327993, -0.6754127110579362, 2.1962502398777835, -0.730124412219956, -0.8736886942602131, 0.43191596415573785, -0.9715893021702185]
effort: []
time_from_start:
secs: 9
nsecs: 265536186
positions: [2.5721243622218797, 0.4890257177649022, 1.8239544685384415, -2.7311607052669737, 2.7635875995088224, 2.216330276844053, 2.8973000049591064]
velocities: [-0.3389843527574834, -0.15634577986854664, 0.09134042429567002, -0.09032115063100243, -0.006603801070785689, 0.26163126545081683, -0.10170393076049722]
accelerations: [-2.1410218142378263, -1.2140688997749598, -2.487405481778824, 0.09225868120801983, 0.08545097339736743, 0.2297787155636069, -0.4936390601629802]
effort: []
time_from_start:
secs: 10
nsecs: 969641134
positions: [-0.877656311197903, -1.4088387322556999, -1.395013293663802, -2.7531309132445787, 2.868534276039565, 2.952849269544255, 2.063620653150253]
velocities: [-0.18185566878006365, 0.3656607890125213, 0.07141675528787894, -0.015062471017449727, -0.12287871553923543, 0.39181868032980566, -0.03125033009639877]
accelerations: [2.365587585497385, 1.8693819964823601, 2.501366038305531, -0.001892257153520745, -0.22857419502480128, -0.07453644325804584, 0.5871570631603973]
effort: []
time_from_start:
secs: 12
nsecs: 595747191
positions: [2.0291215959835713, 1.7305379859744194, 2.1146928631987247, -2.780604804289588, 2.355410691567288, 3.499719251966208, 2.8080707435790555]
velocities: [0.48970591767462196, 0.7622439596459536, 1.187568037653634, -0.04796541909131588, -0.5029115309570179, -0.32411519497819385, -1.0799080858894676]
accelerations: [-1.4576019644450484, -1.3060107788249675, -1.0745352418659437, -0.036037040158017876, -0.22140284133649818, -0.7526844069839503, -1.7587721198077022]
effort: []
time_from_start:
secs: 14
nsecs: 249405194
positions: [0.6076135528310457, 1.047600603296674, 2.5762719020620928, -2.925457273155385, 1.0852035469327912, 1.711940414451464, -1.9584454381954894]
velocities: [-0.6165430988928429, -1.194252716627932, 0.012133182669320161, -0.03121159828329711, 0.6077794068436323, 0.8155332083257167, -2.44486208665312]
accelerations: [0.3423382862445737, -1.735253700519111, -0.5089931819581115, 0.10176166731961772, 2.757010680084333, 3.796009998742757, 0.34933227694416746]
effort: []
time_from_start:
secs: 16
nsecs: 75656605
positions: [0.5782180762728595, 0.9173671338573478, 2.5615014599095693, -2.9243651599452685, 1.2087484502011063, 1.8806676359567618, -2.105821501628602]
velocities: [-0.5903974143626988, -1.001439297489445, -1.2017401732042856, 0.011134630219391362, 1.1143488737408493, 1.0951415813202787, -1.1622622505522564]
accelerations: [-0.23550384898766588, 1.7584082128204002, -1.6892416176010765, -0.009995629238600045, -1.3828590695389533, -2.6292689939048137, 1.939526459460825]
effort: []
time_from_start:
secs: 16
nsecs: 140303050
positions: [-1.048180665273533, 0.9435097153804629, -2.31041435735085, -2.91232395884303, 1.9201869136667706, 0.9405181652891821, -2.2061725019131355]
velocities: [0.7244582936623309, -0.42572663972343233, -0.2687322736018446, 0.020633624334952496, 0.14898197609297778, -0.018094033554471478, -0.07980277144771461]
accelerations: [1.479211016066067, -0.44604260587131467, 1.9439442576103059, 0.015559562712993625, -0.1719628648984873, 0.4095606993552777, -0.035694251333323705]
