We’re happy to announce the next update of ROS Melodic. There are 26 new packages as well as 256 updated packages. Full details are below.
Package Updates for melodic
Added Packages [26]:
- ros-melodic-costmap-tf-layer: 1.0.1-1
- ros-melodic-costmap-tf-layer-dbgsym: 1.0.1-1
- ros-melodic-dingo-control: 0.1.0-1
- ros-melodic-dingo-description: 0.1.0-1
- ros-melodic-dingo-desktop: 0.1.0-1
- ros-melodic-dingo-gazebo: 0.1.0-1
- ros-melodic-dingo-msgs: 0.1.0-1
- ros-melodic-dingo-navigation: 0.1.0-1
- ros-melodic-dingo-simulator: 0.1.0-1
- ros-melodic-dingo-viz: 0.1.0-1
- ros-melodic-moveit-resources-fanuc-description: 0.7.0-1
- ros-melodic-moveit-resources-fanuc-moveit-config: 0.7.0-1
- ros-melodic-moveit-resources-panda-description: 0.7.0-1
- ros-melodic-moveit-resources-panda-moveit-config: 0.7.0-1
- ros-melodic-moveit-resources-pr2-description: 0.7.0-1
- ros-melodic-neo-local-planner: 1.0.0-1
- ros-melodic-neo-local-planner-dbgsym: 1.0.0-1
- ros-melodic-radial-menu: 0.3.4-1
- ros-melodic-radial-menu-example: 0.3.4-1
- ros-melodic-radial-menu-example-dbgsym: 0.3.4-1
- ros-melodic-radial-menu-model: 0.3.4-1
- ros-melodic-radial-menu-rviz: 0.3.4-1
- ros-melodic-radial-menu-rviz-dbgsym: 0.3.4-1
- ros-melodic-ros-speech-recognition-dbgsym: 2.1.21-2
- ros-melodic-udp-com: 1.1.1-1
- ros-melodic-udp-com-dbgsym: 1.1.1-1
Updated Packages [256]:
- ros-melodic-actionlib: 1.12.0-1 -> 1.12.1-1
- ros-melodic-actionlib-dbgsym: 1.12.0-1 -> 1.12.1-1
- ros-melodic-assimp-devel: 2.1.17-1 -> 2.1.21-2
- ros-melodic-assimp-devel-dbgsym: 2.1.17-1 -> 2.1.21-2
- ros-melodic-audio-capture: 0.3.6-1 -> 0.3.7-1
- ros-melodic-audio-capture-dbgsym: 0.3.6-1 -> 0.3.7-1
- ros-melodic-audio-common: 0.3.6-1 -> 0.3.7-1
- ros-melodic-audio-common-msgs: 0.3.6-1 -> 0.3.7-1
- ros-melodic-audio-play: 0.3.6-1 -> 0.3.7-1
- ros-melodic-audio-play-dbgsym: 0.3.6-1 -> 0.3.7-1
- ros-melodic-bayesian-belief-networks: 2.1.17-1 -> 2.1.21-2
- ros-melodic-chomp-motion-planner: 1.0.5-1 -> 1.0.6-1
- ros-melodic-chomp-motion-planner-dbgsym: 1.0.5-1 -> 1.0.6-1
- ros-melodic-collada-urdf-jsk-patch: 2.1.17-1 -> 2.1.21-2
- ros-melodic-collada-urdf-jsk-patch-dbgsym: 2.1.17-1 -> 2.1.21-2
- ros-melodic-combined-robot-hw: 0.18.1-1 -> 0.18.2-1
- ros-melodic-combined-robot-hw-dbgsym: 0.18.1-1 -> 0.18.2-1
