Preparing for Melodic sync 2020-08-19
There are currently 134 regressions and 288 packages ready to sync.
It’s a bit unusual to call a sync hold with that many regressions, but I know that all of them are caused by just two packages: moveit_resources and jsk_3rdparty. I have revert PRs opened for both of them: https://github.com/ros/rosdistro/pull/26216 and https://github.com/ros/rosdistro/pull/26237 . However, both maintainers are planning on doing new releases to fix those packages (thanks @k-okada and @rhaschke) .
With all of that being said, I plan to start holding releases today, August 19th, aiming for a sync at the end of the week. The only exception will be fixes for the above issues.
Please comment here if there are any other outstanding issues I should know about before performing the sync.
Looks like there is only one regression in ros_speech_recognition on ARM architectures.
@k-okada @furushchev Any ideas about how to fix it? If not, I think the intent is to do a sync about 24 hours from now regardless.
thanks, https://github.com/tork-a/jsk_3rdparty-release/commit/ac99e977966b5f87a2320d18123a17dd6cde2c8a will fix this issue.
2020年8月25日(火) 2:55 Sloretz via ROS Discourse <ros@discoursemail.com>:
The sync is out! :tada:
@k-okada Unfortunately it looks like the fix for ros_speech_recognition on ARM will have to wait for the next sync; I started it yesterday evening before the new jsk_3rdparty rosdistro PR :frowning:
@sloretz: it’s been a while already again :slight_smile:
Would a new sync for Melodic be possible?
I’ll take a look at doing another Melodic sync this week.
Thanks @clalancette.
Apologies for pinging you @sloretz.