effort: []
time_from_start:
secs: 18
nsecs: 380264345
positions: [2.611284576741554, -0.5087078888221097, 0.4447599286608907, -2.851935851106143, 1.8871289153408721, 1.5858102131257303, -2.399333740648817]
velocities: [0.25460266036087276, -1.1640455024158167, 1.796938067613762, -0.010130115284625985, 0.8742089709884164, -0.28146486827618944, 0.42897423649013394]
accelerations: [-3.5238882590753944, -0.5521840471575954, 0.2925004066745321, -0.08444890429679759, 1.6402085102993285, -1.220249178018743, 0.997823723987763]
effort: []
time_from_start:
secs: 20
nsecs: 62777100
positions: [1.7828032049631843, -1.2373076735689637, 1.4177440739510478, -2.879862919440033, 2.7664747970253045, 1.1150899906388292, -1.9155356352004123]
velocities: [-1.5955391945713457, -0.8511702859547261, 0.271129914097039, 0.08641831957745112, -0.39734742946380897, -0.03414434405636346, 1.1621663116846397]
accelerations: [0.10379857219388616, 0.9068501143975796, -2.4898052063634606, 0.21063949834905016, -3.1992778406551117, 1.3478934474711135, 0.27984661934862]
effort: []
time_from_start:
secs: 20
nsecs: 560126132
positions: [-1.588117508108596, -1.7619106708029857, -1.7074151411367808, -2.3737917953247223, -2.8973000049591064, 3.0558704580839433, 1.071492547728093]
velocities: [-0.7542808442636779, -0.08332829097208842, -0.7002384842045246, 0.12393857299918637, 0.023619603198073325, 0.38772649316269664, 0.8279694862089577]
accelerations: [0.6982358020068443, 0.13950677062351668, 0.6464701001569084, -0.09513533066295549, 2.3422784417910396, -0.44415540332880027, -0.47419131618127547]
effort: []
time_from_start:
secs: 22
nsecs: 770154792
positions: [-1.551214787164648, -1.6058494317425738, -1.67739362685047, -2.3321076703621157, 2.8625360652246057, 2.8291914864097873, 1.7431645477898299]
velocities: [0.2252630390159866, 0.2372664267176807, -0.25773156052744706, 0.1834066222679872, 1.0923334689605548, -1.0477626596852978, 0.5059614147860833]
accelerations: [0.356564259665598, 0.2847664235626102, -0.4639304230295883, 0.28129347045934544, -2.5949122579450985, -1.615843106162693, 0.34469883561991604]
effort: []
time_from_start:
secs: 24
nsecs: 976988535
positions: [-1.4936855440248016, -1.5522971308596418, -1.7475562359974126, -2.285967395970261, 2.8061302092485705, 2.564913727336774, 1.8369985064518861]
velocities: [0.3719999536076576, 0.36143085353845145, -0.3910554132317936, 0.26479135809727183, -0.18159447747975666, -1.404286885872421, 0.5220853355597146]
accelerations: [-0.5062795401173359, -0.34720228526413066, 1.1305470458160551, -0.6810009565776021, 1.9966289025426953, 4.820981628847374, -1.5193722889568444]
effort: []
time_from_start:
secs: 25
nsecs: 109604269
positions: [-1.3833536912573983, -1.4388173762145, -1.8375599978105666, -2.2213544173055118, 2.828233904270775, 2.27475866840359, 1.9567247079720698]
accelerations: [-1.744219158232369, -1.7939838510719086, 1.4228555193252985, -1.0214565642716267, -0.3494338883869918, 4.587016350719919, -1.8927329614788317]
effort: []
time_from_start:
secs: 25
nsecs: 465288758
multi_dof_joint_trajectory:
header:
seq: 0
stamp:
secs: 0
nsecs: 0
frame_id: ''
joint_names: []
points: []
Am I doing something wrong? I will give bio_ik a try too but as I said it seems to be caused by RTTConnect.