- ros-melodic-combined-robot-hw-tests: 0.18.1-1 -> 0.18.2-1
- ros-melodic-combined-robot-hw-tests-dbgsym: 0.18.1-1 -> 0.18.2-1
- ros-melodic-controller-interface: 0.18.1-1 -> 0.18.2-1
- ros-melodic-controller-manager: 0.18.1-1 -> 0.18.2-1
- ros-melodic-controller-manager-dbgsym: 0.18.1-1 -> 0.18.2-1
- ros-melodic-controller-manager-msgs: 0.18.1-1 -> 0.18.2-1
- ros-melodic-controller-manager-tests: 0.18.1-1 -> 0.18.2-1
- ros-melodic-controller-manager-tests-dbgsym: 0.18.1-1 -> 0.18.2-1
- ros-melodic-costmap-cspace: 0.9.1-1 -> 0.10.0-1
- ros-melodic-costmap-cspace-dbgsym: 0.9.1-1 -> 0.10.0-1
- ros-melodic-diagnostic-aggregator: 1.9.3-0 -> 1.9.5-1
- ros-melodic-diagnostic-aggregator-dbgsym: 1.9.3-0 -> 1.9.5-1
- ros-melodic-diagnostic-analysis: 1.9.3-0 -> 1.9.5-1
- ros-melodic-diagnostic-common-diagnostics: 1.9.3-0 -> 1.9.5-1
- ros-melodic-diagnostic-updater: 1.9.3-0 -> 1.9.5-1
- ros-melodic-diagnostics: 1.9.3-0 -> 1.9.5-1
- ros-melodic-dialogflow-task-executive: 2.1.17-1 -> 2.1.21-2
- ros-melodic-downward: 2.1.17-1 -> 2.1.21-2
- ros-melodic-downward-dbgsym: 2.1.17-1 -> 2.1.21-2
- ros-melodic-ff: 2.1.17-1 -> 2.1.21-2
- ros-melodic-ff-dbgsym: 2.1.17-1 -> 2.1.21-2
- ros-melodic-ffha: 2.1.17-1 -> 2.1.21-2
- ros-melodic-ffha-dbgsym: 2.1.17-1 -> 2.1.21-2
- ros-melodic-gdrive-ros: 2.1.17-1 -> 2.1.21-2
- ros-melodic-genpy: 0.6.12-1 -> 0.6.14-1
- ros-melodic-hardware-interface: 0.18.1-1 -> 0.18.2-1
- ros-melodic-husky-base: 0.4.3-1 -> 0.4.4-1
- ros-melodic-husky-base-dbgsym: 0.4.3-1 -> 0.4.4-1
- ros-melodic-husky-bringup: 0.4.3-1 -> 0.4.4-1
- ros-melodic-husky-control: 0.4.3-1 -> 0.4.4-1
- ros-melodic-husky-description: 0.4.3-1 -> 0.4.4-1
- ros-melodic-husky-desktop: 0.4.3-1 -> 0.4.4-1
- ros-melodic-husky-gazebo: 0.4.3-1 -> 0.4.4-1
- ros-melodic-husky-msgs: 0.4.3-1 -> 0.4.4-1
- ros-melodic-husky-navigation: 0.4.3-1 -> 0.4.4-1
- ros-melodic-husky-robot: 0.4.3-1 -> 0.4.4-1
- ros-melodic-husky-simulator: 0.4.3-1 -> 0.4.4-1
- ros-melodic-husky-viz: 0.4.3-1 -> 0.4.4-1
- ros-melodic-joint-limits-interface: 0.18.1-1 -> 0.18.2-1
- ros-melodic-joystick-interrupt: 0.9.1-1 -> 0.10.0-1
- ros-melodic-joystick-interrupt-dbgsym: 0.9.1-1 -> 0.10.0-1
- ros-melodic-jsk-3rdparty: 2.1.17-1 -> 2.1.21-2
- ros-melodic-julius: 2.1.17-1 -> 2.1.21-2
- ros-melodic-julius-dbgsym: 2.1.17-1 -> 2.1.21-2
- ros-melodic-julius-ros: 2.1.17-1 -> 2.1.21-2
- ros-melodic-kinesis-manager: 2.0.1-1 -> 2.0.3-1
- ros-melodic-kinesis-manager-dbgsym: 2.0.1-1 -> 2.0.3-1
- ros-melodic-laser-filters-jsk-patch: 2.1.17-1 -> 2.1.21-2
- ros-melodic-laser-filters-jsk-patch-dbgsym: 2.1.17-1 -> 2.1.21-2
- ros-melodic-libcmt: 2.1.17-1 -> 2.1.21-2
- ros-melodic-libcmt-dbgsym: 2.1.17-1 -> 2.1.21-2
- ros-melodic-libmavconn: 1.2.0-1 -> 1.3.0-1
- ros-melodic-libmavconn-dbgsym: 1.2.0-1 -> 1.3.0-1
- ros-melodic-librealsense2: 2.36.0-1 -> 2.37.0-1
- ros-melodic-librealsense2-dbgsym: 2.36.0-1 -> 2.37.0-1
- ros-melodic-libsiftfast: 2.1.17-1 -> 2.1.21-2
- ros-melodic-libsiftfast-dbgsym: 2.1.17-1 -> 2.1.21-2
- ros-melodic-lpg-planner: 2.1.17-1 -> 2.1.21-2
- ros-melodic-map-organizer: 0.9.1-1 -> 0.10.0-1
- ros-melodic-map-organizer-dbgsym: 0.9.1-1 -> 0.10.0-1
- ros-melodic-mavlink: 2020.7.7-1 -> 2020.8.8-1
- ros-melodic-mavros: 1.2.0-1 -> 1.3.0-1
- ros-melodic-mavros-dbgsym: 1.2.0-1 -> 1.3.0-1
- ros-melodic-mavros-extras: 1.2.0-1 -> 1.3.0-1
- ros-melodic-mavros-extras-dbgsym: 1.2.0-1 -> 1.3.0-1
- ros-melodic-mavros-msgs: 1.2.0-1 -> 1.3.0-1
- ros-melodic-message-filters: 1.14.7-1 -> 1.14.9-1
- ros-melodic-message-filters-dbgsym: 1.14.7-1 -> 1.14.9-1
- ros-melodic-mini-maxwell: 2.1.17-1 -> 2.1.21-2
- ros-melodic-moveit: 1.0.5-1 -> 1.0.6-1
- ros-melodic-moveit-chomp-optimizer-adapter: 1.0.5-1 -> 1.0.6-1
- ros-melodic-moveit-chomp-optimizer-adapter-dbgsym: 1.0.5-1 -> 1.0.6-1
- ros-melodic-moveit-commander: 1.0.5-1 -> 1.0.6-1
- ros-melodic-moveit-controller-manager-example: 1.0.5-1 -> 1.0.6-1
- ros-melodic-moveit-controller-manager-example-dbgsym: 1.0.5-1 -> 1.0.6-1
- ros-melodic-moveit-core: 1.0.5-1 -> 1.0.6-1
- ros-melodic-moveit-core-dbgsym: 1.0.5-1 -> 1.0.6-1
- ros-melodic-moveit-fake-controller-manager: 1.0.5-1 -> 1.0.6-1
- ros-melodic-moveit-fake-controller-manager-dbgsym: 1.0.5-1 -> 1.0.6-1
- ros-melodic-moveit-kinematics: 1.0.5-1 -> 1.0.6-1
- ros-melodic-moveit-kinematics-dbgsym: 1.0.5-1 -> 1.0.6-1
- ros-melodic-moveit-planners: 1.0.5-1 -> 1.0.6-1
- ros-melodic-moveit-planners-chomp: 1.0.5-1 -> 1.0.6-1
- ros-melodic-moveit-planners-chomp-dbgsym: 1.0.5-1 -> 1.0.6-1
- ros-melodic-moveit-planners-ompl: 1.0.5-1 -> 1.0.6-1
- ros-melodic-moveit-planners-ompl-dbgsym: 1.0.5-1 -> 1.0.6-1
- ros-melodic-moveit-plugins: 1.0.5-1 -> 1.0.6-1
- ros-melodic-moveit-resources: 0.6.5-1 -> 0.7.0-1
- ros-melodic-moveit-ros: 1.0.5-1 -> 1.0.6-1
- ros-melodic-moveit-ros-benchmarks: 1.0.5-1 -> 1.0.6-1
- ros-melodic-moveit-ros-benchmarks-dbgsym: 1.0.5-1 -> 1.0.6-1
- ros-melodic-moveit-ros-control-interface: 1.0.5-1 -> 1.0.6-1
- ros-melodic-moveit-ros-control-interface-dbgsym: 1.0.5-1 -> 1.0.6-1
- ros-melodic-moveit-ros-manipulation: 1.0.5-1 -> 1.0.6-1
- ros-melodic-moveit-ros-manipulation-dbgsym: 1.0.5-1 -> 1.0.6-1
- ros-melodic-moveit-ros-move-group: 1.0.5-1 -> 1.0.6-1
- ros-melodic-moveit-ros-move-group-dbgsym: 1.0.5-1 -> 1.0.6-1
- ros-melodic-moveit-ros-occupancy-map-monitor: 1.0.5-1 -> 1.0.6-1
- ros-melodic-moveit-ros-occupancy-map-monitor-dbgsym: 1.0.5-1 -> 1.0.6-1
- ros-melodic-moveit-ros-perception: 1.0.5-1 -> 1.0.6-1
- ros-melodic-moveit-ros-perception-dbgsym: 1.0.5-1 -> 1.0.6-1
- ros-melodic-moveit-ros-planning: 1.0.5-1 -> 1.0.6-1
- ros-melodic-moveit-ros-planning-dbgsym: 1.0.5-1 -> 1.0.6-1
- ros-melodic-moveit-ros-planning-interface: 1.0.5-1 -> 1.0.6-1
- ros-melodic-moveit-ros-planning-interface-dbgsym: 1.0.5-1 -> 1.0.6-1
- ros-melodic-moveit-ros-robot-interaction: 1.0.5-1 -> 1.0.6-1
- ros-melodic-moveit-ros-robot-interaction-dbgsym: 1.0.5-1 -> 1.0.6-1
- ros-melodic-moveit-ros-visualization: 1.0.5-1 -> 1.0.6-1
- ros-melodic-moveit-ros-visualization-dbgsym: 1.0.5-1 -> 1.0.6-1
- ros-melodic-moveit-ros-warehouse: 1.0.5-1 -> 1.0.6-1
- ros-melodic-moveit-ros-warehouse-dbgsym: 1.0.5-1 -> 1.0.6-1
- ros-melodic-moveit-runtime: 1.0.5-1 -> 1.0.6-1
- ros-melodic-moveit-servo: 1.0.5-1 -> 1.0.6-1
- ros-melodic-moveit-servo-dbgsym: 1.0.5-1 -> 1.0.6-1
- ros-melodic-moveit-setup-assistant: 1.0.5-1 -> 1.0.6-1
- ros-melodic-moveit-setup-assistant-dbgsym: 1.0.5-1 -> 1.0.6-1
- ros-melodic-moveit-simple-controller-manager: 1.0.5-1 -> 1.0.6-1
- ros-melodic-moveit-simple-controller-manager-dbgsym: 1.0.5-1 -> 1.0.6-1
- ros-melodic-mrt-cmake-modules: 1.0.3-1 -> 1.0.4-1
- ros-melodic-neonavigation: 0.9.1-1 -> 0.10.0-1
- ros-melodic-neonavigation-common: 0.9.1-1 -> 0.10.0-1
- ros-melodic-neonavigation-launch: 0.9.1-1 -> 0.10.0-1
- ros-melodic-nlopt: 2.1.17-1 -> 2.1.21-2
- ros-melodic-nlopt-dbgsym: 2.1.17-1 -> 2.1.21-2
- ros-melodic-obj-to-pointcloud: 0.9.1-1 -> 0.10.0-1
- ros-melodic-obj-to-pointcloud-dbgsym: 0.9.1-1 -> 0.10.0-1
- ros-melodic-open-karto: 1.2.1-1 -> 1.2.2-1
- ros-melodic-open-karto-dbgsym: 1.2.1-1 -> 1.2.2-1
- ros-melodic-opt-camera: 2.1.17-1 -> 2.1.21-2
- ros-melodic-opt-camera-dbgsym: 2.1.17-1 -> 2.1.21-2
- ros-melodic-oxford-gps-eth: 1.2.0-1 -> 1.2.1-1
- ros-melodic-oxford-gps-eth-dbgsym: 1.2.0-1 -> 1.2.1-1
- ros-melodic-pgm-learner: 2.1.17-1 -> 2.1.21-2
- ros-melodic-planner-cspace: 0.9.1-1 -> 0.10.0-1
- ros-melodic-planner-cspace-dbgsym: 0.9.1-1 -> 0.10.0-1
- ros-melodic-radial-menu-backend: 0.2.0-1 -> 0.3.4-1
- ros-melodic-radial-menu-backend-dbgsym: 0.2.0-1 -> 0.3.4-1
- ros-melodic-radial-menu-msgs: 0.2.0-1 -> 0.3.4-1
- ros-melodic-rc-hand-eye-calibration-client: 3.0.1-1 -> 3.0.2-1
- ros-melodic-rc-hand-eye-calibration-client-dbgsym: 3.0.1-1 -> 3.0.2-1
- ros-melodic-rc-pick-client: 3.0.1-1 -> 3.0.2-1
- ros-melodic-rc-pick-client-dbgsym: 3.0.1-1 -> 3.0.2-1
- ros-melodic-rc-roi-manager-gui: 3.0.1-1 -> 3.0.2-1
- ros-melodic-rc-roi-manager-gui-dbgsym: 3.0.1-1 -> 3.0.2-1
- ros-melodic-rc-silhouettematch-client: 3.0.1-1 -> 3.0.2-1
- ros-melodic-rc-silhouettematch-client-dbgsym: 3.0.1-1 -> 3.0.2-1
- ros-melodic-rc-tagdetect-client: 3.0.1-1 -> 3.0.2-1
- ros-melodic-rc-tagdetect-client-dbgsym: 3.0.1-1 -> 3.0.2-1
- ros-melodic-rc-visard: 3.0.1-1 -> 3.0.2-1
- ros-melodic-rc-visard-description: 3.0.1-1 -> 3.0.2-1
- ros-melodic-rc-visard-driver: 3.0.1-1 -> 3.0.2-1
- ros-melodic-rc-visard-driver-dbgsym: 3.0.1-1 -> 3.0.2-1
- ros-melodic-realsense2-camera: 2.2.15-1 -> 2.2.16-1
- ros-melodic-realsense2-camera-dbgsym: 2.2.15-1 -> 2.2.16-1
- ros-melodic-realsense2-description: 2.2.15-1 -> 2.2.16-1
- ros-melodic-respeaker-ros: 2.1.17-1 -> 2.1.21-2
- ros-melodic-ros-comm: 1.14.7-1 -> 1.14.9-1
- ros-melodic-ros-control: 0.18.1-1 -> 0.18.2-1
- ros-melodic-ros-pytest: 0.1.2-2 -> 0.2.0-0
- ros-melodic-ros-speech-recognition: 2.1.17-1 -> 2.1.21-2
- ros-melodic-ros-tutorials: 0.9.2-1 -> 0.9.3-1
- ros-melodic-rosbag: 1.14.7-1 -> 1.14.9-1
- ros-melodic-rosbag-dbgsym: 1.14.7-1 -> 1.14.9-1
- ros-melodic-rosbag-storage: 1.14.7-1 -> 1.14.9-1
- ros-melodic-rosbag-storage-dbgsym: 1.14.7-1 -> 1.14.9-1
- ros-melodic-rosconsole: 1.13.16-1 -> 1.13.17-1
- ros-melodic-rosconsole-dbgsym: 1.13.16-1 -> 1.13.17-1
- ros-melodic-roscpp: 1.14.7-1 -> 1.14.9-1
- ros-melodic-roscpp-dbgsym: 1.14.7-1 -> 1.14.9-1
- ros-melodic-roscpp-tutorials: 0.9.2-1 -> 0.9.3-1
- ros-melodic-roscpp-tutorials-dbgsym: 0.9.2-1 -> 0.9.3-1
- ros-melodic-rosdiagnostic: 1.9.3-0 -> 1.9.5-1
- ros-melodic-rosgraph: 1.14.7-1 -> 1.14.9-1
- ros-melodic-roslaunch: 1.14.7-1 -> 1.14.9-1
- ros-melodic-roslz4: 1.14.7-1 -> 1.14.9-1
- ros-melodic-roslz4-dbgsym: 1.14.7-1 -> 1.14.9-1
- ros-melodic-rosmaster: 1.14.7-1 -> 1.14.9-1
- ros-melodic-rosmsg: 1.14.7-1 -> 1.14.9-1
- ros-melodic-rosnode: 1.14.7-1 -> 1.14.9-1
- ros-melodic-rosout: 1.14.7-1 -> 1.14.9-1
- ros-melodic-rosout-dbgsym: 1.14.7-1 -> 1.14.9-1
- ros-melodic-rosparam: 1.14.7-1 -> 1.14.9-1
- ros-melodic-rospatlite: 2.1.17-1 -> 2.1.21-2
- ros-melodic-rosping: 2.1.17-1 -> 2.1.21-2
- ros-melodic-rosping-dbgsym: 2.1.17-1 -> 2.1.21-2
- ros-melodic-rospy: 1.14.7-1 -> 1.14.9-1
- ros-melodic-rospy-tutorials: 0.9.2-1 -> 0.9.3-1
- ros-melodic-rosservice: 1.14.7-1 -> 1.14.9-1
- ros-melodic-rostest: 1.14.7-1 -> 1.14.9-1
- ros-melodic-rostopic: 1.14.7-1 -> 1.14.9-1
- ros-melodic-rostwitter: 2.1.17-1 -> 2.1.21-2
- ros-melodic-roswtf: 1.14.7-1 -> 1.14.9-1
- ros-melodic-rqt-bag: 0.4.12-0 -> 0.4.14-1
- ros-melodic-rqt-bag-plugins: 0.4.12-0 -> 0.4.14-1
- ros-melodic-rqt-controller-manager: 0.18.1-1 -> 0.18.2-1
- ros-melodic-rqt-image-view: 0.4.14-1 -> 0.4.16-1
- ros-melodic-rqt-image-view-dbgsym: 0.4.14-1 -> 0.4.16-1
- ros-melodic-safety-limiter: 0.9.1-1 -> 0.10.0-1
- ros-melodic-safety-limiter-dbgsym: 0.9.1-1 -> 0.10.0-1
- ros-melodic-self-test: 1.9.3-0 -> 1.9.5-1
- ros-melodic-self-test-dbgsym: 1.9.3-0 -> 1.9.5-1
- ros-melodic-sesame-ros: 2.1.17-1 -> 2.1.21-2
- ros-melodic-sesame-ros-dbgsym: 2.1.17-1 -> 2.1.21-2
- ros-melodic-slic: 2.1.17-1 -> 2.1.21-2
- ros-melodic-sound-play: 0.3.6-1 -> 0.3.7-1
- ros-melodic-test-diagnostic-aggregator: 1.9.3-0 -> 1.9.5-1
- ros-melodic-test-mavros: 1.2.0-1 -> 1.3.0-1
- ros-melodic-test-mavros-dbgsym: 1.2.0-1 -> 1.3.0-1
- ros-melodic-topic-tools: 1.14.7-1 -> 1.14.9-1
- ros-melodic-topic-tools-dbgsym: 1.14.7-1 -> 1.14.9-1
- ros-melodic-toposens: 2.0.2-1 -> 2.0.3-1
- ros-melodic-toposens-description: 2.0.2-1 -> 2.0.3-1
- ros-melodic-toposens-driver: 2.0.2-1 -> 2.0.3-1
- ros-melodic-toposens-driver-dbgsym: 2.0.2-1 -> 2.0.3-1
- ros-melodic-toposens-markers: 2.0.2-1 -> 2.0.3-1
- ros-melodic-toposens-markers-dbgsym: 2.0.2-1 -> 2.0.3-1
- ros-melodic-toposens-msgs: 2.0.2-1 -> 2.0.3-1
- ros-melodic-toposens-pointcloud: 2.0.2-1 -> 2.0.3-1
- ros-melodic-toposens-pointcloud-dbgsym: 2.0.2-1 -> 2.0.3-1
- ros-melodic-toposens-sync: 2.0.2-1 -> 2.0.3-1
- ros-melodic-toposens-sync-dbgsym: 2.0.2-1 -> 2.0.3-1
- ros-melodic-track-odometry: 0.9.1-1 -> 0.10.0-1
- ros-melodic-track-odometry-dbgsym: 0.9.1-1 -> 0.10.0-1
- ros-melodic-trajectory-tracker: 0.9.1-1 -> 0.10.0-1
- ros-melodic-trajectory-tracker-dbgsym: 0.9.1-1 -> 0.10.0-1
- ros-melodic-transmission-interface: 0.18.1-1 -> 0.18.2-1
- ros-melodic-transmission-interface-dbgsym: 0.18.1-1 -> 0.18.2-1
- ros-melodic-turtlesim: 0.9.2-1 -> 0.9.3-1
- ros-melodic-turtlesim-dbgsym: 0.9.2-1 -> 0.9.3-1
- ros-melodic-urg-stamped: 0.0.6-2 -> 0.0.7-1
- ros-melodic-urg-stamped-dbgsym: 0.0.6-2 -> 0.0.7-1
- ros-melodic-voice-text: 2.1.17-1 -> 2.1.21-2
- ros-melodic-voice-text-dbgsym: 2.1.17-1 -> 2.1.21-2
- ros-melodic-warthog-gazebo: 0.2.0-1 -> 0.2.1-1
- ros-melodic-warthog-gazebo-dbgsym: 0.2.0-1 -> 0.2.1-1
- ros-melodic-warthog-simulator: 0.2.0-1 -> 0.2.1-1
- ros-melodic-xacro: 1.13.6-1 -> 1.13.7-1
- ros-melodic-xmlrpcpp: 1.14.7-1 -> 1.14.9-1
- ros-melodic-xmlrpcpp-dbgsym: 1.14.7-1 -> 1.14.9-1
Removed Packages [0]:
- AWS RoboMaker
- Alexander Rössler
- Atsushi Watanabe
- Austin Hendrix
- Ben Charrow
- Bence Magyar
- Blake Anderson
- Brice Rebsamen
- Chittaranjan Srinivas Swaminathan
- Dave Coleman
- Dirk Thomas
- Evan Flynn
- Fabian Poggenhans
- Felix Ruess
- Guillaume Autran
- Hitoshi Kamada
- Igor Banfi
- Isaac I. Y. Saito
- Jon Binney
- Kei Okada
- Kevin Hallenbeck
- Mathias Lüdtke
- Michael Carroll
- Michael Ferguson
- Michael Görner
- Mike Lautman
- Monika Florek-Jasinska
- Neobotix GmbH
- Noda Shintaro
- Raghavender Sahdev
- Robert Haschke
- Ryohei Ueda
- Sebastian Dengler
- Sergey Dorodnicov
- Shingo Kitagawa
- Takuya Nakaoka
- Tony Baltovksi
- Tony Baltovski
- Vladimir Ermakov
- Yohei Kakiuchi
- Yoshito Okada
- Yuki Furuta
- Yuto Inagaki
- k-okada
